U344-001-DP
U344-001-DP
    TRIPPLITE
    USB3.0TODISPLAYPORTVIDADAPT
U344-001-DP 数据手册
USB 3.0 SuperSpeed to DisplayPort Dual-Monitor Cable, 512 MB SDRAM, 2560 x 1600, 1080p MODEL NUMBER: U344-001-DP Highlights ● Add an additional DisplayPort monitor through a single USB 3.0 port ● Windows and Intel Mac compatible ● Up to six adapters can be added to one computer ● Features 512MB DDR2 SDRAM of memory ● Supports video resolutions up to 2560 x 1600 @ 60Hz ● Compatible with Ubuntu 14.04.2 System Requirements ● Compatible with Windows 7 and later. Supports both 32- and 64bit. ● Supports Surface tablets running non-RT Windows 8, 8.1 and 10. ● Compatible with Intel Mac OS X 10.8.5 and later, Mac 10.11. Supports both 32- and 64-bit. ● Mac OS X versions 10.8.5 and earlier do not support audio over USB 3.0. Mac OS X versions 10.7.x and earlier do not support USB 3.0. ● Reference the owner's manual for system requirements when using multiple adapters or when using the add-on monitor for DVD playback. Add an additional Displayport Monitor or Projector through a single USB 3.0 port Description Tripp Lite U344-001-DP USB 3.0 SuperSpeed to DisplayPort Dual-Monitor Cable creates as an external DisplayPort video card via an available USB 3.0 port on your PC or Laptop. Connect up to six DisplayPort enabled monitors, with support for video resolutions up to 2560 x 1600 (1080p) and 5.1 surround sound audio. Taking advantage of the SuperSpeed USB 3.0 interface ( 5Gbps), the external video graphics card adapter delivers smooth, high-definition content to your DisplayPort-capable display, and can be used to clone the image on multiple displays, or extended across them. Windows and Intel Mac compatible. Package Includes ● U344-001-DP USB 3.0 SuperSpeed to DisplayPort Dual-Monitor Cable ● Driver CD ● USB 3.0 Cable ● Owners Manual Features ● Adds an additional monitor, LCD or projector through a single USB 3.0 port ● USB 3.0 is 10 times faster than USB 2.0, with transfer rates up to 5 Gbps ● Backward compatible with USB 2.0 ● Simultaneously connect up to 6 display adapters ● Automatically resumes from hibernation and suspend modes ● Features 512MB DDR2 SDRAM of memory ● Supports video resolutions up to 2560 x 1600 @ 60Hz ● Video streaming is supported up to 1080p ● Set additional monitors to extend the primary display, duplicate the primary display, or set an additional monitor as the primary display ● Compatible with Windows 7 and later. Supports both 32- and 64-bit. ● Supports Surface tablets running non-RT Windows 8, 8.1 and 10. ● Compatible with Intel Mac OS X 10.8.5 and later, Mac 10.11. Supports both 32- and 64-bit. ● Mac OS X versions 10.8.5 and earlier do not support audio over USB 3.0. Mac OS X versions 10.7.x and earlier do not support USB 3.0. 1/3 ● Uses DisplayLink DL3500 chipset Specifications OVERVIEW UPC Code 037332180346 Technology DisplayPort VIDEO Max Supported Video Resolution 2560 x 1600 @60Hz INPUT Bus Powered Yes PHYSICAL Color Black Material of Construction ABS Shipping Dimensions (hwd / in.) 1.00 x 5.00 x 6.00 Shipping Dimensions (hwd / cm) 2.54 x 12.70 x 15.24 Shipping Weight (lbs.) 0.40 Shipping Weight (kg) 0.18 Unit Dimensions (hwd / in.) 0.750 x 2.250 x 3.250 Unit Packaging Type Box Unit Weight (lbs.) 0.10 Unit Weight (kg) 0.05 ENVIRONMENTAL Storage Temperature Range -4 to 158 F (-20 to 70 C) Relative Humidity 0% to 90 RH, Non-Condensing Operating Temperature 50 to 104 F (10 to 40 C) CONNECTIONS Number of Ports 1 Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 DISPLAYPORT (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS 2/3 Displayport Specification 1.1a USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required Yes WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U344-001-DP 价格&库存
很抱歉,暂时无法提供与“U344-001-DP”相匹配的价格&库存,您可以联系我们找货
