Note: Connecting both ports to the same network switch may lead to unpredictable results. We
recommend this product be utilized for dual-homed or multi-homed host systems or as a 2-port network
Highlights
Add two 10/100/1000 Gigabit
Ethernet ports via a single USB
3.0 port
Can be used as a 2-port
network switch, with one port
connecting a computer to a
network and the second port
sharing the connection with
another computer
Compatible with Windows,
MAC, Linux and Chromium
Operating Systems
switch; one port connects a computer to a network and a second port shares a network connection with
another computer multi-homing
USB 3.0 SuperSpeed to Dual Port Gigabit
Ethernet Adapter
MODEL NUMBER: U336-002-GB
System Requirements
An available USB 3.0 port. Unit
is backward compatible with
USB 2.0, but at USB 2.0 speeds
Compatible with Windows®,
Mac®, Linux and Chromium
Operating Systems
Package Includes
Add two Gigabit Ethernet ports via the USB 3.0 port on your Chromebook, laptop, or other computer
Description
Tripp Lite's U336-002-GB USB 3.0 to Dual Gigabit Ethernet Adapter allows you to quickly add two Gigabit
Ethernet ports to your computer through a single USB 3.0 port - no need to open up your computer case
to add an internal Ethernet card. Ideal for network administrators that require dual-homed or multi-homed
host systems. Can also be used as a 2-port network switch; one port connects a computer to a network
and a second port shares a network connection with another computer. The adapter's compliance with
USB 3.0 (5Gbps) ensures true Gigabit network speed without any compromise. Furthermore, the adapter
is compact and USB bus-powered, requiring no external power adapter.
Features
Can be used as a 2-port network switch; one port connects a computer to a network and a second port
Compliant with IEEE 802.3i (10BASE-T Ethernet), 802.3u (100BASE-TX Fast Ethernet), 802.3ab
(1000BASE-T GbE) and IEEE 802.3az (Energy Efficient Ethernet) standards
Supports full-duplex with IEEE 802.3x flow control and half-duplex with back-pressure flow control
Supports IPv4 and IPv6 pack Checksum Offload Engine (COE) and TCP large segment offload (LSO)
to reduce CPU loading
Suspend mode and remote wakeup is supported via link-change, Magic Packet, Microsoft Wakeup
Frame and external wakeup pin
Supports Jumbo Frames up to 4K
Supports VLAN tagging
Supports Wake-on-LAN
Features a Micro-USB port for connecting to a power source when your computer or laptop is powered
off
1/3
USB 3.0 Dual Port Gigabit
Ethernet Adapter
Owner’s Manual
Driver CD
Specifications
OVERVIEW
UPC Code
037332186911
Technology
Cat5/5e; Cat6
INPUT
Bus Powered
Yes
Product Length (in.)
10
POWER
Power Consumption (Watts)
1.9
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Green (Link); Yellow (Activity)
PHYSICAL
Color
Black
Material of Construction
Polycarbonate, ABS
Cable Jacket Rating
VW-1
Shipping Dimensions (hwd / in.)
6.70 x 3.86 x 1.18
Shipping Dimensions (hwd / cm)
17.02 x 9.80 x 3.00
Shipping Weight (lbs.)
0.25
Shipping Weight (kg)
0.11
Unit Dimensions (hwd / in.)
0.9 x 3 x 2
Unit Packaging Type
Box
Unit Weight (lbs.)
0.12
Unit Weight (kg)
0.05
ENVIRONMENTAL
Operating Temperature Range
-4 to 158 F (-20 to 70 C)
Storage Temperature Range
-4 to 185 F (-20 to 85 C)
Relative Humidity
20% to 80% RH, Non-Condensing
BTUs
6.4 BTU/Hr
COMMUNICATIONS
2/3
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3; 802.3u; 802.3az
CONNECTIONS
Number of Ports
2
Side A - Connector 1
USB 3.0 A (MALE)
Side B - Connector 1
(2) RJ45 (FEMALE)
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
USB Specification
USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps)
Driver Required
Yes
Auto MDIX Support
Yes
Full Duplex Support
Yes
Suspend Mode Support
Yes
Remote Wakeup Support
Yes
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
3/3
很抱歉,暂时无法提供与“U336-002-GB”相匹配的价格&库存,您可以联系我们找货
