P116-000-HDMI
P116-000-HDMI
    TRIPPLITE
    CABLECONVERTER
P116-000-HDMI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States The display you are connecting must have an HDMI port that can accept a converted HDMI signal. Contact your display manufacturer to confirm it will work with a VGA + Audio to HDMI converter. If your Highlights ● Connect your VGA laptop or PC to a HDMI display to enjoy HD video and audio adapter. ● VGA with Audio to HDMI Converter, Adapter for Stereo Audio and Video Convert RGB Video and Stereo Audio signals for use on a HDMI display ● Plug-and-play operation with no software required for easy, immediate installation ● Supports HD video resolutions up to 1080p, and computer video resolutions up to 1280 x 1024 ● Reduce equipment cost by eliminating the need to update your computer's video card display does not support this, an alternative solution is Tripp Lite's U244-001-HDMI-R USB to HDMI MODEL NUMBER: P116-000-HDMI System Requirements ● The display you are connecting must have a HDMI port that can accept a converted HDMI signal. Contact your display manufacturer to confirm that it will work with a VGA + Audio to HDMI converter. If your display does not support this, an alternative solution is Tripp Lite's U244-001-VGA-R USB to HDMI adapter. ● Computer with a VGA Video and 3.5 mm. or RCA Audio Jacks (If your computer has only a 3.5 mm. Mini Stereo Audio jack, you can use a 3.5 mm. to RCA adapter cable such as Tripp Lite's P314-006. ● DVD player, DVR, etc. with RGB Video and Stereo Audio jacks (Component video to VGA adapter required) ● Supported PC Video Resolutions - 640 x 480 @ 60Hz, 72Hz, 75Hz, 85Hz, 800 x 600 @ 56Hz, 60Hz, 72Hz, 75Hz, 85Hz, 1024 x 768 @ 60Hz, 70Hz, 75Hz, 80Hz, 85Hz, 1280 x 1024 @ 60Hz, 75Hz ● Supported HD Video Resolutions - 480i @ 60Hz, 480p @ 60Hz, 720p @ 60Hz, 1080i @ 60Hz, 1080p @ 60Hz Converts the VGA and Audio signal from a laptop or PC for use on a HDMI display Description Tripp Lite's P116-000-HDMI VGA + Audio to HDMI converter is the perfect solution for using your older laptop or PC with your new HDMI display. Simply connect your computers VGA and Audio ports to the converter, and the converter to the HDMI port on your display, and you are ready to go. No software or drivers required. If your computer has only a 3.5 mm. Mini Stereo Audio jack, connect it to the converter using a 3.5 mm. to RCA adapter cable such as Tripp Lite's P314-006. You can also convert the RGB Video and Stereo Audio signals on your DVD player, DVR, etc., for use on your HDMI display (Component Video to VGA adapter required) Furthermore, you reduce your equipment costs by eliminating the need to upgrade your computer's video card. The P116-000-HDMI supports HD video resolutions up to 1080p, and computer video resolutions up to 1280 x 1024. Supports 24-bit True Color (8-bits per channel), and HDCP compliant. Features ● Connect your VGA laptop or PC to a HDMI display to enjoy high definition video and audio ● Convert the RGB Video and Stereo Audio signals from your DVD player, DVR, etc., for use on a HDMI display (Component Video to VGA adapter required) ● Plug-and-Play, no software or drivers required ● Supports HD video resolutions up to 1080p, and computer video resolutions up to 1280 x 1024 ● Supports 24-bit True Color (8 bits per channel) ● Reduce equipment cost by eliminating the need to update your computer's video card 1/3 Package Includes ● P116-000-HDMI VGA + Audio to HDMI Converter ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.35A; Output: 1000 Eaton Boulevard Cleveland, OH 44122 United States 5V, 2A, 4 ft.) ● Specifications OVERVIEW UPC Code 037332180162 Technology HDMI; VGA/SVGA; Stereo Audio POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.35A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.0 External Power Supply Cord Length (m.) 1.2 DC Barrel Plug OD: 5.5 x 2.1 x 10mm, Positive Pin, Negative Sleeve PHYSICAL Color Black Shipping Dimensions (hwd / in.) 5.70 x 2.50 x 8.10 Shipping Dimensions (hwd / cm) 14.48 x 6.35 x 20.57 Shipping Weight (lbs.) 0.90 Shipping Weight (kg) 0.41 Unit Dimensions (hwd / in.) 1.250 x 3.500 x 2.750 Unit Dimensions (hwd / cm) 3.18 x 8.89 x 6.99 Unit Weight (lbs.) 0.40 Unit Weight (kg) 0.18 ENVIRONMENTAL Operating Temperature Range 32 to 158 F (0 to 70 C) Storage Temperature Range 14 to 176 F (-10 to 80 C) Operating Humidity Range 10 to 85% RH, Non-Condensing Storage Humidity Range 5 to 90% RH, Non-Condensing 2/3 Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Side A - Connector 1 HD15 (FEMALE) Side A - Connector 2 (2) RCA (FEMALE) Side B - Connector 1 HDMI (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P116-000-HDMI 价格&库存
很抱歉,暂时无法提供与“P116-000-HDMI”相匹配的价格&库存,您可以联系我们找货
