U342-DHG-402
U342-DHG-402
    TRIPPLITE
    USB3.0TODISPLAYPORTVIDADAPT
U342-DHG-402 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 3.0 SuperSpeed Laptop Dock - HDMI, DVI Video, Audio, USB, Ethernet MODEL NUMBER: U342-DHG-402 Highlights ● Add multiple ports to your laptop via one USB 3.0 connection ● Backward compatible to USB 2.0 and 1.1 ● Windows 7 and later compatible, Windows 10 ● Mac OS 10.8.5 and later compatible, Mac 10.11 ● Compatible with Ubuntu 14.04.2 System Requirements USB dock adds HDMI, DVI, 3.5 mm audio, Gigabit Ethernet and six USB ports to your computer, laptop or other device with a USB-A port. ● Windows® 7 / Windows 10 (32and 64-bit), 8 (32- and 64-bit), 8.1 (32- and 64-bit) or 10 (32and 64-bit) ● Mac OS X 10.8.5 and later, Mac 10.11 ● Available USB port (USB 3.0 required for USB 3.0 speeds) ● VGA*, DVI or HDMI monitor ● 1.6 GHz Single Core processor (DVD playback on the add-on monitor requires a 2.0 GHz Dual Core processor) ● 1 GB RAM ● 30 MB of available disk space ( * Requires a DVI-VGA adapter, such as Tripp Lite P556- Seris cable ) Description The U342-DHG-402 dock adds HDMI, DVI, 3.5 mm audio, Gigabit Ethernet and six USB ports to your computer, laptop or other device with a USB-A port. Two of the six USB-A ports support USB 3.2 Gen 1 speeds up to 5 Gbps. One USB 3.0 port also supports BC 1.2 charging with 5V 1.5A (7.5W) of power dedicated to fast-charging your mobile device. The universal USB docking station features two independent external monitor outputs (HDMI, DVI) that can be used to expand or mirror your computer's main desktop. Both HDMI and DVI outputs support video resolutions up to 2048 x 1152 @ 60 Hz, including 1080p, and can be used simultaneously. A DVI monitor can be connected to the HDMI port via an HDMI-to-DVI adapter (sold separately). A VGA monitor can be connected to the DVI-I port using a DVI-to-VGA adapter (sold separately). An all-in-one solution, the U342-DHG-402 also features audio ports for connecting a microphone and speakers, as well as an RJ45 port for connecting to a Gigabit Ethernet network. The USB dock supports true 10/100/1000 Mbps (1 Gbps) Gigabit Ethernet speeds. The U342-DHG-402 is an ideal accessory for enhancing laptop capability for users who need to connect and manage multiple devices at home or at the office. Compatible with Windows and Mac computers. Features ● USB 3.0 is 10 times faster than USB 2.0 and supports data transfer rates of up to 5 Gbps ● Backward compatible with USB 2.0 and 1.1 ● DVI-I and HDMI ports for connection of external monitors ● A VGA monitor can be connected to the DVI-I port using a DVI-to-VGA adapter, such as a Tripp Lite P556-Series cable ● A DVI monitor can be connected to the HDMI port using an HDMI-to-DVI adapter, such as a Tripp Lite P566-Series cable ● Supports video resolutions of up to 2048 x 1152 @ 60 Hz ● Automatically resumes operation from hibernation and suspend modes ● Gigabit Ethernet port supports true 10/100/1000 Mbps network speeds ● IEEE 802.3az (Energy Efficient Ethernet) compliant ● Supports full duplex and half duplex operations ● Supports IPv4 and IPv6 pack Checksum Offload Engine (COE) to reduce CPU loading 1/5 Package Includes ● U342-DHG-402 ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60 Hz, 0.8A; Output: 5V, 4A), 6 ft. ● USB 3.0 A/B Cable, 3 ft. ● Driver CD ● Owner’s Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Supports Wake-on LAN, VLAN tagging and Auto-MDIX ● Two USB 3.0 and four USB 2.0 hub ports for connection of additional USB peripherals ● One USB 3.0 port supports USB Battery Charging (BC) specification 1.2, allowing it to provide 1.5 amps of power for faster charging of mobile devices ● 3.5 mm Mini Stereo jacks for connection of speaker and microphone ● Compatible with Windows 7 and later, Windows 10 ● Compatible with Mac OS 10.8.5 and later, Mac 10.11 Specifications OVERVIEW UPC Code 037332182586 Product Type Docking Station Technology Cat5/5e; Cat6; DVI; HDMI; Stereo Audio Host Connector USB A (MALE) VIDEO Number of Monitors Supported 2 Video Ports DVI-I (FEMALE); HDMI (FEMALE) Video Ports Details HDMI 1.3 Resolutions Supported Both HDMI and DVI outputs support video resolutions up to 2048 x 1152 @ 60 Hz Max Supported Video Resolution 2048 x 1152 @60Hz Extended Mode Yes Extended Mode Details Supports HDMI and DVI can be simultaneously extended at 1080p each Mirror Mode Yes Mirror Mode Details Supports HDMI and DVI can be simultaneously mirrored at 1080p each HDR Support No AUDIO Audio Ports (2) 3.5MM (FEMALE) Audio Ports Details Separate 3.5 mm mini stereo jacks for speakers and microphone DATA Data Ports (2) USB A (FEMALE) Data Ports Details (1) USB-A - USB 3.2 Gen 1 (5 Gbps) NETWORK Network Ports RJ45 (FEMALE) 2/5 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 Bus Powered No BATTERY Battery Charging (5V/1.5A Port) Yes POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.8A External Power Supply Output Specs (V / A) 5V / 4A External Power Supply Cord Length (ft.) 6 External Power Supply Cord Length (m.) 1.83 AC Adapter Input: 100-240V, 50/60 Hz, 0.8A; Output: 5V, 4A DC Barrel Plug OD: 4.75 x 1.7 x 9.5mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 4.5 USB Power Delivery (PD) Charging Support No USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Power), Green (USB) CHARGING Total Charging Watts 0 Charging Ports USB-A: 5V 1.5A (7.5W) Charging Ports / Amps 1.5A PHYSICAL Color Black Material of Construction ABS Shipping Dimensions (hwd / in.) 4.10 x 8.40 x 5.10 Shipping Dimensions (hwd / cm) 10.41 x 21.34 x 12.95 Shipping Weight (lbs.) 2.30 Shipping Weight (kg) 1.04 3/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / in.) 7.400 x 1.200 x 3.000 Unit Packaging Type Box Unit Weight (lbs.) 1.30 Unit Weight (kg) 0.59 ENVIRONMENTAL Operating Temperature Range 32 to 104°F (0 to 40°C) Storage Temperature Range 14 to 176°F (-10 to 80°C) Relative Humidity 0% to 90 RH, Non-Condensing BTUs 15.4 BTU/Hr Power Provided to Connected Device(s) USB BC 1.2: 5V/1.5A (7.5W), USB 3.0-A: 5V/0.9A (4.5W), USB-A: 5V/0.5A (2.5W) COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3az CONNECTIONS Number of Ports 13 Dock Connectors (2) 3.5mm, (2) USB-A 3.0, (4) USB-A 2.0, RJ45, HDMI, DVI-I Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 (2) USB 3.0 A (FEMALE) Side B - Connector 3 DVI-I (FEMALE) Side B - Connector 4 RJ45 (FEMALE) Side B - Connector 5 (4) USB A (FEMALE) Side B - Connector 6 (2) 3.5MM (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS HDCP Specification 1.3 USB Hub Ports Yes Number of USB Hub Ports 6 USB Specification USB 2.0 (up to 480 Mbps); USB 3.0 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) Driver Required Yes Recommended Category Cable Cat5/Cat5e/Cat6 Cables UASP Support No 4/5 1000 Eaton Boulevard Cleveland, OH 44122 United States Auto MDIX Support Yes Full Duplex Support Yes Suspend Mode Support No Remote Wakeup Support Yes Ethernet Support Yes STANDARDS & COMPLIANCE External Power Supply Certifications FCC; UL; RoHS Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 5/5
U342-DHG-402 价格&库存
很抱歉,暂时无法提供与“U342-DHG-402”相匹配的价格&库存,您可以联系我们找货
