U342-SHG-001
U342-SHG-001
    TRIPPLITE
    USB3.0TODISPLAYPORTVIDADAPT
U342-SHG-001 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 3.0 SuperSpeed HDMI / VGA Mini Dock, GbE Highlights ● Connect an external HDMI or VGA monitor to your laptop ● Adds a USB 3.0 and Gigabit Ethernet port to your laptop ● Compact design is perfect for travel, fitting easily into a laptop bag pocket MODEL NUMBER: U342-SHG-001 System Requirements ● Supports computers running Windows® XP, Vista, 7, 8, 8.1, 10 ● Supports Surface™ tablets running non-RT Windows 8 or 8.1 ● USB port (USB 3.0 port required for USB 3.0 speeds) ● DVI*, HDMI or VGA monitor ● Compatible with Windows 7 and later and Intel Mac OS X 10.8.5 / Mac 10.11 and later. Supports both 32- and 64-bit. Add USB 3.0, HDMI or VGA, and LAN ports to your laptop through a single USB 3.0 connection Description Universal USB dock adds HDMI, VGA, Gigabit Ethernet and a USB port to your computer, laptop or other device with a USB-A port. The USB-A port supports USB 3.2 Gen 1 speeds up to 5 Gbps, which is 10 times faster than USB 2.0. The USB docking station features two independent external monitor outputs (HDMI, VGA) that can be separately used to expand or mirror your computer's main desktop. The HDMI output supports video resolutions up to 2048 x 1152 at 60 Hz, including 1080p, while the VGA (VGA) port supports 1920 x 1200 at 60 Hz (1080p). Only one monitor may be used at a time. A DVI monitor can be connected to the HDMI port via an HDMI-to-DVI adapter (sold separately) An all-in-one solution, the U342-SHG-001 also features an RJ45 port for connecting to a Gigabit Ethernet network. The USB mini dock supports true 10/100/1000 Mbps (1 Gbps) Gigabit Ethernet speeds. The U342-SHG-001 with built-in USB cable is an ideal accessory for enhancing laptop capability for users who need to connect and manage multiple devices at home or at the office. Compatible with Windows computers and select Surface tablets. Features ● Add a VGA or HDMI monitor, USB 3.2 Gen 1 port and Gigabit Ethernet to your laptop ● Portable design with built-in cable is perfect for travel, tucking into your laptop bag when not in use ● Bus powered...no external power adapter required ● USB 3.2 Gen 1 is 10 times faster than USB 2.0, supporting data transfer rates up to 5 Gbps ● Backward compatible with USB 2.0 and 1.1 ● Connect a DVI*, HDMI or VGA monitor or projector ● HDMI port supports video resolutions up to 2048 x 1152 @ 60 Hz ● VGA (VGA) port supports video resolutions up to 1920 x 1200 @ 60 Hz ● Automatically resumes from hibernation and suspend modes ● Gigabit Ethernet port supports true 10/100/1000 Mbps (1 Gbps) network speeds ● USB 3.2 Gen 1 port is available for the connection of a USB peripheral device * Requires an HDMI to DVI adapter, such as Tripp Lite’s P566-Series cables 1/4 *Requires an HDMI to DVI adapter, such as Tripp Lite's P566-Series cables Package Includes ● U342-SHG-001 ● Driver CD ● Owner’s Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332185341 Product Type Docking Station Technology Cat5/5e; Cat6; HDMI; VGA/SVGA Host Connector USB A (MALE) VIDEO Number of Monitors Supported 1 Video Ports HDMI (FEMALE); HD15 (FEMALE) Video Ports Details HDMI 1.3; HDCP 1.3 Resolutions Supported HDMI supports 2048 x 1152 @60Hz, VGA support 1920 x 1200 @60Hz Max Supported Video Resolution 2048 x 1152 @60Hz Extended Mode No Mirror Mode No HDR Support No DATA Data Ports USB A (FEMALE) Data Ports Details USB-A - USB 3.2 Gen 1 (5 Gbps) NETWORK Network Ports RJ45 (FEMALE) INPUT Bus Powered Yes Product Length (in.) 5.00 BATTERY Battery Charging (5V/1.5A Port) No POWER Power Consumption (Watts) 4.5 USB Power Delivery (PD) Charging Support No 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (Link); Yellow (Activity) CHARGING Total Charging Watts 0 PHYSICAL Color Black Material of Construction Polycarbonate, ABS Cable Jacket Rating VW-1 Shipping Dimensions (hwd / in.) 1.60 x 6.50 x 5.40 Shipping Dimensions (hwd / cm) 4.06 x 16.51 x 13.72 Shipping Weight (lbs.) 0.40 Shipping Weight (kg) 0.18 Unit Dimensions (hwd / in.) 0.688 x 4.875 x 2.125 Unit Packaging Type Box Unit Weight (lbs.) 0.41 Unit Weight (kg) 0.19 ENVIRONMENTAL Operating Temperature Range 50 to 104°F (10 to 40°C) Storage Temperature Range -4 to 158°F (-20 to 70°C) Relative Humidity 0% to 90 RH, Non-Condensing BTUs 15.4 BTU/Hr Power Provided to Connected Device(s) USB-A: 5V/0.9A (4.5W) COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) IEEE Standards Supported 802.3az CONNECTIONS Number of Ports 4 Dock Connectors USB-A 3.0, HDMI, VGA, RJ45 Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 USB 3.0 A (FEMALE) 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Side B - Connector 3 HD15 (FEMALE) Side B - Connector 4 RJ45 (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS HDCP Specification 1.3 USB Hub Ports Yes Number of USB Hub Ports 1 USB Specification USB 3.0 (up to 5 Gbps); USB 3.2 Gen 1 (up to 5 Gbps) Driver Required Yes Recommended Category Cable Cat5/Cat5e/Cat6 Cables UASP Support No Auto MDIX Support Yes Full Duplex Support Yes Suspend Mode Support Yes Remote Wakeup Support Yes Ethernet Support Yes STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U342-SHG-001
物料型号:U342-SHG-001
器件简介: - 该设备是一个USB 3.0超级速度HDMI/VGA迷你扩展坞,可以连接外部HDMI或VGA显示器到笔记本电脑。 - 它还增加了一个USB 3.0和千兆以太网端口到笔记本电脑。 - 设计紧凑,适合旅行,可以轻松放入笔记本电脑包的口袋。
引脚分配: - 主机连接器:USB A(公) - 视频端口:HDMI(母);HD15(母) - 数据端口:USB A(母) - 网络端口:RJ45(母)
参数特性: - 支持的显示器数量:1 - 视频端口细节:HDMI 1.3;HDCP 1.3 - 支持的分辨率:HDMI支持2048x1152 @60Hz,VGA支持1920x1200 @60Hz - 最大支持视频分辨率:2048x1152@60Hz - 数据端口细节:USB-A - USB 3.2 Gen 1(5 Gbps) - 网络端口:RJ45(母) - 输入:总线供电
功能详解: - 通过单个USB 3.0连接,将USB 3.0、HDMI或VGA、LAN端口添加到笔记本电脑。 - 支持USB 3.2 Gen 1速度,最高可达5 Gbps,比USB 2.0快10倍。 - HDMI端口支持视频分辨率高达2048 x 1152 @ 60 Hz,包括1080p。 - VGA端口支持1920 x 1200 @ 60 Hz(1080p)。 - RJ45端口支持真正的10/100/1000 Mbps(1 Gbps)网络速度。
应用信息: - 适用于需要在家中或办公室连接和管理多个设备的笔记本电脑用户。 - 兼容Windows电脑和部分Surface平板电脑。
封装信息: - 产品类型:Docking Station - 技术:Cat5/5e; Cat6; HDMI; VGA/SVGA - 产品长度:5.00英寸 - 电源消耗:4.5瓦特 - 网络兼容性:1 Gbps(千兆) - IEEE标准支持:802.3az
其他信息: - 产品符合RoHS、CE(欧洲)、REACH、FCC(美国)等标准。 - 提供3年有限保修期。
包装内包括: - U342-SHG-001 - 驱动光盘 - 用户手册
U342-SHG-001 价格&库存
很抱歉,暂时无法提供与“U342-SHG-001”相匹配的价格&库存,您可以联系我们找货
