S212-000
S212-000
    TRIPPLITE
    ADAPTER SCSI HD68F/50F
S212-000 数据手册
Internal SCSI Adapter (HD68F/50F Socket IDC) Highlights ● Adapters convert older SCSI devices to work with newer SCSI installations ● Perfect for upgrading mixed installations MODEL NUMBER: S212-000 System Requirements ● Any internal SCSI ribbon with HD68 connector needing conversion to accept a 50 position narrow device Package Includes ● Description Tripp Lite's internal adapters convert SCSI devices to work with SCSI installations perfect for upgrading mixed installations. It has HD68F and 50 socket IDC female connectors used to connect a 50-pin narrow drive to a wide internal ribbon cable. Ideal when needing to connect a narrow drive to an enclosure with wide internal cabling. With these adapters you can save the time and expense of buying new cables by simply adapting your existing ones to interface with the connector types found on many of the newer model SCSI installations. Features ● The adapter will adapt a 50pin device to a 68pin cable or connector ● All Tripp Lite SCSI products, regardless of the SCSI generation, meet the latest specifications of ANSI ● Tripp Lite offers a complete line of internal and external solutions for SCSI/RAID and fibre channel ranging from the very latest Ultra 320 to legacy SCSI-1 and every combination in between Specifications OVERVIEW UPC Code 037332013910 Technology Ribbon/Internal; SCSI PHYSICAL Color Black Shipping Dimensions (hwd / cm) 17.14 x 10.16 x 1.27 Shipping Dimensions (hwd / in.) 6.75 x 4.00 x 0.50 Shipping Weight (kg) 0.04 Shipping Weight (lbs.) 0.08 1/2 Internal SCSI Adapter 50PinF to HD68F CONNECTIONS Side A - Connector 1 HD68 (FEMALE) Side B - Connector 1 50 SOCKET IDC (FEMALE) WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
S212-000 价格&库存
很抱歉,暂时无法提供与“S212-000”相匹配的价格&库存,您可以联系我们找货
