USB / FireWire ® - USB 2.0 Bus Port PCI Card (5
port) for desktop PCs
Highlights
Adds up to 5 USB ports to
compatible computers
MODEL NUMBER: U234-005-R
Description
Fully USB 2.0 certified
Supports faster data transfer
Tripp Lite's Hi-speed USB 2.0 Certified PCI Card takes you to the next level of performance with an
astounding 480Mbps; much faster than the 1.1 cards and a bandwidth 40 times greater. Allows you to
transfer larger amounts of data from your USB 2.0 compliant products. This handy little card can be used
in such USB2.0 applications as video cameras, scanners, portable drives and much more! Can also be
used with older USB peripherals (non USB2.0 devices). Provides 5 ports (4 external and 1 internal) which
enables you to connect up to 127 devices at a time (requires the use of USB hubs to add ports).
Features
rate (1.5 to 480 Mbps) for low
speed and high speed devices,
including multimedia
applications
Card requires 32 bit 5V PCI
Retail Packaging
Supports high-speed data transfer rates-up to 480Mbps
USB 2.0 certified by the USB-IF
Unique internal port provides easier connection for an internal hard drive
Auto-detects device connection and device transfer rate
Fast, easy PCI card slot installation
Hot-swap, plug-and-play operation
Available PCI slot
Connect up to 127 USB devices to the PCI card when using optional USB hubs
Floppy disk drive for software
PCI-Bus power management interface specification revision 2.1 compliant
Windows® 98/98SE or higher
32-bit 33MHz host interface, PCI specification revision 2.2 compliant
Tripp Lite warrants this product to be free from defects in materials and workmanship for life
System Requirements
IBM® PC Pentium II 266MHz
CPU or higher or compatible
system
Specifications
OVERVIEW
UPC Code
037332100030
Technology
USB; USB 2.0 (High Speed)
PHYSICAL
Shipping Dimensions (hwd / cm)
15.24 x 22.22 x 3.81
Shipping Dimensions (hwd / in.)
6.00 x 8.75 x 1.50
Shipping Weight (kg)
0.25
Shipping Weight (lbs.)
0.55
CONNECTIONS
1/2
Package Includes
USB 2.0 PCI card
Driver on Floppy disk
User's Manual
Ports
5
Side A - Connector 1
(4) USB A (FEMALE)
WARRANTY
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2021 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U234-005-R”相匹配的价格&库存,您可以联系我们找货
