U280-004
U280-004
    TRIPPLITE
    4-PORTUSBCHARGINGSTATION,5V
U280-004 数据手册
4-Port USB Charging Station, 5V 6A/30W USB Charger Output MODEL NUMBER: U280-004 Highlights ● 5V, 2.4A per port for charging battery-intensive devices ● 5V, 1.5A per port simultaneously when at maximum capacity ● All four ports support USB Battery Charging (BC) specification v1.2 ● Internal dual-voltage power supply with NEMA 1-15P plug ● Protects against overheating, overcurrent and overcharging ● No computer required Package Includes Charges up to 4 electronic devices at the same time via USB connection. Ideal for quick-charging tablets, cell phones, laptops and other mobile devices. Description Whether you’re at home or in the office, Tripp Lite’s U280-004 4-Port USB Charging Station provides enough ports and power to keep your devices at 100% capacity. No more peering behind furniture to find an available outlet or unplugging one device to charge another. You can charge up to four tablets, cell phones, laptops and other devices at the same time. The U280-004 doesn’t require a computer, so you can take it anywhere AC power is available. The U280-004 simultaneously provides up to 5V, 1.5A of power per port at maximum capacity. Each individual port supports USB Battery Charging (BC) specification v1.2 and is capable of delivering up to 5V, 2.4A, which is enough for charging even battery-intensive devices like the Apple® iPad®. To charge your USB devices, simply connect the four-foot power cord’s NEMA 1-15P plug to an AC power outlet, and connect your devices to the available USB ports. The unit protects against overheating, overcurrent and overcharging—in fact, it stops charging as soon as your devices’ batteries are at full capacity. A front LED indicates the unit is turned on and receiving AC power. Features Charges Up to 4 Devices at the Same TimeIdeal for charging tablets, cell phones, laptops and other devices at home or workConnect devices to unit’s USB ports for proficient chargingFunctions anywhere AC power is available—no computer required Provides Plenty of Juice for ChargingEach individual port capable of delivering up to 5V, 2.4A, enough for charging battery-intensive devices like the Apple iPadSimultaneously provides up to 5V, 1.5A of power per port at maximum capacityAll four ports support USB Battery Charging (BC) specification v1.2Protects against overheating, overcurrent and overcharging Easy to Use4 ft. power cord with NEMA 1-15P plug connects to AC outletFront LED indicates when unit is turned on and receiving AC power Specifications 1/3 ● U280-004 4-Port USB Charging Station ● C7 to NEMA 1-15P power cord, 4 ft. ● Quick Start Guide OVERVIEW UPC Code 037332192073 Product Type Plug in Charger Charging Form Factor Charging Hub Device Compatibility Phone; Tablet; Amazon Kindle INPUT Nominal Input Voltage(s) Supported 120V AC; 230V AC Plug Type C7 to NEMA 1-15P Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Input Frequency 50/60Hz Input Plug Type NEMA 1-15P Input Current 120V (0.8A) / 230V (0.4A) OUTPUT Overload Protection Yes POWER Power Consumption (Watts) 38 Power Consumption Detail 38W (Operating) 0.26W (Standby) USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Power) CHARGING Number of Charging Ports 4 Total Charging Amps 6A Total Charging Watts 30 Charging Method USB Charging Port Type (4) USB A (FEMALE) Charging Ports Details USB-A: 5V 2.4A (12W)USB-A: 5V 1.5A (7.5W) when all ports are in use Charging Ports / Amps (4) 2.4A Charging Method Detail 5V - 1.5A (7W) PHYSICAL Color White Shipping Dimensions (hwd / in.) 2.00 x 5.30 x 7.30 2/3 Shipping Dimensions (hwd / cm) 5.08 x 13.46 x 18.54 Shipping Weight (lbs.) 1.00 Shipping Weight (kg) 0.45 Unit Dimensions (hwd / in.) 1.200 x 4.200 x 4.000 Unit Dimensions (hwd / cm) 3.1 x 10.6 x 10.1 Unit Packaging Type Box Unit Weight (lbs.) 0.46 Unit Weight (kg) 0.21 ENVIRONMENTAL Operating Temperature Range 41°F to 95°F / 5°C to 35°C Storage Temperature Range -4°F to 122°F / -20°C to 50°C Relative Humidity 20% to 80% RH, Non-Condensing CONNECTIONS Number of Ports 4 Side A - Connector 1 NEMA 1-15P (NON-POLARIZED) Side B - Connector 1 (4) USB A (FEMALE) FEATURES & SPECIFICATIONS Overcurrent Protection Yes Overvoltage Protection Yes GaN Technology No WARRANTY Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U280-004 价格&库存
很抱歉,暂时无法提供与“U280-004”相匹配的价格&库存,您可以联系我们找货
