76000654
76000654
    DIGIINTERNATIONAL
    POWER SUPPLY TS 1 120-240VAC
76000654 数据手册
AC Power Supply - 12VDC. IEC320C14 to 2.1mm non-locking barrel plug. Compatibility: Digi Connect WAN (legacy, non-locking power cord models). PART NUMBERS North America: 76000654 International: 76000654 Input Specifications: Rated input voltage range: 100VAC - 240VAC Input frequency: 47Hz - 63Hz Rated input current: < 0.6A Max. in-rush current: < 40A Input Plug Type: IEC320 /C14 /3Pin Output Specifications: Output Voltage: 12VDC Output current: 1.5A Output Power: 18W Output Plug: Connector Type: Straight female barrel Outer Diameter: 5.5mm Inner Diameter: 2.1mm Environment: Operating Temperature: 0° C to 40° C Storage Temperature: -40° C to 80° C Dimensions: Size (LxHxW): 80.5 x 30 x 50mm Weight: 166g Cord Length: 1830mm Certifications: UL, CSA, TUV, CE, T-Mark Contact a Digi expert and get started today! CONTACT US http://www.digi.com/products/model?mid=2265 5/27/2015
76000654 价格&库存
很抱歉,暂时无法提供与“76000654”相匹配的价格&库存,您可以联系我们找货
