P167-000
P167-000
    TRIPPLITE
    CAT6WALLPLATEEXTENDERKIT
P167-000 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDMI over Dual Cat5/Cat6 Extender Wall Plate Kit with Transmitter and Receiver, TAA Highlights ● Extends a 1080p (24Hz) or 1080i (60Hz) signal up to 150-ft. (45.72 m) using 24Awg, Solid Wire Cat6* cabling (Tripp Lite N222-Series, or N224-Series ) ● Extends a 3D signal up to 100ft. (30.5 m) using 24Awg, Solid Wire Cat6 cabling ● Supports 24-bit True Color (8bits per channel) ● Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound Audio ● Supports HDCP, EDID and DDC ● No external power required MODEL NUMBER: P167-000 Package Includes Description Tripp Lite's HDMI Over Dual Cat5 Extender Wallplate Kit is the perfect solution for those who need to extend a HDMI signal over a long distance over two Cat5/6 cables. ● When using 24Awg, Solid Wire Cat6 cable, a 1080p (24Hz) or 1080i (60Hz) signal can be extended up to 150 ft. from the source. ● When using 24Awg, Solid Wire Cat6 cable, a 3D signal can be extended up to 100-ft. (30.5 m) ● When using 24Awg, Solid Wire Cat5 cable, a 1080p (24Hz) or 1080i (60Hz) signal can be extended up to 100-ft. (30.5 m) from the source. ● When using 24Awg, Solid Wire Cat5 cable, a 3D signal can be extended up to 50 ft. Simply run two Cat5/6 cables between the local transmitter and remote receiver wallplates, and plug in standard Tripp Lite HDMI cables to the HDMI source and the display. The Green LED on the remote receiver wallplate lets you know that power from the source and monitor. When functioning properly, only the Green LED will be lit. If the Red LED is illuminated, it means that the remote receiver is not receiving a functional signal from the source. The P167-000 comes with both local transmitter and remote receiver wallplates. DTS-HD, Dolby True HD and 7.1 Channel Surround Sound audio are supported, and it is compliant with HDCP, EDID and DDC. 24-bit True Color (8-bits per channel) is supported. No external power is required. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features ● Extends a 1080p (24Hz) or 1080i (60Hz) signal up to 150 ft. using 24Awg, Solid Wire Cat6* cabling (Tripp Lite N222-Series, or N224-Series ) ● Extends a 1080p (24Hz) or 1080i (60Hz) signal up to 100-ft. (30.5 m) using 24Awg, Solid Wire Cat5 cabling ● Extends a 3D signal up to 100-ft. (30.5 m) using 24Awg, Solid Wire Cat6 cabling, or up to 50 ft. using 24Awg, Solid Wire Cat5 cabling ● Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound Audio ● Supports HDCP, EDID and DDC ● Supports 24-bit True Color (8-bits per channel) ● No external power required ● Use Tripp Lite P568-Series HDMI cables from wallplates to devices 1/4 ● Local Transmitter and Remote Receiver Wallplates ● 110 Punchdown Tool ● (x4) Wallplate Screws ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332143730 Product Type Extender Kit Accessory Type Wall Plate Technology HDMI PRODUCT OVERVIEW Product Overview HDMI Over Cat5/6 Wallplate Extender Kit VIDEO Max Supported Video Resolution 1920x1080 (1080p @ 60Hz) Max 1280 x 720 (720p) Range (ft) 197 Max 1920 x 1080 (1080p) Range (ft) 147 Transmitter Video Input HDMI Receiver/Transceiver Video Output HDMI Receiver - Number of Video Outputs 1 Recommended Cabling Solid Wire Cat6 Cables (Tripp Lite's N202-Series) HDR Support No 3D Video Supported Yes Maximum Signal Range (ft) 230 Maximum Signal Range (m) 70 Maximum Signal Range Details 230 ft via Cat6 @ 480p197 ft via Cat6 @ 720p147 ft via Cat6 @ 1080p AUDIO Audio Input HDMI Audio Output HDMI Audio Specification Stereo Audio INPUT Bus Powered No POWER Power Over Cable (PoC) Support No 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color White Number of Displays 1 Form Factor/Mounting Options Wallplate Receiver Unit Dimensions (hwd / in.) 1.5 x 4.5 x 2.8 Receiver Unit Weight (lbs.) 0.2 Shipping Dimensions (hwd / in.) 1.70 x 7.90 x 5.60 Shipping Dimensions (hwd / cm) 4.32 x 20.07 x 14.22 Shipping Weight (lbs.) 0.55 Shipping Weight (kg) 0.25 Transmitter Unit Dimensions (hwd / in.) 1.5 x 4.5 x 2.8 Transmitter Unit Weight (lbs.) 0.2 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Housing Plastic ENVIRONMENTAL Operating Temperature Range 32 to 104°F (0 to 40°C) Storage Temperature Range 5 to 122°F (-15 to 50°C) Relative Humidity 0% to 85% RH, Non-Condensing COMMUNICATIONS EDID Compatible Yes IR Remote Extension Support No RS-232 Serial Extension Support No Consumer Electronics Control (CEC) Supported Yes USB Extension Support No CONNECTIONS Side A - Connector 1 HDMI (FEMALE) Side B - Connector 1 HDMI (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.3 Driver Required No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States 10/100 Ethernet Extension Support No Built-In Equalizer No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
P167-000 价格&库存
很抱歉,暂时无法提供与“P167-000”相匹配的价格&库存,您可以联系我们找货
