Mini External USB Stereo Speaker
PROUCT ID: 3369
Description
Add some crisp and compact audio to your project with this Mini External USB 2.0 Speaker. It's USBonly and does not require or use a 3.5mm audio jack. You'll get great audio, even with a device that doesn't
have a head phone jack. And since it is powered over USB, there's no need to charge it by other means,
merely plug it into your desired device's USB port and listen to the audio flow. Compact and convenient to
carry, it's simple and practical. With 2 built-in speakers and no battery or adapter needed, this plug-andplay speaker is perfect if you need a quick and portable audio solution.
Works great with a Raspberry Pi, or any other computer. For use with the Pi, check out our guide which
will show you how to set it up so it is the default output and then test it.
https://cdn-learn.adafruit.com/downloads/pdf/usb-audio-cards-with-a-raspberry-pi.pdf
Goes great with our USB microphone, if you want your own recording and playback setup.
Technical Details
o
o
o
o
Voltage: 5V
Total power: 2 x 2W
SNR: 60dB
Impedance: 4 ohm
Cable Length: 1,168mm / 46"
Product Dimensions: 84.0mm x 43.0mm x 32.0mm / 3.3" x 1.7" x 1.3"
Product Weight: 73.6g / 2.6oz
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3369”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+109.892181+14.28563
