U357-025-UASP
U357-025-UASP
    TRIPPLITE
    ENCLOSURE2.5"SATAHARDDRIVE
U357-025-UASP 数据手册
USB 3.0 SuperSpeed External 2.5 in. SATA Hard Drive Enclosure with Built-In Cable and UASP Support Highlights ● Supports USB 3.0 data transfer rates up to 5 Gbps ● Works up to 70% faster when connected to UASP host controller ● Compatible with 2.5 in. SATA HDDs and SSDs up to 3 TB ● Protective cover keeps SATA drive free of dust ● Requires no software, drivers or external power supply MODEL NUMBER: U357-025-UASP System Requirements ● Device with USB port (USB 3.0 required for USB 3.0 speeds) ● UASP-enabled host controller required for UASP performance ● 2.5 in. SATA HDD or SSD with 9.5 mm maximum height Package Includes Connects a 2.5 in. SATA hard disk drive or solid state drive to your laptop, netbook or notebook computer’s USB port for extra storage and fast data transfer. UASP enabled for 70% more speed with UASP host controller. Description The U357-025-UASP USB 3.0 SuperSpeed External 2.5 in. SATA Hard Drive Enclosure is a quick, easy way to connect a SATA HDD (Hard Disk Drive) or SSD (Solid State Drive) to your laptop, netbook or notebook’s USB port. Not only does it support USB 3.0 data transfer rates up to 5 Gbps, but its UASP (USB Attached SCSI Protocol) feature reduces latency and allows it to perform up to 70% faster when connected to a UASP-enabled host controller. Perfect for storing and sharing large files like photos, music and video files, the enclosure is compatible with 2.5-inch SATA drives up to 3 TB. Just insert the drive into the SATA connector, connect the included one-foot USB 3.0 Micro-B cable to your computer, and slide the protective cover over the drive, even when it’s in use, to keep it dust-free at all times. The U357-025-UASP accepts SATA III (6 Gbps), SATA II (3 Gbps) and SATA I (1.5 Gbps) drives, as well as USB 2.0 (480 Mbps) and USB 1.1 (12 Mbps) transfer speeds. A blue LED flashes to indicate data transfer is occurring. After thirty minutes of inactivity, the enclosure goes into hibernation mode and wakes up when activity resumes. No software, drivers or external power supply is required. Compatible with Windows, Mac and Linux. Features Quickly Connects a SATA Drive to Your Computer’s USB Port ● Ideal for storing large files like photos, music and video files and sharing them on your laptop, netbook or notebook ● Supports USB 3.0 data transfer rates up to 5 Gbps ● Features UASP (USB Attached SCSI Protocol) for performance up to 70% faster when connected to UASP-enabled host controller ● Hibernates after 30 minutes of inactivity ● Compatible with Windows, Mac and Linux Compatible with 2.5 in. SATA Drives Up to 3 TB ● Accepts SATA III (6 Gbps), SATA II (3 Gbps) and SATA I (1.5 Gbps) drives 1/3 ● U357-025-UASP USB 3.0 SuperSpeed External 2.5 in. SATA Hard Drive Enclosure ● USB 3.0 Micro-B cable, 1 ft. ● Owner’s manual ● Backward compatible with USB 2.0 (480 Mbps) and USB 1.1 (12 Mbps) transfer speeds ● Works with both HDDs (Hard Disk Drives) and SSDs (Solid State Drives) Easy to Use Right from the Box ● Plug and play—no software, drivers or external power supply needed ● SATA drive slides easily into convenient slot ● Protective cover keeps dust and dirt away from sensitive SATA drives ● Blue LED indicates successful data transfer ● 1 ft. USB 3.0 Micro-B cable included Specifications OVERVIEW UPC Code 037332190000 Drives Supported 2.5" HDD and SSD Technology SATA/eSATA INPUT Bus Powered Yes POWER Power Consumption (Watts) 5.00 USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Read, Write, Power) PHYSICAL Material of Construction ABS Color Black Cable Jacket Color Black Cable Length (ft.) 0.2 Cable Length (m) 0.06 Shipping Dimensions (hwd / cm) 4.80 x 18.11 x 12.80 Shipping Dimensions (hwd / in.) 1.89 x 7.13 x 5.04 Shipping Weight (kg) 0.18 Shipping Weight (lbs.) 0.40 Unit Dimensions (hwd / in.) 0.57 x 4.8 x 3.1 Unit Dimensions (hwd / cm) 1.5 x 12.1 x 7.8 2/3 Unit Packaging Type Box Unit Weight (lbs.) 0.11 Unit Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 50 to 122 F (10 to 50 C) Storage Temperature Range 32 to 149 F (0 to 65 C) Relative Humidity 10% to 80% RH, Non-Condensing BTUs 17.1 BTU/Hr CONNECTIONS Number of Ports 1 Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 22 PIN SATA + POWER (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No UASP Support Yes IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U357-025-UASP 价格&库存
很抱歉,暂时无法提供与“U357-025-UASP”相匹配的价格&库存,您可以联系我们找货
