U280-004-UK
U280-004-UK
    TRIPPLITE
    4-PORTUSBCHARGINGSTATION,5V
U280-004-UK 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port USB Charging Station, 5V 6A/30W USB Charger Output, UK Version MODEL NUMBER: U280-004-UK Highlights ● 5V, 2.4A per port for charging battery-intensive devices ● 5V, 1.5A per port simultaneously when at maximum capacity ● All four ports support USB Battery Charging (BC) specification v1.2 ● Internal dual-voltage power supply with BS-1363 plug ● Protects against overheating, overcurrent and overcharging ● No computer required Package Includes Charges up to 4 electronic devices at the same time via USB connection. Ideal for quick-charging tablets, cell phones, laptops and other mobile devices. Description Whether you’re at home or in the office, Tripp Lite’s U280-004-UK 4-Port USB Charging Station provides enough ports and power to keep your devices at 100% capacity. No more peering behind furniture to find an available outlet or unplugging one device to charge another. You can charge up to four tablets, cell phones, laptops and other devices at the same time. The U280-004-UK doesn’t require a computer, so you can take it anywhere AC power is available. The U280-004-UK simultaneously provides up to 5V, 1.5A of power per port at maximum capacity. Each individual port supports USB Battery Charging (BC) v1.2 and is capable of delivering up to 5V, 2.4A, which is enough for charging even battery-intensive devices like the Apple® iPad®. To charge your USB devices, simply connect the 1.2-meter power cord’s BS-1363 plug to an AC power outlet, and connect your devices to the available USB ports. The unit protects against overheating, overcurrent and overcharging—in fact, it stops charging as soon as your devices’ batteries are at full capacity. A front LED indicates the unit is turned on and receiving AC power. Features Charges Up to 4 Devices at the Same TimeIdeal for charging tablets, cell phones, laptops and other devices at home or workConnect devices to unit’s USB ports for proficient chargingFunctions anywhere AC power is available—no computer required Provides Plenty of Juice for ChargingEach individual port supports USB Battery Charging (BC) v1.2 and is capable of delivering up to 5V, 2.4A, enough for charging battery-intensive devices like the Apple iPadSimultaneously provides up to 5V, 1.5A of power per port at maximum capacityProtects against overheating, overcurrent and overcharging Easy to Use1.2 m power cord with BS-1363 plug connects to AC outletFront LED indicates when unit is turned on and receiving AC power Specifications OVERVIEW 1/3 ● U280-004-UK 4-Port USB Charging Station ● C7 to BS-1363 power cord, 1.2 m ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332192080 Product Type Plug in Charger Charging Form Factor Charging Hub Device Compatibility Phone; Tablet; Amazon Kindle INPUT Nominal Input Voltage(s) Supported 120V AC; 230V AC Plug Type C7 to BS-1363 Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Input Frequency 50/60Hz Input Plug Type NEMA 1-15P (NON-POLARIZED) Input Current 120V (0.8A) / 230V (0.4A) OUTPUT Overload Protection Yes POWER Power Consumption (Watts) 38 Power Consumption Detail 38W (Operating) 0.26W (Standby) USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Power) CHARGING Number of Charging Ports 4 Total Charging Amps 6A Total Charging Watts 30 Charging Method USB Charging Port Type (4) USB A (FEMALE) Charging Ports Details USB-A: 5V/6A Charging Ports / Amps (4) 2.4A Charging Method Detail 5V - 1.5A (7W) PHYSICAL Color White Shipping Dimensions (hwd / in.) 2.00 x 5.20 x 7.30 Shipping Dimensions (hwd / cm) 5.08 x 13.21 x 18.54 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 0.87 Shipping Weight (kg) 0.39 Unit Dimensions (hwd / in.) 1.200 x 4.200 x 4.000 Unit Dimensions (hwd / cm) 3.1 x 10.6 x 10.1 Unit Packaging Type Box Unit Weight (lbs.) 0.46 Unit Weight (kg) 0.21 ENVIRONMENTAL Operating Temperature Range 41°F to 95°F / 5°C to 35°C Storage Temperature Range -4°F to 122°F / -20°C to 50°C Relative Humidity 20% to 80% RH, Non-Condensing CONNECTIONS Number of Ports 4 Side A - Connector 1 BS1363 UK PLUG Side B - Connector 1 (4) USB A (FEMALE) FEATURES & SPECIFICATIONS IP68 Rated No Overcurrent Protection Yes Overvoltage Protection Yes GaN Technology No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U280-004-UK 价格&库存
很抱歉,暂时无法提供与“U280-004-UK”相匹配的价格&库存,您可以联系我们找货
