P936-000
P936-000
    TRIPPLITE
    SATADRIVECONTCONVE40PIN
P936-000 数据手册
40 Pin F IDE to Serial ATA (SATA) Drive Adapter Converter MODEL NUMBER: P936-000 Highlights ● Convert existing IDE Drives to a SATA Controller ● Serial ATA (SATA) Data & Power Cable Included System Requirements ● Supports any operating system when a PC with available IDE hard disk and SATA controller are used Package Includes Description Tripp Lites P936-000, Serial ATA (SATA) to IDE converter, allows a standard parallel ATA hard disk drive, CD-ROM, CD-RW, DVD ROM, DVD + RW, etc, to be used with Serial ATA Controller cards or motherboards with Serial ATA ports, and meets the specification of Serial ATA 1.0 interface. Simply plug the 40-pin side of the adapter into the IDE drive 40-pin connector, and attach power and SATA cables to the appropriate connections...no software to load. Features ● Easily connect IDE/ATA Drives to a SATA Controller ● Compliance with Serial ATA Gen 1.0. ● Master/slave device emulation support. ● Supports PIO mode 0~4. ● Supports Ultra DMA mode 0~7. ● Supports UDMA data transfer rates of up to 150MBps ● Supports ATAPI Packet command set. ● Supports 48-bit LBA addressing. ● Supports additional ATA command for serial ATA SCR access. ● Serial ATA power save mode supported ● Serial ATA BIST operation. ● Supports hot-plugging Specifications OVERVIEW UPC Code 037332152053 Technology SATA/eSATA; Ribbon/Internal 1/2 ● Serial ATA to IDE Converter x 1 ● Serial ATA Cable x 1 ● Power supply cable x 1 ● User's Manual x 1 PHYSICAL Color Black Shipping Dimensions (hwd / in.) 7.00 x 5.50 x 1.25 Shipping Dimensions (hwd / cm) 17.78 x 13.97 x 3.18 Shipping Weight (lbs.) 0.17 Shipping Weight (kg) 0.08 CONNECTIONS Side A - Connector 1 IDE 40PIN SOCKET Side B - Connector 1 7 PIN SATA (MALE) Side B - Connector 2 LP4 (FEMALE) Side B - Connector 3 LP4 (MALE) WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P936-000 价格&库存
很抱歉,暂时无法提供与“P936-000”相匹配的价格&库存,您可以联系我们找货
