U338-06N-SATA-B
U338-06N-SATA-B
    TRIPPLITE
    USB3.0SUPERSPEEDTOSATAIIIA
U338-06N-SATA-B 数据手册
USB 3.0 SuperSpeed to SATA III Adapter Cable with UASP, 2.5 in. SATA Hard Drives, Black MODEL NUMBER: U338-06N-SATA-B Highlights ● Supports USB 3.0 data transfer rates up to 5 Gbps ● Works up to 70% faster when connected to UASP host controller ● Compatible with SATA HDDs and SSDs up to 4 TB ● Plug-and-play—no external power supply required ● Compatible with all USBenabled operating systems System Requirements ● Any USB-enabled operating system ● Available USB port (USB 3.0 required to achieve USB 3.0 speeds) ● 2.5 in. SATA drive ● UASP-enabled host controller required for UASP performance Connects a 2.5 in. SATA HDD or SSD to your laptop or computer’s USB port for extra storage, quick disk formatting and fast data transfer. Package Includes Description ● The U338-06N-SATA-B USB 3.0 SuperSpeed to SATA III Adapter Cable connects a 2.5-inch SATA hard disk drive (HDD) or solid state drive (SSD) to an available USB port on your laptop or computer. This lets you back up important data, retrieve data from an old hard drive, or store information on an external drive that you can take with you to another computer. This adapter cable supports USB 3.0 data transfer rates up to 5 Gbps. Its UASP (USB Attached SCSI Protocol) feature reduces latency and allows the cable to perform up to 70% faster when connected to a UASP-enabled host controller. Perfect for storing and sharing large files, such as music and video files, the U338-06N-SATA-B is compatible with SATA drives up to 4 TB. Just insert the drive into the 22-pin SATA connector, and attach the built-in USB 3.0 cable to your computer. The U338-06N-SATA-B accepts SATA III (6 Gbps), SATA II (3 Gbps) and SATA I (1.5 Gbps) drives, as well as USB 2.0 (480 Mbps) and USB 1.1 (12 Mbps) transfer speeds. It supports LBA-48 bit (Logical Block Addressing) and USB Mass Storage Class Bulk-Only Transport. No software, drivers or external power supply is required. Compatible with all USB-enabled operating systems. Features Quickly Connects a SATA Drive to Your Computer’s USB Port ● Recommended for backing up, retrieving and storing large data files ● Supports USB 3.0 data transfer rates up to 5 Gbps ● Features UASP for performance up to 70% faster when connected to UASP-enabled host controller Compatible with 2.5 in. SATA HDDs and SSDs Up to 4 TB ● Accepts SATA III, SATA II and SATA I drives ● Backward compatible with previous USB generations ● Supports LBA-48 bit and USB Mass Storage Class Bulk-Only Transport Easy to Use ● Plug-and-play—no software, drivers or external power supply needed 1/3 U338-06N-SATA-B USB 3.0 SuperSpeed to SATA III Adapter Cable, Black ● Compatible with all USB-enabled operating systems Specifications OVERVIEW UPC Code 037332199287 Technology SATA/eSATA INPUT Bus Powered Yes Product Length (in.) 6 POWER Power Consumption (Watts) 5 USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Read, Write, Power) PHYSICAL Material of Construction ABS Color Black Cable Jacket Color Black Cable Jacket Rating VW-1 Shipping Dimensions (hwd / cm) 18.03 x 10.92 x 1.27 Shipping Dimensions (hwd / in.) 7.10 x 4.30 x 0.50 Shipping Weight (kg) 0.03 Shipping Weight (lbs.) 0.06 Unit Dimensions (hwd / in.) 0.5 x 2.8 x 0.71 Unit Dimensions (hwd / cm) 1.3 x 7.1 x 1.8 Unit Packaging Type Polybag Unit Weight (lbs.) 0.05 Unit Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range 50 to 122 F (10 to 50 C) Storage Temperature Range 32 to 149 F (0 to 65 C) Relative Humidity 10% to 80% RH, Non-Condensing 2/3 BTUs 17.1 BTU/Hr CONNECTIONS Number of Ports 1 Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 22 PIN SATA + POWER (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No UASP Support Yes IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U338-06N-SATA-B
物料型号:U338-06N-SATA-B
器件简介:该适配器电缆可以将2.5英寸SATA硬盘驱动器(HDD)或固态驱动器(SSD)连接到笔记本电脑或计算机的USB端口,用于额外存储、快速磁盘格式化和快速数据传输。
引脚分配:22针SATA连接器。
参数特性: - 支持USB 3.0数据传输速率高达5Gbps。 - 支持UASP(USB Attached SCSI Protocol),连接到UASP启用的主机控制器时,性能可提高70%。 - 兼容SATA III(6Gbps)、SATA II(3Gbps)和SATA I(1.5Gbps)驱动器。 - 支持LBA-48位和USB大容量存储类Bulk-Only传输。 - 不需要软件、驱动程序或外部电源。
功能详解: - 快速将SATA驱动器连接到计算机的USB端口。 - 推荐用于备份、检索和存储大型数据文件。 - 支持USB 3.0数据传输速率高达5Gbps。 - 兼容2.5英寸SATA HDD和SSD,最大4TB。 - 向后兼容以前的USB版本。
应用信息:适用于存储和共享大型文件,如音乐和视频文件。
封装信息:黑色,ABS材料,电缆外皮颜色为黑色,电缆外皮等级为三VW-1。
系统要求:任何USB启用的操作系统,可用的USB端口(需要USB 3.0以实现USB 3.0速度),2.5英寸SATA驱动器,UASP启用的主机控制器以实现UASP性能。
包装包括:U338-06N-SATA-B USB 3.0 SuperSpeed到SATA III适配器电缆,黑色。
易用性:即插即用,无需软件、驱动程序或外部电源。
规格参数: - UPC代码:037332199287 - 技术:SATA/eSATA - 总线供电:是 - 产品长度(英寸):6 - 功耗(瓦特):5 - LED指示灯:蓝色(读、写、电源) - 材料:ABS - 颜色:黑色 - 电缆外皮等级:三VW-1 - 发货尺寸(高宽深/厘米):18.03x10.92x1.27 - 发货重量(公斤):0.03 - 发货重量(磅):0.06 - 工作温度范围:50至122华氏度(10至50摄氏度) - 存储温度范围:32至149华氏度(0至65摄氏度) - 相对湿度:10%至80% RH,非凝结
连接信息: - 端口数量:1 - 侧面A -连接器1:USB3.0 A(公) - 侧面B -连接器1:22针SATA +电源(母) - 连接器镀层:镍
特性和规格: - USB规范:USB 3.0(高达5Gbps); USB 3.1 Gen 1(高达5Gbps) - 需要驱动程序:否 - UASP支持:是
标准和合规性: - 产品合规性:RoHS; CE(欧洲); REACH; FCC(美国) - 保修期:3年有限保修
U338-06N-SATA-B 价格&库存
很抱歉,暂时无法提供与“U338-06N-SATA-B”相匹配的价格&库存,您可以联系我们找货
