EZA-VGAM-2
EZA-VGAM-2
    TRIPPLITE
    TYPEACONNM/MRGBVGACABLE
EZA-VGAM-2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Easy Pull Type-A Connectors - M/M set of VGA Highlights ● SVGA Connector Kit includes: Male to Male HD15 1-ft. (0.31 m) pigtail cables ● Versatile trunk cable allows for a variety of connection options ● High quality RGB style VGA cable supports resolutions up to 1600 x 1200 ● Works in tandem with Tripp Lite's EZA-Series Cables MODEL NUMBER: EZA-VGAM-2 Package Includes ● Description Easy Pull Connector Kit includes: 2 x HD15 Male 1-ft. (0.31 m) pigtail cable. Completes your Easy Pull trunk run with a finished appearance. Video support up to 1600 x 1200. Use with either PVC or Plenum trunk cables. Features ● Eliminates the need to field terminate VGA connectors ● Wall plate with HD15 cut-out cleanly finish off the cable run ● Allows cable to be run according to code - inside conduit, drop ceilings, etc. ● Makes pulling long cables fast and easy ● Trunk cables available in 35-ft. (10.67 m), 50-ft. (15.24 m) and 100-ft. (30.5 m) PVC lengths, and 35-ft. (10.67 m) and 50-ft. (15.24 m) Plenum jackets ● High quality RGB style VGA cable supports resolutions up to 1600 x 1200 Specifications OVERVIEW UPC Code 037332142016 Product Type Passive Technology VGA/SVGA PHYSICAL Color Black; Green Cable Length (ft.) 1 Cable Length (m) 0.30 1/2 2 x HD15 Male 1-ft. (0.31 m) pigtail cable 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 0.25 x 1.00 x 12.00 Shipping Dimensions (hwd / cm) 0.64 x 2.54 x 30.48 Shipping Weight (lbs.) 0.40 Shipping Weight (kg) 0.18 CONNECTIONS Side A - Connector 1 HD15 (MALE) Side A - Connector 2 DIN 14 PIN (FEMALE) Side B - Connector 1 HD15 (MALE) Side B - Connector 2 DIN 14 PIN (FEMALE) Latching or Gripping Connector No FEATURES & SPECIFICATIONS IP68 Rated No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
EZA-VGAM-2 价格&库存
很抱歉,暂时无法提供与“EZA-VGAM-2”相匹配的价格&库存,您可以联系我们找货
