ZX360D1-B-CN-10P
ZX360D1-B-CN-10P
    HRS(广濑)
ZX360D1-B-CN-10P 数据手册
USB3.0 Micro-B Connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ZX360 Series (Note) Please contact us for TID acquisition status of each product. ■General The ZX360 Series is a Micro-USB connector that is compliant with the MicroUSB 3.0 specifications and suppor ts up to 5Gbps high speed data transmission. As a next-generation interface, this ser ies functions well for various small sized devices. USB 2.0 + Charging Hi-Speed 480 Mbps USB 3.0 Transmission Super Speed 5.0 Gbps ■Features 1.Supports high-speed USB 3.0 transmissions In comparison to the MicroUSB 2.0 connectors, the maximum transfer speed has drastically increased from 480Mbps to 5Gbps, delivering 10 times the transfer speed. Hi-Speed USB2.0 2. Fully supports MicroUSB 2.0 Supports the plug used in MicroUSB 2.0 3. Design provides a smoother mating cycle and a longer life With the extensive data and experience compiled from the previous MicroUSB 2.0 ZX series connectors, the unique new active latch (lock) mechanism delivers a clear tactile click that does not diminish after repeated use. 4. Micro-USB 3.0 certification (TID number) acquired 5. RoHS compliant, halogen-free product* In case of USB 2.0 transmission + charging, conventional Micro USB 2.0 plug is usable. Super Speed USB3.0 * ZX360 series is halogen-free product (Maximum content of Br, Cl and Br+Cl total are 900ppm, 900ppm and 1500ppm, respectively.) USB 3.0 plug is required in case of USB 3.0 transmission. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2016.9③ 1 ZX360 Series●USB3.0 Micro-B Connector ■Product Specifications Rated Voltage 30V AC Rated 1A/contact : When all contacts (No. 1 to 10) are for signal 1.8A/contact : for power contact (No. 1 & 5) and 0.5A/contact Operating Temp. Range -30°C to +85°C (Note 1) Current for others (No. 2 to 4, 6 to 10). Storage Temp. Range −30℃∼ +60℃ Ratings Items Specifications 1. Contact 30mø max. resistance 2. Withstand voltage No flashover or breakdown 3. Capacitance Measured at 100mA 100V AC / 1min Between adjacent contacts with 1,000Hz alternative voltage 2 pF or less 4. Durability 5. Overall insertion/ extraction forces Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Conditions Contact resistance : Increase by 10mø or less from the initial value Insertion : 35N max. Extraction : 10N min.(Initial) 8N min.(After durability cycles) 10,000 mating cycles Measured with applicable connector Note 1 : Includes temperature rise caused by current flow. Note 2 : The above specifications are representative of this series. Hirose does not guarantee specified performance when mating with other maker's parts. ■Materials / Finish ●Receptacle Parts Materials Color/Finish Insulator LCP Black/UL94V-0 Contact Copper alloy Gold plating (nickel under plating) or Nickel-palladium plating Shell Stainless steel Tin plating ●Plug Parts Materials Color/Finish Insulator Contact Lock spring LCP Copper alloy Stainless steel Black/UL94V-0 Gold plating (nickel under plating) or Nickel-palladium plating − Shield Stainless steel Nickel plating Note : This is a halogen-free product. (Maximum content of Br, Cl and Br+Cl total are 900ppm, 900ppm and 1500ppm, respectively.) Note : The above data is representative of this series. Data may vary according to specifications. ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Receptacle ZX 3 60 D − B − 10 P ❶ ❷ ❸ ❹ ❺ ❻ ❼ ●Plug ZX 3 60 − B − 10 S − UNIT ❶ ❷ ❸ ❺ ❻ ❼ ZX 3 60 − B − SLD* ❶ ❷ ❸ ❺ ❽ ❽ ❶Series name ❷Supported transmission None 3 ❸Wiring style 60 ❹Mounting form of receptacle shell D B ❺Mating key shape ❻No. of contacts ❼Contact type P S ❽Plug components UNIT SLD* ZX USB 2.0 compliant USB 3.0 compliant Right angle SMT Dip style Micro-B 10 contacts Receptacle (male contacts) Plug connector (female contacts) Plug unit Plug shield (Note 1) Note 1 : * contains type symbol such as A, B or number. 2 ZX360 Series●USB3.0 Micro-B Connector ■Receptacle Micro-B ●Standard type Part No. HRS No. Packaging ZX360D-B-10P(30) 242-0500-1 30 3,000 pcs/reel BRecommended PCB layout (component side) 1.35 1.9 12.85 No.1 No.5 No.6 No.10 0.6 5 2.8 2.63 0.25 0.25 2.15 2.15 3.1 4.9 5.6 7.4 8.1 2.7 3.635 8.965 4.24 9.57 12.6 0.7 0.3(THROUGH HOLE) 0.525(THROUGH HOLE) 2.6 1.3 1.45 PCB END 9.75 8.75 6.7 1.6 3.35 2.65 1.3 R 0.3(THROUGH HOLE)10-0.4 R 0.3(LAND) 1.5(THROUGH HOLE) 2.15 ■Plug Micro-B ●Cable side, PCB mount type Part No. HRS No. Packaging ZX360-B-10S-UNIT(30) 242-0501-4 30 100 pcs/pack 14.85 Note : Cable assembly instructions are separately available. No.10 No.1 12.95 4.2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4.15 2.05 3 ZX360 Series●USB3.0 Micro-B Connector ● Cable side, PCB mount type shield A Part No. Packaging Cable Diameter 242-0502-7 00 2,700 pcs/reel Ø3.3 ZX360-B-SLDA(4.8) 242-0508-3 00 1,500 pcs/reel Ø4.8 26.4 23.4 HRS No. ZX360-B-SLDA 13.05 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 13.05 ZX360-B-SLDA(4.8) ZX360-B-SLDA BPackaging Specifications (JIS C 0806-3 compliant) ●Reel Dimensions .5 Unreeling direction 30.4 24.4 2 4 Ø1 1.75 ●Emboss Carrier Tape Dimensions Unreeling direction Ø80 Ø380 24 11.5 .3 Ø1 1.8 8 BReceptacle Recommended Temperature Profile ●Set-up Condition ○Solder paste used  Sn96.5/Ag3.0/Cu0.5 ○Board Dimensions : 35 × 35 × 0.8 mm  Material : Glass-based epoxy resin ○Temperature measurement point  Contact lead area Note 1 : Reflow is allowed up to 2 times with the same conditions.Please allow the parts to return to the ambient temperature before the second run is started. Note 2 : The measured temperature is the temperature of the PCB surface around the connector leads. BPrecautions 1. Please handle connectors with care because excessive external force may damage the connectors. 2. To extract the plug, hold the plug body itself and remove it straight away from the receptacle. Do not pull on the cable to extract the plug as this may damage the connector. 3. Due to the assembly process there may be some abrasions on the surface of the receptacle, they will not have a negative impact on the performance of the product. 4. Due to external variances, the plating shine on the surface of the receptacles may differ from lot to lot. This difference will not affect the performance of this product. ® 4 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 09/2016. Contents are subject to change without notice for the purpose of improvements.
ZX360D1-B-CN-10P 价格&库存
很抱歉,暂时无法提供与“ZX360D1-B-CN-10P”相匹配的价格&库存,您可以联系我们找货
