U338-06N
U338-06N
    TRIPPLITE
    USB3.0SUPERSPEEDTOSATA/IDEA
U338-06N 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States USB 3.0 SuperSpeed to SATA/IDE Adapter with Built-In USB Cable, 2.5 in., 3.5 in. and 5.25 in. Hard Drives MODEL NUMBER: U338-06N Highlights ● Supports USB 3.0 data transfer rates up to 5 Gbps ● Compatible with SATA and IDE hard drives up to 4 TB ● Backward compatible with earlier USB generations ● Plug-and-play—no external power supply required ● Compatible with all USBenabled operating systems System Requirements ● Any USB-enabled operating system ● Available USB port (USB 3.0 required to achieve USB 3.0 speeds) ● 2.5 in., 3.5 in. or 5.25 in. SATA or IDE drive Package Includes Connects a 2.5, 3.5 or 5.25 in. SATA or IDE (PATA) hard drive to your laptop or computer’s USB port for extra storage, quick disk formatting and fast data transfer. Description The U338-06N USB 3.0 SuperSpeed to SATA/IDE Adapter connects a 2.5-, 3.5- or 5.25-inch SATA or IDE hard drive to an available USB port on your laptop or computer. This lets you back up important data, retrieve data from an old hard drive, or store information on an external drive that you can take with you to another computer. This adapter with built-in USB cable supports USB 3.0 data transfer rates up to 5 Gbps. Perfect for storing and sharing large files, such as music and video files, the U338-06N is compatible with SATA and IDE drives up to 4 TB. It features 40- and 44-pin IDE ports, as well as 7-pin SATA data and 15-pin SATA power (via adapter cable) connectors. Necessary SATA and Molex cables are included. LEDs indicate a successful connection. The U338-06N accepts SATA III (6 Gbps), SATA II (3 Gbps) and SATA I (1.5 Gbps) drives, as well as USB 2.0 (480 Mbps) and USB 1.1 (12 Mbps) transfer speeds. It supports USB Mass Storage Class Bulk-Only Transport. No software or drivers are required. Compatible with all USB-enabled operating systems. Features Quickly Connects a SATA and/or IDE Drive to Your Computer’s USB Port ● Recommended for backing up, retrieving and storing large data files ● LEDs indicate successful connection ● Built-in USB 3.0 cable supports data transfer rates up to 5 Gbps ● Backward compatible with previous USB generations Compatible with 2.5 in., 3.5 in. and 5.25 in. SATA and IDE Drives Up to 4 TB ● Accepts SATA III, SATA II and SATA I drives ● Features 40-pin and 44-pin IDE connectors and 7-pin SATA data and 15-pin SATA power (via adapter cable) connectors ● Supports USB Mass Storage Class Bulk-Only Transport 1/4 ● U338-06N USB 3.0 SuperSpeed to SATA/IDE Adapter ● 7-pin SATA data cable ● 15-pin SATA power cable ● 4-pin Molex power cable ● External power supply (Input: 100–240V, 50/60 Hz, 0.6A; Output: 12V, 2A) ● Power supply adapter ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Easy to Use ● Plug-and-play—no software or drivers needed ● Compatible with all USB-enabled operating systems ● SATA and Molex cables included Specifications OVERVIEW UPC Code 037332199744 Technology SATA/eSATA INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 Bus Powered No Product Length (in.) 21.6 POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.6A External Power Supply Output Specs (V / A) 12V / 2A External Power Supply Cord Length (ft.) 4.9 External Power Supply Cord Length (m.) 1.5 AC Adapter Input: 100-240V, 50/60Hz, 0.6A; Output: 12V, 2A DC Barrel Plug OD: 5.5 x 2.1 x 10mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 24.00 USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Read, Write, Power) PHYSICAL Color Black Material of Construction ABS Cable Jacket Color Black Cable Jacket Rating VW-1 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 1.90 x 5.20 x 6.70 Shipping Dimensions (hwd / cm) 4.83 x 13.21 x 17.02 Shipping Weight (lbs.) 0.60 Shipping Weight (kg) 0.27 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 1.4 x 6.3 x 4.2 Unit Packaging Type Box Unit Weight (lbs.) 0.08 Unit Weight (kg) 0.04 ENVIRONMENTAL Operating Temperature Range 50 to 122 F (10 to 50 C) Storage Temperature Range 32 to 149 F (0 to 65 C) Relative Humidity 10% to 80% RH, Non-Condensing BTUs 81.9 BTU/Hr CONNECTIONS Number of Ports 3 Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 7 PIN SATA (MALE) Side B - Connector 2 40 POS. SOCKET (FEMALE) Side B - Connector 3 44 Header IDC (Female) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; UL; cUL; RoHS Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U338-06N 价格&库存
很抱歉,暂时无法提供与“U338-06N”相匹配的价格&库存,您可以联系我们找货
