DDR0810TRI
DDR0810TRI
    TRIPPLITE
    FULLMOTIONUNIVERSALTABLETDES
DDR0810TRI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Full-Motion Universal Flexible Tablet Stand Highlights ● Fits most tablets ranging from 8 to 10 in. ● Flexible, bendable legs stabilize tablet on uneven surfaces ● Rubber feet grip surface securely ● Rotates 360° for portrait and landscape orientations ● Supports up to 2.2 lbs (1 kg) MODEL NUMBER: DDR0810TRI Package Includes Mount your tablet on your desk, table, workstation or almost any other surface to maximize space. Customize the tablet’s angle to fit your environment and comfort level. Description The DDR0810TRI Full-Motion Universal Flexible Tablet Stand rests securely on your desk, table, workstation or almost any other surface to maximize space and offer hands-free stability. It fits most tablets from 8 to 10 inches. Its flexible eight-inch legs bend to steady your tablet on uneven surfaces and can even wrap around objects for maximum effect. Rubber feet provide a strong grip on most surfaces. Tripod design rotates 360°, so you can view your tablet in portrait or landscape orientation. Easy assembly in seconds with no tools necessary. Supports up to 2.2 lbs (1 kg). Features Ideal for Most Desks, Tables and Workstations ● Fits most tablets from 8 to 10 in. ● Flexible 8 in. legs bend to stabilize tablet on uneven surfaces ● Legs can wrap around objects for maximum effect ● Rubber feet provide strong grip on most surfaces ● Full 360° rotation for both portrait and landscape orientations Assembles in Seconds ● No tools necessary ● Supports up to 2.2 lbs (1 kg) Specifications OVERVIEW UPC Code 037332190536 Device Compatibility Tablet 1/3 ● DDR0810TRI Full-Motion Universal Flexible Tablet Stand ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color Black Material of Construction Plastic Motion Full Mounting Location Desktop Degrees of Motion -30/+30 Tilt; -30/+30 Swivel; 360 Rotate Minimum Screen Size (in.) 8 Minimum Screen Size (cm) 20.32 Maximum Screen Size (in.) 10 Maximum Screen Size (cm) 25.4 Maximum Weight Capacity (lbs.) 2.2 Maximum Weight Capacity (kg) 1 Shipping Dimensions (hwd / in.) 2.75 x 4.52 x 10.63 Shipping Dimensions (hwd / cm) 6.98 x 11.48 x 27.00 Shipping Weight (lbs.) 0.75 Shipping Weight (kg) 0.34 Unit Dimensions (hwd / in.) 8.070 x 8.260 x 8.260 Unit Dimensions (hwd / cm) 20.50 x 20.99 x 20.99 Unit Weight (lbs.) .57 Unit Weight (kg) 0.26 Assembly Required Yes FEATURES & SPECIFICATIONS Cord Management No Antimicrobial No Tools Necessary No STANDARDS & COMPLIANCE Product Compliance RoHS; RoHS3; REACH WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
DDR0810TRI
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换和分配,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗电子等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
DDR0810TRI 价格&库存
很抱歉,暂时无法提供与“DDR0810TRI”相匹配的价格&库存,您可以联系我们找货
