1000 Eaton Boulevard
Cleveland, OH 44122
United States
Notebook Cooling Pad - Notebook/Laptop
Computer
Highlights
Built-in cooling fans dissipate
heat away from the bottom of
your notebook and cool down
the overall temperature of your
system
USB-powered for use with any
computer USB port
Heavy-duty construction
withstands the constant
pressure of heavy notebooks
3 viewing angles - 15, 30 and 45
degrees
Compact size offers easier
portability while traveling
MODEL NUMBER: NC2003SR
System Requirements
Description
This portable model includes two built-in cooling fans for reducing the internal heat of hot-running
notebooks.
Fan Specifications Bearing type: sleeve, MTBF: 30,000 hours
Features
notebooks
MTBF: 30,000 hours
3 viewing angles - 15, 30 and 45 degrees
Specifications
OVERVIEW
UPC Code
037332127051
Accessory Type
Cooling Pad
Accessory Class
Laptop & Tablet Accessories
PRODUCT OVERVIEW
Product Overview
PHYSICAL
Color
Black
1/2
USB port
Cleveland, OH 44122
United States
Material of Construction
Plastic
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Dimensions (hwd / cm)
1.93 x 30 x 24.9
Unit Weight (lbs.)
1.01
Unit Weight (kg)
0.46
FEATURES & SPECIFICATIONS
USB 1.1 Compatible
Yes
USB 2.0 Compatible
Yes
USB Powered
Yes
IP68 Rated
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“NC2003SR”相匹配的价格&库存,您可以联系我们找货
