U026-15M
U026-15M
    TRIPPLITE
    USB2.0HI-SPEEDACTIVEEXTENSIO
U026-15M 数据手册
USB 2.0 Active Extension Repeater Cable (A M/F), 15M (49.21 ft.) MODEL NUMBER: U026-15M Highlights ● Adds 15M (49.21-ft.) to existing USB device cable ● Supports data transfer rates up to 480 Mbps ● Built-in booster for peak USB 2.0 signal quality ● Provides up to 250mA of power to connected device ● Backward compatible with previous USB generations System Requirements Connects to any computer, device and/or cable with USB-A connectors to increase the length of a device cable with no decrease in signal or performance. Extends beyond the 16 ft. limit of conventional USB 2.0 cables. Description Tripp Lite's U026-15M USB 2.0 Hi-Speed Active Extension Repeater Cable (M/F) increases the length of a device cable up to 15M (49.21-ft.) with no danger of signal loss or performance decrease. Connect the male plug to a USB port on your computer or hub and the female end to a USB device cable. A built-in bus-powered signal booster ensures peak USB 2.0 signal quality. Backward compatible with previous USB generations, this cable supports data transfer rates up to 480 Mbps. The U026-15M works with all computers, devices and cables with USB-A connectors, and provides up to 250mA of power to a connected device (an external power supply or powered USB 2.0 hub is required for power applications stronger than 250mA). Premium foil and braid shielding delivers top-of-the-line signal quality and protection from EMI/RFI interference. Nickel-plated USB connectors with gold-plated copper contacts ensure excellent conductivity. Integral strain relief ensures the cable and connectors last a long time. Features Extends Transmission Distance Between USB Device and Computer by 15M (49.21-ft.) ● Supports data transfer rates up to 480 Mbps ● Built-in bus-powered signal booster for peak performance ● Provides up to 250mA of power to connected device ● Backward compatible with previous USB generations Premium Construction for Superior Signal Transfer ● Premium foil and braid shielding protects against EMI/RFI ● Nickel-plated connectors with gold-plated copper contacts ensure excellent conductivity ● Works with all computers, devices and cables with USB-A connectors ● External power supply or powered USB hub required for power applications stronger than 250mA Specifications 1/3 ● USB 2.0 computer port and USB 2.0 device required to meet USB 2.0 speeds ● External power supply or powered USB hub (such as U222-004-R) required for power applications above 250mA. Package Includes ● U026-15M USB 2.0 Hi-Speed Active Extension Repeater Cable (M/F), 15 m OVERVIEW UPC Code 037332199768 Technology USB 2.0 (High Speed) USB Cable Type Active INPUT Bus Powered Yes POWER Power Consumption (Watts) 0.20 PHYSICAL Material of Construction ABS, PVC Cable Jacket Color Black Cable Jacket Rating VW-1 Cable Length (ft.) 49.2 Cable Length (m) 15.00 Shipping Dimensions (hwd / in.) 0.50 x 9.40 x 11.80 Shipping Weight (lbs.) 1.20 Unit Packaging Type Polybag Unit Weight (lbs.) 1.1 Unit Weight (kg) 0.50 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) Storage Temperature Range 14 to 167 F (-10 to 75 C) BTUs 0.68 BTU/Hr Operating Humidity Range 10 to 85% RH, Non-Condensing Storage Humidity Range 5 to 90% RH, Non-Condensing Power Provided to Connected Device(s) 0.25A Output per USB port CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 USB A (FEMALE) Connector Plating Nickel 2/3 FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) Driver Required No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U026-15M 价格&库存
很抱歉,暂时无法提供与“U026-15M”相匹配的价格&库存,您可以联系我们找货
U026-15M
    库存:2
