U239-UE1
U239-UE1
    TRIPPLITE
    SATAHARDDRIVE
U239-UE1 数据手册
USB 2.0 Hi-Speed or eSatA to SatA External Hard Drive Docking Station for 2.5in or 3.5in HDD MODEL NUMBER: U239-UE1 Highlights ● Works with both 2.5" and 3.5" SATA hard drives ● Supports high-speed USB 2.0 data transfer rates up to 480 Mbps ● Supports SATA data transfer rates up to 3 Gbps ● Features two USB 2.0 hub ports ● Supports Windows 98/ME/2000/XP/Vista/7/8, Mac OS 9.x/10.x, Linux System Requirements ● Intel compatible PC w/USB Port (USB 2.0 recommended) or eSATA port ● Windows 98/ME/2000/XP/Vista/7/8, Mac OS 9.x/10.x, Linux Package Includes ● U239-UE1 USB 2.0 / eSATA to SATA Hard Drive Quick Dock Tripp Lite's USB 2.0 / eSATA to SATA Hard Drive Quick Dock gives you a quick and easy way to set up ● USB 2.0 Device Cable an external hard drive storage system. Plug the docking station into an available USB or eSATA port on ● eSATA 7-pin Cable your computer, and then insert a 2.5" or 3.5" SATA drive for instant access to your external storage ● External Power Supply (100240V, 50/60Hz, 0.8A Output: 12V,2A) ● Owner's Manual Description device. Far easier than installing the hard drive internally or in a caddy, the Quick Dock is easy to use, convenient and practical. In addition, the U239-UE1 features two USB 2.0 hub ports to access your USB peripherals with. Compatible with Windows 98/ME/2000/XP/Vista/7/8, Mac OS 9.x/10.x, and Linux. Features ● Works with both 2.5" and 3.5" SATA hard drives ● Supports high-speed USB 2.0 data transfer rates up to 480 Mbps ● Supports SATA data transfer rates up to 3 Gbps ● Features two USB 2.0 hub ports ● Plug-n-Play (no software or configuring needed) ● Supports Windows 98/ME/2000/XP/Vista/7/8, Mac OS 9.x/10.x, Linux Specifications OVERVIEW UPC Code 037332153289 Technology SATA/eSATA; USB 2.0 (High Speed) PHYSICAL Color Black 1/2 Shipping Dimensions (hwd / in.) 4.60 x 6.20 x 5.00 Shipping Dimensions (hwd / cm) 11.68 x 15.75 x 12.70 Shipping Weight (lbs.) 1.20 Shipping Weight (kg) 0.54 Unit Dimensions (hwd / in.) 2.250 x 5.250 x 4.750 Unit Dimensions (hwd / cm) 5.7 x 13.3 x 12.1 Unit Weight (lbs.) 0.45 Unit Weight (kg) 0.20 WARRANTY Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U239-UE1 价格&库存
很抱歉,暂时无法提供与“U239-UE1”相匹配的价格&库存,您可以联系我们找货
