EZA-VGACSAX-2
EZA-VGACSAX-2
    TRIPPLITE
    TYPE A CONNECTOR M/F VGA 3.5MM
EZA-VGACSAX-2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Easy Pull Type-A Connectors - M/F set of VGA, 3.5mm, RCA Audio, Composite Video MODEL NUMBER: EZA-VGACSAX-2 Highlights ● SVGA / 3.5mm / Red-White RCA Audio / Composite Video, Male to Female ● Versatile trunk cable allows for a variety of connection options ● High quality RGB style VGA cable supports resolutions up to 1600 x 1200 Package Includes Description Easy Pull Connector Kit includes: 1x HD15 Male, 1x stereo 3.5mm Plug, 2x RCA Red/White Audio plugs, and 1 x Yellow Composite Video plugs, 1 ft. pigtails. 1x HD15 Female, 1x stereo 3.5mm jack, 2x RCA Red/White Audio jacks, and 1 x Yellow Composite Video jacks, 1 ft. pigtails and wallplate. Video support up to 1600 x 1200. Use with either PVC or Plenum Easy Pull trunk cables. Features ● Easy Pull, SVGA / 3.5mm / Red-White RCA Audio / Composite Video, Male to Female ● Eliminates the need to field terminate VGA connectors ● Allows cable to be run according to code - inside conduit, drop ceilings, etc. ● Makes pulling long cables fast and easy ● Trunk cables available in 35 ft., 50 ft. and 100 ft. lengths, PVC or Plenum rated jackets ● Support resolutions up to 1600 x 1200 Specifications OVERVIEW UPC Code 037332153807 Technology Composite; Stereo Audio; VGA/SVGA PHYSICAL Color Black; Green Cable Length (ft.) 1.5 Cable Length (m) 0.46 1/2 ● 1 x HD15/3.5mm/Red White RCA Audio/Composite Video, All Male Plugs ● 1 x HD15/3.5mm/Red White RCA Audio/Composite Video, All Female jacks + Wallplate 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 2.40 x 6.30 x 9.10 Shipping Dimensions (hwd / cm) 6.10 x 16.00 x 23.11 Shipping Weight (lbs.) 0.90 Shipping Weight (kg) 0.41 CONNECTIONS Side A - Connector 1 HD15 (MALE) Side A - Connector 2 3.5MM (MALE) Side A - Connector 3 (3) RCA (MALE) Side A - Connector 4 DIN 14 PIN (MALE) Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 3.5MM (FEMALE) Side B - Connector 3 (3) RCA (FEMALE) Side B - Connector 4 DIN 14 PIN (MALE) Latching or Gripping Connector No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
EZA-VGACSAX-2 价格&库存
很抱歉,暂时无法提供与“EZA-VGACSAX-2”相匹配的价格&库存,您可以联系我们找货
