HY3403D
HY3403D
    HUAYI(华羿微)
    TO-252(DPAK)
    N沟道2.4mΩ@10V TO-252 30V
HY3403D 数据手册
HY3403D/U/V N-Channel Enhancement Mode MOSFET Feature  Pin Description 30V/100A RDS(ON)= 2.4mΩ(typ.)@VGS = 10V RDS(ON)= 2.9mΩ(typ.)@VGS = 4.5V  100% Avalanche Tested  Reliable and Rugged  Lead Free and Green Devices Available (RoHS Compliant) TO-252-2L TO-251-3L TO-251-3S Applications Systems High Frequency Synchronous Buck Converters for Computer Processor Power High Frequency Isolated DC-DC N-Channel MOSFET Converters with Synchronous Rectification for Telecom and Industrial Use Ordering and Marking Information Package Code D U HY3403 HY3403 HY3403 YYXXXJWW G YYXXXJWW G YYXXXJWW G V D: TO-252-2L Date Code YYXXX WW U: TO-251-3L V:TO-251-3S Assembly Material G:Halogen Free Note: HOOYI lead-free products contain molding compounds/die attach materials and 100% matte tin plateTermiNation finish; which are fully compliant with RoHS. HOOYI lead-free products meet or exceed the lead-Free requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature. HOOYI defines “Green” to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed 900ppm by weight in homogeneous material and total of Br and Cl does not exceed 1500ppm by weight). HOOYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to this pr -oduct and/or to this document at any time without notice. www.hooyi.cc V2.0 1 HY3403D/U/V Absolute Maximum Ratings Symbol Parameter Rating Unit Common Ratings (Tc=25°C Unless Otherwise Noted) VDSS Drain-Source Voltage 30 V VGSS Gate-Source Voltage ±20 V Maximum Junction Temperature 175 °C -55 to 175 °C Tc=25°C 100 A Tc=25°C 400 A Tc=25°C 100 A Tc=100°C 70 A Tc=25°C 60 W Tc=100°C 30 W TJ TSTG Storage Temperature Range IS Source Current-Continuous(Body Diode) Mounted on Large Heat Sink Note: IDM Pulsed Drain Current * ID Continuous Drain Current PD Maximum Power Dissipation RJC Thermal Resistance, Junction-to-Case 2.5 °C/W RJA Thermal Resistance, Junction-to-Ambient ** 110 °C/W EAS Single Pulsed-Avalanche Energy *** 184 mJ * ** *** L=0.3mH Repetitive rating;pulse width limited by max. junction temperature. Surface mounted on FR-4 board. Limited by TJmax , starting TJ=25°C, L = 0.3mH, RG= 25Ω, VGS =10V. Electrical Characteristics(Tc =25°C Unless Otherwise Noted) Symbol Parameter Test Conditions HY3403 Unit Min Typ. Max 30 - - V - - 1 μA - - 50 μA 3 V Static Characteristics BVDSS Drain-Source Breakdown Voltage IDSS Drain-to-Source Leakage Current VGS(th) IGSS RDS(ON)* VGS=0V,IDS=250μA VDS=30V,VGS=0V TJ=125°C Gate Threshold Voltage VDS=VGS, IDS=250μA 1 1.5 Gate-Source Leakage Current VGS=±20V,VDS=0V - - VGS=10V,IDS=50A - 2.4 3.0 VGS=4.5V,IDS=50A - 2.9 3.6 ISD=50A,VGS=0V - 0.8 1.3 V - 23 - ns - 58 - nC Drain-Source On-State Resistance ±100 nA mΩ Diode Characteristics VSD* Diode Forward Voltage trr Reverse Recovery Time Qrr Reverse Recovery Charge ISD=50A,dISD/dt=100A/μs www.hooyi.cc V2.0 2 HY3403D/U/V Electrical Characteristics (Cont.) (Tc =25°C Unless Otherwise Noted) Symbol Parameter Test Conditions HY3403 Min Typ. Max - 1.9 - - 4726 - Unit Dynamic Characteristics RG Gate Resistance Ciss Input Capacitance VGS=0V,VDS=0V,F=1 MHz VGS=0V, Coss Output Capacitance VDS=24V, - 469 - Crss Reverse Transfer Capacitance Frequency=1.0MHz - 322 - td(ON) Turn-on Delay Time - 13 - Tr Turn-on Rise Time VDD=15V,RG=4Ω, - 11 - td(OFF) Turn-off Delay Time IDS=50A,VGS=10V - 41 - - 14 - - 120 - - 9 - - 26 - Tf Turn-off Fall Time Gate Charge Ω pF ns Characteristics Qg Total Gate Charge Qgs Gate-Source Charge Qgd Gate-Drain Charge VDS =24V, VGS=10V, ID=50A nC Note: *Pulse test,pulse width ≤ 300us,duty cycle ≤ 2% www.hooyi.cc V2.0 3 HY3403D/U/V Typical Operating Characteristics ID-Drain Current(A) Voltage Figure 2: Drain Current Power Dissipation (w) Figure 1: Power Dissipation Tc-Case Temperature(℃) Impedance Thermal Normalized Transient Figure 4: Thermal Transient Impedance Zθ jc Voltage ID-Drain Current(A) Figure 3: Safe Operation Area Tc-Case Temperature(℃) Maximum Effective Transient Thermal Impedance, Junction-to-Case VDS-Drain-Source Voltage(V) VDS-Drain-Source Voltage (V) Voltage RDS(ON)-ON-Resistance(Ω) Figure 6: Drain-Source On Resistance Voltage ID-Drain Current(A) Figure 5: Output Characteristics ID-Drain Current(A) www.hooyi.cc V2.0 4 HY3403D/U/V Typical Operating Characteristics(Cont.) Voltage IS-Source Current (A) Figure 8: Source-Drain Diode Forward Voltage Normalized On-Resistance Figure 7: On-Resistance vs. Temperature Tj-Junction Temperature (℃) VDS-Drain-Source Voltage (V) Voltage VGS-Gate-Source Voltage (V) Figure 10: Gate Charge Characteristics Voltage C-Capacitance(pF) Figure 9: Capacitance Characteristics VSD-Source-Drain Voltage(V) Q G-Gate Charge (nC) www.hooyi.cc V2.0 5 HY3403D/U/V Avalanche Test Circuit Switching Time Test Circuit and Waveforms Gate Charge Test Circuit and Waveforms www.hooyi.cc V2.0 6 HY3403D/U/V Device Per Unit Package Type Unit Quantity TO-252-2L TO-251-3L TO-251-3S Tube Tube Tube 75 75 75 Package Information TO-252-2L www.hooyi.cc V2.0 7 HY3403D/U/V TO-251-3L www.hooyi.cc V2.0 8 HY3403D/U/V TO-251-3S www.hooyi.cc V2.0 9 HY3403D/U/V Classification Profile Classification Reflow Profiles Profile Feature Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) Average ramp-up rate (Tsmax to TP) Liquidous temperature (TL) Time at liquidous (tL) Peak package body Temperature (Tp)* Time (tP)** within 5°C of the specified classification temperature (Tc) Average ramp-down rate (Tp to Tsmax) Time 25°C to peak temperature Sn-Pb Eutectic Assembly Pb-Free Assembly 100 °C 150 °C 150 °C 200 °C 60-120 seconds 60-120 seconds 3 °C/second max. 3°C/second max. 183 °C 217 °C 60-150 seconds 60-150 seconds See Classification Temp in table 1 See Classification Temp in table 2 20** seconds 30** seconds 6 °C/second max. 6 °C/second max. 6 minutes max. 8 minutes max. *Tolerance for peak profile Temperature (T p) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature (tp) is defined as a supplier minimum and a user maximum. www.hooyi.cc V2.0 10 HY3403D/U/V Table 1.SnPb Eutectic Process – Classification Temperatures (Tc) Package Volume mm³ Volume mm³ Thickness
HY3403D 价格&库存
很抱歉,暂时无法提供与“HY3403D”相匹配的价格&库存,您可以联系我们找货
