USB 3.0 SuperSpeed Active Extension Repeater
Cable (USB-A M/F), 20M (65.61 ft.)
MODEL NUMBER: U330-20M
Highlights
Daisy-chain 2 cables for max
distance up to 130 ft.
Supports data transfer rates up
to 5 Gbps
Built-in signal booster for peak
performance
Provides up to 360mA of power
to connected device
Backward compatible with
previous USB generations
System Requirements
Connects to any computer, device and/or cable with USB-A connectors to increase the length of a device
cable with no decrease in signal or performance. Extends beyond the 10 ft. limit of conventional USB 3.0
cables.
Description
Tripp Lite's U330-20M USB 3.0 SuperSpeed Active Extension Repeater Cable (M/F) increases the length
of a device cable up to 65 feet with no worry of signal loss. By daisy-chaining two cables while using
external power, you can extend the length between USB devices up to 130-ft. (39.62 m).
Connect the male plug to a USB port on your computer or hub and the female end to a USB device cable.
A built-in bus-powered signal booster ensures peak performance. Backward compatible with previous
USB generations, this cable supports data transfer rates up to 5 Gbps.
The U330-20M works with all computers, devices and cables with USB-A connectors. It provides up to
360mA of power to a connected device (a 5V, 2A external power supply is required for power applications
stronger than 360mA).
Premium foil and braid shielding delivers top-of-the-line signal quality and protection from EMI/RFI
interference. Nickel-plated USB connectors with gold-plated copper contacts ensure excellent
conductivity. Integral strain relief ensures the cable and connectors last a long time.
Features
Extends Connections Between 2 USB-A Devices and/or Cables
● Increases length of device cable up to 20M (65.61-ft.)
Daisy-chain 2 cables for maximum distance up to 130-ft. (39.62 m) (while using an external 5V, 2A
power supply)
Supports data transfer rates up to 5 Gbps
Built-in bus-powered signal booster for peak performance
Provides up to 360mA of power to connected device
Backward compatible with previous USB generations
Premium Construction for Superior Signal Transfer
● Premium foil and braid shielding protects against EMI/RFI
Nickel-plated connectors with gold-plated copper contacts ensure excellent conductivity
Works with all computers, devices and cables with USB-A connectors
1/2
USB 3.0 computer port and USB
3.0 device required to meet USB
3.0 speeds
5V, 2A power supply with 3.5 x
1.35 mm DC jack required for
power applications above
360mA. Output plug requires
positive tip and negative sleeve.
Package Includes
U330-20M USB 3.0
Repeater Cable (M/F), 20 m
5V, 2A external power supply required for power applications stronger than 360mA
Specifications
OVERVIEW
UPC Code
037332199713
PHYSICAL
Color
Black
Cable Jacket Color
Black
Cable Length (ft.)
65.6
Cable Length (m)
20.00
Shipping Dimensions (hwd / cm)
1.27 x 35.56 x 43.18
Shipping Dimensions (hwd / in.)
0.50 x 14.00 x 17.00
Shipping Weight (kg)
1.36
Shipping Weight (lbs.)
3.00
CONNECTIONS
Side A - Connector 1
USB 3.0 A (MALE)
Side B - Connector 1
USB 3.0 A (FEMALE)
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U330-20M”相匹配的价格&库存,您可以联系我们找货
