1000 Eaton Boulevard
Cleveland, OH 44122
United States
Dual Vertical Flat-Screen Desk Stand/Clamp
Mount, 15 in. to 27 in. Flat-Screen Displays
MODEL NUMBER: DDR1527SDC
Highlights
Functions as either a desktop
stand or clamp-on mount
Fits most flat-panel displays
from 15 to 27 in.
One-touch adjustment for easy
viewing from multiple angles
-20° to +20° tilt, 20° swivel and
360° rotation capability
Supports displays up to 18 lbs
(8.2 kgs) each
Package Includes
VESA-compliant unit for mounting 2 flat-panel displays above your desk, table or workstation’s surface to
free up valuable space. One-touch adjustment for customizing the displays’ viewing angles for
comfortable viewing.
Description
The VESA-compliant DDR1527SDC Dual Vertical Flat-Screen Desk Stand/Clamp Mount frees up
valuable space on your desk, table or workstation by allowing you to mount two flat-panel displays on a
vertical pole. Ideal for home or office, the DDR1527SDC fits most flat-panel displays from 15 to 27 inches.
You can use it as a desktop stand or clamp it to a flat surface up to three inches thick.
One-touch adjustment lets you optimize viewing angles and improve ergonomics as you switch tasks
during the day. Adjust the dual mounting plates independently for angle and height to give you maximum
flexibility in positioning your displays to fit your environment and comfort level. A 20° swivel and -20° to
+20° tilt capability minimizes glare and provides comfortable viewing from multiple angles. A 360° rotation
lets you view your displays in portrait and landscape orientations.
Each mounting plate supports flat-panel displays up to 18 lbs (8.2 kgs). The durable all-metal frame with
scratch-resistant powder-coated finish tolerates frequent handling and blends with any décor. Included
cable clamps organize cables and secure them to the vertical pole to prevent clutter. Mounting hardware
is included. Conforms to VESA-compliant displays with hole patterns of 75 x 75 mm and 100 x 100 mm.
Features
Compatible with Most Desks, Tables and WorkstationsFunctions as either a desktop stand or clampon mount - both mounting options includedMounts 2 flat-panel displays from 15 to 27 in. on a vertical
poleDual mounting plates adjust independently for angle and heightIdeal for home and office useClamps
to flat surface up to 3 in. thick
Convenient One-Touch Adjustment20° swivel and -20° to +20° tilt capability provide comfortable
viewing from multiple anglesFull 360° rotation in both portrait and landscape orientations
Durable Metal ConstructionEach mounting plate supports displays up to 18 lbs (8.2 kgs)Scratchresistant powder-coated finish blends with any décorMounting hardware includedCable clamps organize
cables and reduce clutter
VESA ComplianceConforms to VESA-compliant universal mounting hole patterns
Specifications
1/3
Pole
(2) Mount assemblies with
VESA plate
Desktop base
Clamp
(2) Locating rings
Top cap
Hex key, 3 mm
Hex key, 4 mm
Hex key, 5 mm
(8) M4 x 12 mm screws
(8) M4 x 30 mm screws
(3) M6 x 15 mm screws
(8) Spacers
(2) Cable clamps
Owner’s manual
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332190574
Device Compatibility
Monitor/HDTV
PHYSICAL
Color
Black
Material of Construction
Steel
VESA Pattern (mm)
75x75; 100x100
Motion
Full
Mounting Location
Desktop; Desk Clamp
Degrees of Motion
-20/+20 Tilt; 20 Swivel; 360 Rotate
Minimum Screen Size (in.)
15
Minimum Screen Size (cm)
38.1
Maximum Screen Size (in.)
27
Maximum Screen Size (cm)
68.58
Maximum Weight Capacity (lbs.)
18
Maximum Weight Capacity (kg)
8
Number of Displays
2
Shipping Dimensions (hwd / in.)
13.80 x 13.00 x 5.40
Shipping Dimensions (hwd / cm)
35.05 x 33.02 x 13.72
Shipping Weight (lbs.)
14.25
Shipping Weight (kg)
6.46
Unit Dimensions (hwd / in.)
23.600 x 17.700 x 10.900
Unit Dimensions (hwd / cm)
60 x 45 x 28
Unit Weight (lbs.)
15.80
Unit Weight (kg)
7.17
Assembly Required
Yes
FEATURES & SPECIFICATIONS
Cord Management
Yes
Antimicrobial
No
Tools Necessary
Yes
Security Lock
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; RoHS3; REACH
2/3
Cleveland, OH 44122
United States
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
5-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“DDR1527SDC”相匹配的价格&库存,您可以联系我们找货
