2 Bay RAID Enclosure, SuperSpeed USB 5Gbps,
Fan Cooled, For 3.5" and 2.5" drives
MODEL NUMBER: U357-002
Highlights
2 Bay External RAID enclosure
for SATA 3.5" and 2.5" drives
5Gbps transfer speed with USB
3.2 Gen 1 enabled computer
Windows, MAC, Linux
compatible
System Requirements
( x2 ) 2.5" or 3.5" SATA Hard
Drives
Computer with USB 3.2 Gen 1
port required to achieve
maximum transfer rate
Package Includes
U357-002 Enclosure
USB 3.0 A/B Device Cable, 4-ft
External Power Supply with
NEMA 1-15P Plug and
removable power cord ( Input:
100-240V, 50/60Hz, 1.2A;
Output: 12V, 4A )
Screws for mounting 2.5" hard
drives
Owners Manual
Create inexpensive external mass storage for music, videos, photos
Description
Tripp Lite's 2-bay RAID enclosure with USB 3.0 support lets you quickly turn any two 2.5" or 3.5" internal
SATA hard drives into external hard drives. Compatible with SATA I, II, and III hard drives, and tested to
support up to 4TB 3.5" HDD per bay ( 8TB total ), and up to 1TB 2.5" HDD per bay ( 2TB total ), this highperformance 2 bay hard drive enclosure creates massive amounts of inexpensive external storage for
large files, such as Videos, Music, Photos, and more. When used with computers supporting USB 3.0, it
can achieve transfer speeds of up to 5Gbps. Backward compatible with USB 2.0 computers as well ( 480
mbps ), it features RAID 0, RAID 1, JBOD, and Normal disk modes, giving you the flexibility to access
your data in whatever way works best for you. A built in cooling fan keeps drives cool during prolonged
use. The unit is Plug-and-Play with no drivers or software required.
Features
2-bay HDD enclosure supports two 2.5" or 3.5" SATA I, II, or III drives
Up to 8TB with 2 x 4TB 3.5" drives, or 2TB with 2 x 2.5" drives
RAID 0, RAID 1, JBOD, or Normal modes available
Supports SuperSpeed USB 5Gbps transfer rates ( backward compatible with USB 2.0 and 1.1 )
Built-in cooling fan keeps drives cool
Plug-and-Play... no Drivers or Software required
Compatible with Windows (up to 10), MAC, and Linux
Specifications
OVERVIEW
UPC Code
037332181619
Drives Supported
2
Accessory Type
Hard Drive Enclosure
1/2
Technology
SATA/eSATA
POWER
AC Adapter
Input: 100-240V, 50/60Hz, 1.2A; Output: 12V, 4A
PHYSICAL
Color
Black
Shipping Dimensions (hwd / cm)
19.48 x 27.28 x 19.00
Shipping Dimensions (hwd / in.)
7.67 x 10.74 x 7.48
Shipping Weight (kg)
2.25
Shipping Weight (lbs.)
4.96
Unit Dimensions (hwd / in.)
4.80 x 8.90 x 5.30
Unit Dimensions (hwd / cm)
12.192 x 22.61 x 13.46
Unit Weight (lbs.)
3.50
Unit Weight (kg)
1.59
CONNECTIONS
Side A - Connector 1
USB 3.0 A (MALE)
Side B - Connector 1
(2) 22 PIN SATA + POWER (FEMALE)
STANDARDS & COMPLIANCE
Product Compliance
RoHS
WARRANTY
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“U357-002”相匹配的价格&库存,您可以联系我们找货
