U339-004
U339-004
    TRIPPLITE
    4-BAYUSB3.0/ESATATOSATADOCK
U339-004 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Note: The cloning function will not work if the U339-004 is connected to a computer or any other source via a USB cable. 4-Bay USB 3.2 Gen1/eSATA to SATA Docking Station with Cloning, 2.5 in. to 3.5 in. SATA Hard Drives MODEL NUMBER: U339-004 Highlights ● Supports USB 3.2 Gen1 data transfer rates up to 5 Gbps ● Supports eSATA data transfer rates up to 6 Gbps ● Compatible with SATA HDDs and SSDs up to 6 TB ● Works with all USB/eSATAenabled operating systems ● Offline cloning requires no computer connection System Requirements Connects up to four 2.5 in. or 3.5 in. SATA HDD or SSD to your laptop or computer’s USB or eSATA port for extra storage, quick disk formatting and fast data transfer. ● Any USB- and/or eSATAenabled operating system (cloning functionality will not work if the U339-004 is connected to a computer) ● Available USB or eSATA port (USB 3.2 Gen1 required to achieve USB 3.2 Gen1 speeds. SATA III eSATA port required to achieve eSATA speeds.) ● 2.5 in. or 3.5 in. SATA drive ● UASP-enabled host controller required for UASP performance Package Includes ● U339-004 4-Bay USB 3.2 Gen1/eSATA to SATA Docking Station ● USB 3.2 Gen1 cable, 2.5 ft. ● eSATA cable, 2 ft. ● External power supply w/NEMA 1-15P plug (Input: 100–240V, 50/60 Hz, 1.2A; Output: 12V, 5A) ● Owner’s manual Description The U339-004 4-Bay USB 3.2 Gen1/eSATA to SATA Docking Station connects up to four 2.5- or 3.5-inch SATA hard disk drives (HDD) or solid state drives (SSD) to an available USB or eSATA port on your laptop or computer. This lets you back up important data, retrieve data from an old hard drive, or store information on an external drive that you can take with you to another computer. Not only can you quickly access hard drive content without time-consuming internal installation, you can also clone a drive to as many as three others simultaneously. Cloning does not require the U339-004 to be connected to a host computer. Just insert the master drive into the master bay, insert the slave drive(s) into the slave bay(s), and press the Clone button twice. Red LEDs monitor cloning progress. The U339004 accepts 2.5- and 3.5-inch SATA III, II and I hard drives up to 6 TB and will work with larger drives as they become available. This docking station supports USB 3.2 Gen1 data transfer rates up to 5 Gbps, as well as eSATA rates up to 6 Gbps. Its UASP (USB Attached SCSI Protocol) feature reduces latency and allows the cable to perform up to 70% faster when connected to a UASP-enabled host controller. The U339-004 requires no software or drivers. It’s compatible with all USB- and/or eSATA-enabled operating systems and backward-compatible with previous USB generations. Features Connects Up to 4 SATA Drives to Your Computer’s USB or eSATA Port ● Recommended for backing up, retrieving and storing large data files ● Supports USB 3.2 Gen1 data transfer rates up to 5 Gbps ● Supports eSATA data transfer rates up to 6 Gbps ● Features UASP for performance up to 70% faster when connected to UASP-enabled host controller Provides Offline Disk Cloning ● Duplicates a hard drive on up to 3 others simultaneously ● Offline cloning requires no computer connection Compatible with 2.5 in. and 3.5 in. SATA HDDs and SSDs Up to 6 TB 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Accepts SATA III, SATA II and SATA I drives ● Backward-compatible with previous USB generations ● Will work with larger SATA drives as they become available Easy to Use ● Plug-and-play—no software or drivers ● No time-consuming internal installation required ● Compatible with all USB- and/or eSATA-enabled operating systems ● USB 3.2 Gen1 and eSATA cables included Specifications OVERVIEW UPC Code 037332198709 Technology SATA/eSATA INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 Bus Powered No POWER Power Source Type AC Adapter with detachable power cord External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1.5A External Power Supply Output Specs (V / A) 12V / 5A External Power Supply Cord Length (ft.) 4.9 External Power Supply Cord Length (m.) 1.5 AC Adapter Input: 100-240V, 50/60Hz, 1.2A; Output: 12V, 5A DC Barrel Plug OD: 5.5 x 2.1 x 10mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 60 USER INTERFACE, ALERTS & CONTROLS LED Indicators Red (Read, Write, Power); Green (Clone) PHYSICAL Color Black Material of Construction ABS, Steel Shipping Dimensions (hwd / in.) 2.80 x 6.70 x 9.60 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 7.11 x 17.02 x 24.38 Shipping Weight (lbs.) 2.40 Shipping Weight (kg) 1.09 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 6.5 x 16.5 x 12.7 Unit Packaging Type Box Unit Weight (lbs.) 1 Unit Weight (kg) 0.45 ENVIRONMENTAL Operating Temperature Range 50 to 122 F (10 to 50 C) Storage Temperature Range 32 to 149 F (0 to 65 C) Relative Humidity 10% to 80% RH, Non-Condensing BTUs 204.7 BTU/Hr CONNECTIONS Number of Ports 4 Side A - Connector 1 7 PIN ESATA (MALE); USB A (MALE) Side B - Connector 1 (4) 22 PIN SATA + POWER (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.2 Gen 1 (up to 5 Gbps) Driver Required No UASP Support Yes IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE External Power Supply Certifications CE; FCC; UL; PSE; GS; RoHS; China RoHS Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U339-004 价格&库存
很抱歉,暂时无法提供与“U339-004”相匹配的价格&库存,您可以联系我们找货
