1000 Eaton Boulevard
Cleveland, OH 44122
United States
The B203-104 is designed for long-distance data transfer.
● USB A/V devices that use isochronous USB data transfer require a non-Cat5 (U026-016, U02610M, U026-20M, U042-025 or U042-036) or plug-and-play (B203-101-PNP or B203-104-PNP)
extender.
Before use with a touchscreen, confirm compatibility with the manufacturer.
4-Port USB 2.0 over Cat5/Cat6 Extender Hub Kit,
Transmitter & Receiver, USB up to 328 ft. (100
m), TAA
MODEL NUMBER: B203-104
Highlights
Extends USB data transfer up to
328 ft. over Cat5/Cat6 cable
Includes transmitter and 4-port
receiver hub
Supports data transfer rates up
to 480 Mbps
Backward compatible with USB
1.1 devices
Works with Windows XP
through 10; not Mac®
compatible
System Requirements
Send data from a USB-equipped Windows® PC to as many as four USB 2.0 devices up to 328 ft. away.
USB-equipped Windows PC
Compatible with Windows XP,
Server 2003, Vista, 7, Server
2008, 8, 8.1 and 10 (32- and 64bit)
Installation of driver before
connection to PC; driver is
provided on the included CD
and is available for download on
the product support page
Cat5/Cat6 cable
Available AC outlet in receiver
hub location
Package Includes
B203-104 local transmitter
B203-104 4-port remote receiver
hub
1 ft. USB A/B cable (for local
transmitter connection)
External Power Supply with
NEMA 1-15P Plug for receiver
hub (Input: 100-240V, 50/60 Hz,
0.5A; Output: 5V, 2A)
supplied Cat5/Cat6 cable. It’s a simple, cost-effective solution for connecting your Windows PC to printers
Mounting hardware
and other USB peripherals that lack network connectivity and are farther than 16 feet away from your
Driver CD
Owner’s Manual
The USB signal travels over user-supplied Cat5/Cat6 cable. This kit is useful for devices or areas that lack
network conductivity.
Description
Tripp Lite’s B203-104 USB 2.0 over Cat5/Cat6 Extender Hub Kit transmits data from your Windows PC to
as many as four USB 2.0 peripherals up to 328 ft. away. Use the included 1 ft. USB cable to connect your
PC to the transmitter. The USB signals travel between the transmitter and 4-port receiver hub over user-
computer, which is the distance limitation for USB cables. For example, you can use the B203-104 to
connect impact printers to a server in another room. This extender kit is also convenient for making
connections in areas without network availability.
By using Cat5/Cat6 cable to carry signals, the B203-104 extends your installation farther than is possible
with standard USB cables. Plus, Cat5/Cat6 cabling is readily available at low cost. For maximum signal
integrity, use solid-conductor Cat5/Cat6 UTP cabling, such as Tripp Lite’s N202-series. The B203-104
extender kit can achieve data transfer rates up to 480 Mbps. It’s backward compatible with USB 1.1
peripherals, but at USB 1.1 speeds. The B203-104 works with Windows through 10 operating systems
(not Mac compatible; for a Mac-compatible solution, choose Tripp Lite’s B203-104-PNP extender kit).
Mount the receiver hub to a wall, pole or rack with the included mounting hardware. Complies with the
Federal Trade Agreements Act (TAA) for GSA Schedule purchases.
1/3
Cleveland, OH 44122
United States
Features
Long-Distance Data Transfer to 4 Devices—Up to 328 ft. (100 m) from the Source
● Send data to as many as four USB 2.0 devices located up to 328 ft. from the source
USB signals travel over a single user-supplied Cat5/Cat6 cable
Includes transmitter and 4-port receiver hub
Supports data transfer rates up to 480 Mbps
Status LEDs indicate power and connection
Greater Distance over Cat5/Cat6 Cable Provides Greater Flexibility
● Cat5/Cat6 cabling exceeds the 16 ft. distance limitation of USB cables
Allows connection to devices that lack network connectivity in areas beyond the reach of standard USB
cables
Makes connections in areas where a network is not available
Allows source to be in a secure location, separate from peripherals
Cat5/Cat6 cabling is cost-effective and readily available
For best results, use solid-conductor Cat5/Cat6 UTP cable, such as Tripp Lite’s N202-series cable
Convenient Installation
● Driver is provided on the included CD; driver is also available for download on the product support page
Included 1 ft. USB A/B device cable connects source and transmitter
User-supplied Cat5/Cat6 cable connects transmitter and receiver hub
Receiver hub has an external power supply
Mount receiver hub to wall, rack or pole with included hardware
Widely Compatible
● Compatible with Windows XP through 10 (not Mac compatible; for a Mac-compatible solution, choose
Backward compatible with USB 1.1 devices (at USB 1.1 speeds)
TAA-Compliant
● Complies with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332171887
Technology
USB 2.0 (High Speed)
POWER
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A
PHYSICAL
2/3
Cleveland, OH 44122
United States
Color
Black
Shipping Dimensions (hwd / in.)
2.20 x 8.40 x 6.50
Shipping Dimensions (hwd / cm)
5.59 x 21.34 x 16.51
Shipping Weight (lbs.)
1.20
Shipping Weight (kg)
0.54
ENVIRONMENTAL
Storage Temperature Range
-20 to 60 C (-4 to 140 F)
Relative Humidity
20 to 90%
Operating Temperature
0 to 40 C (32 to 104 F)
CONNECTIONS
Number of Ports
4
Side A - Connector 1
USB B (FEMALE)
Side A - Connector 2
RJ45 (FEMALE)
Side B - Connector 1
(4) USB A (FEMALE)
Side B - Connector 2
RJ45 (FEMALE)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“B203-104”相匹配的价格&库存,您可以联系我们找货
