B013-330
B013-330
    TRIPPLITE
    CAT5CONSOLEEXTENDER330FT
B013-330 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cat5e KVM Console Extender Kit Highlights ● Manage a PS/2 or USB computer/KVM switch from a remote location up to 330ft (100m) away ● Use readily available Cat5e cable for interconnection MODEL NUMBER: B013-330 Package Includes Features ● Enables you to control a PS/2 or USB computer/KVM switch from a distance of up to 330ft (100m) away. ● Can control the computer or KVM switch via both Local and Remote Consoles. ● The remote connection is made using standard Cat5e cable ● Display mode of 1600 x 1200 @ 60Hz ● Shielded Cat5e cables provide better transmission integrity Specifications OVERVIEW UPC Code 037332143419 Accessory Type Extender Kit Technology PS/2; VGA/SVGA Accessory Class KVM Switch Accessories PRODUCT OVERVIEW Product Overview Cat5e KVM Console Extender Kit VIDEO Max Supported Video Resolution 1600 x 1200 @60Hz HDR Support No INPUT 1/4 ● Transmitter and Receiver Unit (1 each) ● 3-ft. PC/KVM Cable Kit (1) ● Power Adapter (DC9V, 1A) for Receiver Unit (1) ● 4-ft. (1.22 m) USB A-B Cable (1) ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 1A External Power Supply Output Specs (V / A) 9V / 1.33A External Power Supply Cord Length (ft.) 5 External Power Supply Cord Length (m.) 1.5 Power Over Cable (PoC) Support No DC Barrel Plug OD: 5.5 x 2.1 x 9.5mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 3.5 USER INTERFACE, ALERTS & CONTROLS LED Indicators Red (Power); Green (Link) PHYSICAL Color Silver Material of Construction Steel Rackmountable No Receiver Unit Dimensions (hwd / in.) 1 x 5.2 x 2.6 Receiver Unit Weight (lbs.) 1.3 Shipping Dimensions (hwd / in.) 5.40 x 6.90 x 8.00 Shipping Dimensions (hwd / cm) 13.72 x 17.53 x 20.32 Shipping Weight (lbs.) 2.60 Shipping Weight (kg) 1.18 Transmitter Unit Dimensions (hwd / in.) 1 x 5.2 x 2.6 Transmitter Unit Weight (lbs.) 1.3 Unit Packaging Type Box ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range -4 to 140 F (-20 to 60 C) Relative Humidity 0%-90% RH, Non-Condensing 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States BTUs 11.9 BTU/Hr COMMUNICATIONS IR Remote Extension Support No RS-232 Serial Extension Support No USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 (2) HD15 (FEMALE) Side A - Connector 2 RJ45 (FEMALE) Side A - Connector 3 USB B (FEMALE) Side A - Connector 4 (2) MINI DIN-6 (FEMALE) Side B - Connector 1 HD15 (FEMALE) Side B - Connector 2 RJ45 (FEMALE) Side B - Connector 3 (2) MINI DIN-6 (FEMALE) Computer Keyboard and Mouse Interface PS/2; USB Computer Monitor Interface VGA Console Keyboard and Mouse Interface PS/2 Console Monitor Interface VGA Connector Plating Nickel FEATURES & SPECIFICATIONS Recommended Category Cable Cat5/Cat5e Cables IP68 Rated No IP20 Rated No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; UL; cUL; TUV; CB Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
B013-330 价格&库存
很抱歉,暂时无法提供与“B013-330”相匹配的价格&库存,您可以联系我们找货
