1000 Eaton Boulevard
Cleveland, OH 44122
United States
USB VGA over Cat5 UTP KVM Console Extender
Kit - 500 ft. (152.4 m)
MODEL NUMBER: 0DT60001
Highlights
Extends the VGA video and
USB keyboard/mouse from your
computer or KVM switch
Console ports on both the
transmitter adn receiver units
allow for local or remote control
of the connected computer /
KVM switch
Receiver unit doubles as a 2port KVM switch, allowing for
the connection of a local
computer
Supports video resolutions up to
1600 x 1200 @ 75 Hz
System Requirements
Compatible with all major
operating systems
Compatible with any KVM
switch / computer
USB Keyboard and Mouse
PS/2 Keyboard and Mouse with
0DT60002 PS/2 to USB
Converter
When using the 0DT60001 to
extend the console ports of a
KVM switch, the transmitter unit
may require an external power
supply. Use a 12VDC 1A power
supply.
Features
Compatible with any KVM switch / computer
Extends console (USB keyboard, USB mouse and VGA monitor) up to 150m / 500ft from computer,
KVM or server
Integrated local port for local keyboard, mouse and monitor
2 port KVM switch built into remote unit
Pure hardware solution - no software/network conflicts
Supports high-resolution video - up to 1600 x 1200 @ 75 Hz
All cables included - off-the-shelf retail package, easy to maintain
Simple to install and operate
Package Includes
No external power needed at transmitter end
Supports all major OS
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
654518302196
1/4
Local Transmitter Unit
Remote Receiver Unit
(x2) VGA + USB KVM Cable
Kits
External Power Supply with
NEMA 1-15P Plug (Input: 100240V, 50/60Hz Output:
12V/1000mA) and Plug
Adapters for US, UK, Europe
and Australia, NEMA
Screwdriver
Rubber Feet
Owner's Manual
Cleveland, OH 44122
United States
Accessory Type
Extender Kit
Technology
VGA/SVGA
Accessory Class
KVM Switch Accessories
VIDEO
Max Supported Video Resolution
1600 x 1200 @75Hz
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 127; 200; 208; 220; 230; 240
Bus Powered
Yes
POWER
External Power Supply Plug(s)
NEMA 5-15P North America; CEE 7/16 Schuko; BS 1363 UK; AS/NZS 3112 Australia
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
12V / 1A
External Power Supply Cord Length
(ft.)
6
(m.)
1.8
Power Consumption (Watts)
12
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
TX: Green (Control), Red (Lock)
RX: Green (Local), Red (Lock)
PHYSICAL
Color
Gray
Material of Construction
Steel
Receiver Unit Dimensions (hwd /
cm.)
2.9 x 6.9 x 16.5
Receiver Unit Dimensions (hwd / in.)
1.1 x 2.7 x 6.5
Receiver Unit Weight (kg)
0.28
Receiver Unit Weight (lbs.)
0.61
Shipping Dimensions (hwd / in.)
4.10 x 8.00 x 12.40
Shipping Dimensions (hwd / cm)
10.41 x 20.32 x 31.50
Shipping Weight (lbs.)
3.80
Shipping Weight (kg)
1.72
Transmitter Unit Dimensions (hwd /
cm.)
2.9 x 6.9 x 16.5
2/4
Cleveland, OH 44122
United States
in.)
1.1 x 2.7 x 6.5
Transmitter Unit Weight (kg)
0.27
Transmitter Unit Weight (lbs.)
0.58
Unit Packaging Type
Box
ENVIRONMENTAL
Operating Temperature Range
32 to 104 F (0 to 40 C)
Storage Temperature Range
-40 to 158 F (-40 to 70 C)
Relative Humidity
0% to 80% RH, Non-Condensing
BTUs
40.9 BTU/Hr
COMMUNICATIONS
Signal Range (ft.)
500
Signal Range (m)
152
EDID Compatible
Yes
CONNECTIONS
Number of Ports
2
PC/Server Connections
VGA; USB; PS/2
Side A - Connector 1
(2) HD15 (FEMALE); RJ45 (FEMALE); (2) USB A (FEMALE)
Side B - Connector 1
Connector Plating
Nickel
FEATURES & SPECIFICATIONS
Port Selection
Pushbutton
Recommended Category Cable
Cat5/Cat5e/Cat6
IP68 Rated
No
IP20 Rated
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
CE; UL; CCC; PSE; C-Tick; GS; RoHS
Product Certifications
ICES (Canada); C-Tick (Australia)
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
3/4
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“0DT60001”相匹配的价格&库存,您可以联系我们找货
