WWSSDT
WWSSDT
    TRIPPLITE
    SIT STAND DESKTOP WORKSTATION HE
WWSSDT 数据手册
Height-Adjustable Sit-Stand Desktop Workstation MODEL NUMBER: WWSSDT Highlights ● Height adjustment from 6.3 to 17.5 in to hlep you find your ideal working position ● Easy one-touch paddle allows for smooth transition from sitting to standing in seconds ● large 23.6 x 15.7 in rectangular surface supports monitor and other items up to 28.6 lbs ● Keyboard tray holds the largest, most popular models ● Maximum weight capacity is 28.6 for monitor surface and 4.4 for keyboard Package Includes Adapt a traditional desk for sit-stand ergonomics without modifying the entire work surface. Place this workstation on a flat surface, and adjust the height of your monitor and keyboard for different working positions. Description Tripp Lite’s WWSSDT Standing Desktop Workstation allows you to enjoy the benefits of standing for a portion of the day without using your entire work surface. Simply place the WWSSDT on a fixed-height desk or table. With a single touch, you can change the height of your monitor and keyboard to improve ergonomics, promote health and increase productivity. To adjust the height of the WWSSDT, press the lever to raise or lower the pneumatic spring arm. The monitor platform and keyboard move together to provide smooth transitions between sitting and standing. An adjustment on the rear of the workstation gives you the option to increase tension for heavier loads or decrease it for lighter items. The WWSSDT has a heavy-duty base that’s only 19.3 x 13.8 inches, so it doesn’t occupy your entire work surface. The base provides stability at all workstation heights, yet it can be easily moved or repositioned. Maximum weight capacity is 28.6 pounds. Monitor platform is 23.6 x 15.7 inches and adjusts between 6.3 and 17.5 inches above the work surface. It’s sturdy enough to support a dual-arm display mount. Integrated cable management reduces cable clutter. Keyboard tray is an oversized 26 x 8.5 inches to accommodate the some of the largest, most popular models. Features One-Touch Height Adjustment for Sit-Stand Ergonomics ● Lever raises or lowers pneumatic arm for smooth height adjustment ● Monitor platform and keyboard tray move together for seamless sit-stand transitions ● Use included hex key to increase or decrease tension according to load ● Maximum weight capacity is 29 lb. Base Requires Minimal Desk Space ● Small 19.3 x 13.8 in. footprint ● Place on a flat fixed-height work surface ● Provides stability at all workstation heights 1/2 ● Workstation (base, arm, monitor platform) ● (2) M6 x 10 screws ● (2) Hole plugs ● Large hex key ● Small hex key ● Owner’s manual Monitor Platform ● 23.6 x 15.7 in. for flat-panel display, laptop or display mount ● Adjusts between 6 and 17.5 in. above the work surface ● Integrated cable management reduces cable clutter Keyboard Tray ● Extra-large 26 x 8.5 in. tray holds the most of the largest and most popular models ● Adjusts up to 17 in. above the work surface Specifications OVERVIEW UPC Code 037332196859 Device Compatibility Monitor/HDTV; Computer; Laptop PHYSICAL Color Black Mounting Location Desktop Maximum Weight Capacity (lbs.) 29 Maximum Weight Capacity (kg) 13 Number of Displays 1 Shipping Dimensions (hwd / in.) 7.20 x 29.00 x 27.50 Shipping Dimensions (hwd / cm) 18.29 x 73.66 x 69.85 Shipping Weight (lbs.) 52.00 Shipping Weight (kg) 23.59 Unit Dimensions (hwd / in.) 17.5 x 23.6 x 24.2 FEATURES & SPECIFICATIONS Cord Management No Antimicrobial No Tools Necessary Yes WARRANTY Product Warranty Period (Worldwide) 5-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
WWSSDT 价格&库存
很抱歉,暂时无法提供与“WWSSDT”相匹配的价格&库存,您可以联系我们找货
