1000 Eaton Boulevard
Cleveland, OH 44122
United States
HDBaseT HDMI Over Cat5e/6/6a Extender Kit
with Serial and IR Control, 4K x 2K 30 Hz UHD /
1080p 60 Hz, Up to 328 ft. (100 m)
Highlights
Extends a 1080p @ 60 Hz
signal up to 328 feet (100 m)
Extends both a 4096 x 2160 and
3840 x 2160 (4K x 2K) @ 30Hz
Supports 7.1-channel surround
sound, DTS-HD and Dolby
TrueHD
Controls RS-232 serial devices
at baud rates up to 115 Kbps
Allows you to control a Blu-ray™
player from a remote monitor
MODEL NUMBER: BHDBT-K-SI-LR
Package Includes
Transmit HDMI video and audio, RS-232 serial and IR Remote Control signals over a single Cat5e/6/6a
cable to a projector, monitor or television. Ideal for digital signs and trade show presentations.
Transmitter unit
Receiver unit
IR-IN cable
IR-OUT cable
3.5 mm Male to DB9 Female
adapter cable
3.5 mm Male to DB9 Male
adapter cable
(2) External Power Supplies with
NEMA 1-15P Plug(Input:
100–240V, 50/60 Hz, 0.5A;
Output: 5V, 3A)
Mounting hardware
Owner’s manual
Features
Supports the Latest Video and Audio Applications
● Extends a High Definition 1920 x 1080 (1080p) @ 60 Hz signal up to 328 feet (100 m)
Extends an Ultra High Definition (UHD) 4096 x 2160 or 3840 x 2160 (4K x 2K) @ 30Hz signal up to
328 feet (100 m)
Accepts up to five BHDBT-TR-SI-LR transceivers and six total monitors to further expand the range
up to 2,000 feet (600 m)
Supports 7.1-channel surround sound, DTS-HD and Dolby TrueHD audio
Supports 36-bit Deep Color (12 bits per channel), CEC pass-through, 3D video, EDID and HDCP
Allows You to Control Other Display Devices
● 2-way 39 KHz IR Remote Control functionality lets you control your Blu-ray player with its remote
while standing at the remote monitor (and vice versa)
RS-232 serial port supports 115 Kbps full-duplex baud rates for scanners and touchscreen monitors
Easy to Set Up and Use
● Plug-and-play engineering means no software or drivers to download and install
Ready to use in minutes
Included mounting hardware lets you install each unit on a wall, rack or pole
Locking HDMI ports (for use with Tripp Lite High Speed HDMI cables with locking connectors, such
as P569-006-LOCK) on both the transmitter and receiver prevent cables from coming loose or
disconnected, ensuring an intact signal
TAA-Compliant
● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
1/5
Cleveland, OH 44122
United States
Specifications
OVERVIEW
UPC Code
037332187093
Product Type
Extender Kit
Technology
HDBaseT; HDMI; IR; Cat5/5e; Cat6
VIDEO
Max Supported Video Resolution
3840x2160 (4K @ 30Hz)
Max 720P Range (ft)
328
Max 1080P Range (ft)
328
Max 1280 x 720 (720p) Range (ft)
328
Max 1920 x 1080 (1080p) Range (ft)
328
Max 1920 x 1200 Range (ft)
328
Max 2560 x 1600 Range (ft)
328
Max 3840 x 2160 (4K@30Hz)
Range (ft)
328
Transmitter Video Input
HDMI
Receiver/Transceiver Video Output
HDMI
Receiver - Number of Video Outputs
1
Recommended Cabling
HDMI
Max Supported Color Depth
36-bit Deep Color
HDR Support
No
3D Video Supported
Yes
Maximum Signal Range (ft)
328
Maximum Signal Range (m)
100
AUDIO
Audio Input
HDMI
Audio Output
HDMI
Audio Specification
7.1 Channel Surround Sound, DTS-HD and Dolby TrueHD
INPUT
Bus Powered
No
POWER
2/5
Cleveland, OH 44122
United States
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 0.5A
External Power Supply Output
Specs (V / A)
5V / 3A
External Power Supply Cord Length
(ft.)
4.5
(m.)
1.4
AC Plug Type
NEMA 1-15P
Power Source
Transmitter and Receiver (Included)
Power Over Cable (PoC) Support
No
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 3A
DC Barrel Plug
OD: 5.5 x 2.1 x 7.5mm, Positive Pin, Negative Sleeve
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
GREEN UNIT LED INDICATES POWER / GREEN RJ45 LED's INDICATE HDCP IS WORKING / ORANGE UNIT
LED INDICATES HDBASET SYSTEM ACTIVATION / ORANGE RJ45 LED's INDICATE HDBASET LINK
PHYSICAL
Color
Black
Included Mounting Accessories
Wallmount
Number of Displays
1
Optional Mounting Accessory Notes
Can DIN Mount using Tripp Lite Bracket B110-DIN-01
Form Factor/Mounting Options
Box; Wall-mount
Receiver Unit Dimensions (hwd / in.)
2.46 x 4.53 x 1.06
Receiver Unit Height (in.)
1.1
Receiver Unit Width (in.)
4.5
Receiver Unit Depth (in.)
1.1
Receiver Unit Weight (lbs.)
1.01
Shipping Dimensions (hwd / in.)
2.20 x 11.40 x 6.50
Shipping Dimensions (hwd / cm)
5.59 x 28.96 x 16.51
Shipping Weight (lbs.)
2.50
Shipping Weight (kg)
1.13
Transmitter Unit Depth (in.)
2.5
Transmitter Unit Dimensions (hwd /
in.)
2.46 x 4.53 x 1.06
Transmitter Unit Height (in.)
1.1
3/5
Cleveland, OH 44122
United States
Transmitter Unit Weight (lbs.)
1.01
Transmitter Unit Width (in.)
4.5
0.000 x 0.000 x 0.000
Unit Packaging Type
Box
Unit Weight (lbs.)
1.01
Unit Weight (kg)
0.46
Unit Weight Details
0.55lbs (Transmitter) 0.5lbs (Receiver
Housing
Metal
ENVIRONMENTAL
Operating Temperature Range
32 to 104 F (0 to 40)
Storage Temperature Range
5 TO 122F (-15 TO 50 C)
Relative Humidity
0% TO 85% RH, Non-Condensing
Operating Humidity Range
Storage Humidity Range
COMMUNICATIONS
Max 1024 x 768 Range (ft)
328
Max 480P Range (ft)
328
Max 1440 x 900 Range (ft)
328
Max 1080i Range (ft)
328
Max 1920 x 1440 Range (ft)
328
Max 4K UHD Range (ft)
328
Max 480i Range (ft)
328
Max 640 x 480 Range (ft)
328
Max 800 x 600 Range (ft)
328
Max 1600 x 1200 Range (ft)
328
Max 2048 x 1536 Range (ft)
328
EDID Compatible
Yes
IR Remote Extension Support
Yes
RS-232 Serial Extension Support
Yes
Consumer Electronics Control (CEC)
Supported
Yes
USB Extension Support
No
CONNECTIONS
Number of Ports
1
4/5
Cleveland, OH 44122
United States
Side A - Connector 1
HDMI (FEMALE)
Side A - Connector 2
RJ45 (FEMALE)
Side B - Connector 1
HDMI (FEMALE)
Side B - Connector 2
RJ45 (FEMALE)
Side B - Connector 3
DB9 (MALE)
FEATURES & SPECIFICATIONS
HDCP Specification
1.4
Driver Required
No
10/100 Ethernet Extension Support
No
Built-In Equalizer
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
UL; cUL; RoHS; FCC
Product Compliance
RoHS; REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“BHDBT-K-SI-LR”相匹配的价格&库存,您可以联系我们找货
