BHDBT-K-SI-ER
BHDBT-K-SI-ER
    TRIPPLITE
    HDBASET HDMI OVER CAT5E EXTENDER
BHDBT-K-SI-ER 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HDBaseT HDMI Over Cat5e/6/6a Extender Kit with Serial and IR Control, 1080p, Up to 500 ft. (152.4 M) Highlights ● Extends a 1080p @ 60 Hz signal up to 500 feet (150 m) ● Supports 7.1-channel surround sound, DTS-HD and Dolby TrueHD ● Controls RS-232 serial devices at baud rates up to 115 Kbps ● Allows you to control a Blu-ray™ player from a remote monitor ● Plug and play—no software or drivers to install MODEL NUMBER: BHDBT-K-SI-ER Package Includes Transmit HDMI video and audio, RS-232 serial and IR Remote Control signals over a single Cat5e/6/6a cable to a projector, monitor or television. Ideal for digital signs and trade show presentations. ● Transmitter unit ● Receiver unit ● IR-IN cable ● IR-OUT cable ● 3.5 mm Male to DB9 Female adapter cable ● 3.5 mm Male to DB9 Male adapter cable ● (2) External Power Supplies with NEMA 1-15P Plug(Input: 100–240V, 50/60 Hz, 0.5A; Output: 5V, 3A) ● Mounting hardware ● Owner’s manual Features Supports the Latest Video and Audio Applications ● Extends a High Definition 1920 x 1080 (1080p) @ 60 Hz signal up to 500 feet (150 m) ● Accepts up to five BHDBT-TR-SI-ER transceivers and six total monitors to further expand the range up to 3,000 feet (900 m) ● Supports 7.1-channel surround sound, DTS-HD and Dolby TrueHD audio ● Supports 36-bit Deep Color (12 bits per channel), CEC pass-through, 3D video, EDID and HDCP Allows You to Control Other Display Devices ● 2-way 39 KHz IR Remote Control functionality lets you control your Blu-ray player with its remote while standing at the remote monitor (and vice versa) ● RS-232 serial port supports 115 Kbps full-duplex baud rates for scanners and touchscreen monitors Easy to Set Up and Use ● Plug-and-play engineering means no software or drivers to download and install ● Ready to use in minutes ● Included mounting hardware lets you install each unit on a wall, rack or pole ● Locking HDMI ports on both the transmitter and receiver prevent cables from coming loose or disconnected, ensuring an intact signal TAA-Compliant ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332187086 Technology HDBaseT; HDMI; IR VIDEO Max 720P Range (ft) 500 Max 1080P Range (ft) 500 HDR Support No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.5A External Power Supply Output Specs (V / A) 5V / 3A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.4 Power Over Cable (PoC) Support No AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 3A PHYSICAL Color Black Included Mounting Accessories Y Receiver Unit Height (in.) 1.1 Receiver Unit Width (in.) 4.5 Receiver Unit Depth (in.) 1.1 Shipping Dimensions (hwd / in.) 2.20 x 11.40 x 6.50 Shipping Dimensions (hwd / cm) 5.59 x 28.96 x 16.51 Shipping Weight (lbs.) 2.50 Shipping Weight (kg) 1.13 Transmitter Unit Depth (in.) 2.5 Transmitter Unit Height (in.) 1.1 Transmitter Unit Width (in.) 4.5 Unit Weight Details 0.55lbs (Transmitter) 0.5lbs (Receiver 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Operating Temperature Range 0 to 40 C (32 to 104 F) Storage Temperature Range -20 to 60 C (-4 to 140 F) Relative Humidity 20 to 90% COMMUNICATIONS Max 1024 x 768 Range (ft) 500 Max 480P Range (ft) 500 Max 1440 x 900 Range (ft) 500 Max 1080i Range (ft) 500 Max 480i Range (ft) 500 Max 640 x 480 Range (ft) 500 Max 800 x 600 Range (ft) 500 Max 1600 x 1200 Range (ft) 500 IR Remote Extension Support Yes RS-232 Serial Extension Support Yes USB Extension Support No CONNECTIONS Number of Ports 1 Side A - Connector 1 HDMI (FEMALE) Side A - Connector 2 RJ45 (FEMALE) Side B - Connector 1 HDMI (FEMALE) Side B - Connector 2 RJ45 (FEMALE) Side B - Connector 3 DB9 (MALE) FEATURES & SPECIFICATIONS 10/100 Ethernet Extension Support No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
BHDBT-K-SI-ER 价格&库存
很抱歉,暂时无法提供与“BHDBT-K-SI-ER”相匹配的价格&库存,您可以联系我们找货
