WWBASE-GY
WWBASE-GY
    TRIPPLITE
    SITSTANDADJUSTABLEELECTRICDE
WWBASE-GY 数据手册
WorkWise Standing Desk Base, Electric Adjustable-Height, Gray MODEL NUMBER: WWBASE-GY Highlights ● Steel construction with gray powder-coated finish ● Height adjusts in precise 0.1 in. increments from 23.5 to 49 in. ● Width adjusts to fit all WorkWise Desk Tops (sold separately) ● Create up to 4 convenient preset positions ● Electric motor adjusts height 1.5 in. per second Package Includes WWBASE-GY (Base Only) ● Control box Electric adjustable-height desk base attaches to a desk top (sold separately) to create a more ergonomic workspace that accommodates sitting, standing and the comfort of different users. Description Tripp Lite's WWBASE-GY WorkWise™ Standing Desk Base lets you change the height of your workspace at the touch of a button. The DC linear actuator motor lifts or lowers a desk top at a speed of 1.5 inches per second. Base height adjusts from 23.5 to 49 inches in precise 0.1-inch increments for standing and sitting positions perfectly customized for your comfort. The included control handset mounts beneath a desk top and connects to the motor. It features buttons for up/down movement and a digital readout that displays height in inches. You can create up to four ● Handset ● (2) Legs ● (2) Feet ● (2) Frame ends ● (2) Center rails ● (2) Side brackets ● (8) M6 x 10 screws ● (16) M6 x 14 screws ● (4) M6 x 35 screws ● (7) M5 x 20 wood screws ● (2) M5 x 16 wood screws ● (10) Cable clips ● Hex key, 4 mm ● AC power cord w/NEMA 1-15 plug, 10-ft. (3.05 m) ● Male-to-female extension cable, 4.3-ft. (1.31 m) ● Owner's manual convenient preset positions, making it easy to instantly adjust the WWBASE-GY to the perfect height for you, as well as the officemate who shares your workspace. You can also set upper and lower limits if you prefer a narrower range of heights. The WWBASE-GY is made of steel with a gray powder-coated finish. You can adjust its width between 42.5 and 72 inches to accommodate a variety of desk tops (sold separately). It perfectly matches the threaded mounting inserts on Tripp Lite WorkWise Desk Tops, including WWTOP48-BK, WWTOP48-ES, WWTOP60-BKC, WWTOP60-ESC, WWTOP60-WHC, WWTOP72-BK and WWTOP72-ES. Pre-installed leveling feet keep it stable on uneven floors. Includes a 10-ft. (3.05 m) power cord with two-prong plug that connects to a 120V AC outlet. Meets ANSI/BIFMA X5.5-2014 standards. Maximum load capacity of 365 lbs (165.6 kgs.). Assembles in less than 30 minutes. Features Precise Electric Height Adjustment ● Height adjusts in precise 0.1 in. increments from 23.5 to 49 in. ● Powerful DC linear actuator motor moves base legs 1.5 in. per second 1/3 ● Create up to 4 convenient preset positions for one-touch adjustment ● Set programmable upper and lower height limits ● 10-ft. (3.05 m) power cord with two-prong plug connects to 120V AC outlet Control Handset ● Digital readout displays height in inches ● Up/down buttons adjust height with just a touch ● Mounts beneath desk top Width Adjusts to Fit a Variety of Desk Tops (Sold Separately) ● Width adjusts from 42.5 to 72 in. ● Base perfectly matches threaded mounting inserts on Tripp Lite WorkWise Desk Tops, including WWTOP48-BK, WWTOP48-ES, WWTOP60-BKC, WWTOP60-ESC, WWTOP60-WHC, WWTOP72-BK and WWTOP72-ES Durable Construction ● Made of steel with a gray powder-coated finish ● Pre-installed leveling feet for stability on uneven floors ● Meets ANSI/BIFMA X5.5-2014 standards ● Maximum load capacity of 365 lbs (165.6 kgs) ● Assembles in less than 30 min. Specifications OVERVIEW UPC Code 037332196873 INPUT Voltage Compatibility (VAC) 120 Input Frequency 60 Hz PHYSICAL Color Gray Maximum Weight Capacity (kg) 166 Maximum Weight Capacity (lbs.) 365 Shipping Dimensions (hwd / cm) 104.14 x 24.38 x 25.40 Shipping Dimensions (hwd / in.) 41.00 x 9.60 x 10.00 Shipping Weight (kg) 29.94 Shipping Weight (lbs.) 66.00 Standing Desk Base Color Gray Unit Dimensions (hwd / cm) 59.69-124.46 x 107.95-182.88 x 57.51 2/3 Unit Dimensions (hwd / in.) 23.5-49 x 42.5-72 x 22.64 Unit Weight (kg) 24.95 Unit Weight (lbs.) 55 STANDARDS & COMPLIANCE Certifications UL 1004-7, UL 1004-1, UL 508:1999, CSA C22.2 100-04, CSA C22.2 77-95, CSA C22.2 14-10 Approvals ANSI/BIFMA X5.5-2014 WARRANTY Product Warranty Period (U.S. & Canada) 5-year limited warranty © 2021 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
WWBASE-GY 价格&库存
很抱歉,暂时无法提供与“WWBASE-GY”相匹配的价格&库存,您可以联系我们找货
