1000 Eaton Boulevard
Cleveland, OH 44122
United States
HDBaseT HDMI over Cat5e/6/6a 4x4 Extender
Matrix Transmitter, Serial and IR, 4K x 2K 30 Hz
UHD / 1080p 60 Hz, 4 Input, 4 Output, TAA
Highlights
Features 4 HDMI input ports
and 4 RJ45 output ports
Supports video resolutions up to
4096 x 2160 and 3840 x 2160
(4K x 2K) @ 30Hz*
Supports 7.1-channel surround
sound, DTS-HD and Dolby
TrueHD
Mounts easily to wall, rack or
pole
Plug and play—no software or
drivers to install
MODEL NUMBER: BHDBT-T-SI-4X4
Package Includes
Works with a Tripp Lite HDBaseT receiver to extend uncompressed HDMI video and audio, RS-232 serial
and IR remote control signals over a Cat5e/6/6a cable up to 500 ft. to 4 projectors, monitors or televisions.
Description
The BHDBT-T-SI-4X4 HDBaseT HDMI over Cat5e/6/6a 4x4 Extender Matrix Transmitter works in tandem
with the Tripp Lite BHDBT-Series receiver in your HDBaseT installation to extend uncompressed HDMI
video and audio, RS-232 serial and IR remote control signals. It features four HDMI input ports and four
RJ45 output ports, letting you route any source to any display or the same source to all displays.
Using a single Cat5e/6/6a cable, the BHDBT-T-SI-4X4 can extend an Ultra High Definition (UHD) 4096 x
2160 or 3840 x 2160 (4K x 2K) @ 30Hz signal up to 328 feet (100 m) or a high-definition 1920 x 1080
(1080p) @ 60 Hz signal up to 500 feet (150 m). To further extend and expand your installation, you can
insert up to five BHDBT-Series Extender Transceivers between the transmitter and receiver for a total
range up to 3,000 feet with a monitor connected to each transceiver.** The sources connect to locking
HDMI ports that prevent the cable from coming loose or undone, ensuring an intact signal.
The BHDBT-T-SI-4X4 supports 7.1-channel surround sound, DTS-HD and Dolby TrueHD audio, as well
as 3D video, EDID and HDCP. Included mounting hardware lets you attach the unit to a wall, rack or pole.
Sets up quickly with no software to download or install.
** Maximum supported extension distance and video resolutions depend on the receivers and/or
transceivers being used. See the receiver (BHDBT-R-SI, BHDBT-R-SI-ER, BHDBT-R-SI-LR) and
transceiver (BHDBT-TR-SI, BHDBT-TR-SI-ER, BHDBT-TR-SI-LR) pages for details.
Features
Supports the Latest Video and Audio Applications
● Connects to Tripp Lite BHDBT-Series receivers and transceivers with a single Cat5e/6/6a cable
Extends a 1920 x 1080 (1080p) @ 60 Hz signal up to 500 ft. (150 m)***
Extends an Ultra High Definition (UHD) 4096 x 2160 or 3840 x 2160 (4K x 2K) @ 30Hz signal up to 328
ft. (100 m)***
Supports 7.1-channel surround sound, DTS-HD and Dolby TrueHD audio
Supports 36-bit Deep Color (12 bits per channel), CEC pass-through, 3D video, EDID and HDCP 2.0
Add up to 5 BHDBT-Series Extender Transceivers to further expand the range of your installation up to
3,000 feet (1080p) with a monitor attached to each transceiver***
1/5
Remote control
IR extension cable
3.5 mm Male to DB9 Female
adapter cable
External power supply w/C14
Socket (Input: 100–240V, 50/60
Hz, 1.5A; Output: 12V, 5A)
C13 to 5-15P Power Cord - 6-ft
Mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
4 HDMI Input Ports and 4 RJ45 Output Ports
● Can route any source to any display or the same source to all displays
Control inputs and outputs using unit pushbuttons, included remote control or your computer’s Terminal
Emulation Software
Allows You to Control Other Devices
● 2-way 39 KHz IR Remote Control functionality lets you control your Blu-ray player with its remote while
standing at the remote monitor (and vice versa)
RS-232 serial port supports 115 Kbps full-duplex baud rates for devices such as scanners and
touchscreen monitors
Easy to Set Up and Use
● Plug-and-play engineering—no software or drivers to download and install
Included mounting hardware lets you install each unit on a wall, rack or pole
Locking HDMI ports (ideal for use with Tripp Lite’s P569-006-LOCK HDMI cables) prevent cables from
coming loose or disconnected, ensuring an intact signal
P054-006 (EU) and P056-006-10A (UK) power cords (sold separately) available for international use
TAA-Compliant
● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332186997
Product Type
Transmitter
Technology
HDBaseT; HDMI; IR; Cat5/5e; Cat6
Host Connector
(4) HDMI (FEMALE)
VIDEO
Video Input
HDMI (FEMALE)
Video Output
HDMI (FEMALE)
Max Supported Video Resolution
3840x2160 (4K @ 30Hz)
Max 720P Range (ft)
500
Max 1080P Range (ft)
500
Max 1280 x 720 (720p) Range (ft)
500
Max 1920 x 1080 (1080p) Range (ft)
500
Max 1920 x 1200 Range (ft)
500
Max 2560 x 1600 Range (ft)
328
2/5
Cleveland, OH 44122
United States
Max 3840 x 2160 (4K@30Hz)
Range (ft)
328
Transmitter Video Input
HDMI
Recommended Cabling
HDMI
Max Supported Color Depth
36-bit Deep Color
HDR Support
No
3D Video Supported
Yes
Maximum Signal Range (ft)
500
Maximum Signal Range (m)
152
AUDIO
Audio Input
HDMI
Audio Output
HDMI
Audio Specification
7.1 Channel Surround Sound, DTS-HD and Dolby TrueHD
INPUT
Nominal Input Voltage(s) Supported
100V AC; 110V AC; 115V AC; 120V AC; 127V AC; 140V AC; 200V AC; 208V AC; 220V AC; 230V AC; 240V AC
Input Frequency
50/60Hz
Input Current
120V (1.3A) / 230V (0.7A)
Bus Powered
No
POWER
Power Source Type
AC Adapter
External Power Supply Plug(s)
NEMA 1-15P North America
External Power Supply Input Specs
(V / Hz / A)
100-240V / 50/60Hz / 1.5A
External Power Supply Output
Specs (V / A)
12V / 5A
External Power Supply Cord Length
(ft.)
6
(m.)
1.83
AC Plug Type
NEMA 5-15P
Power Source
Unit (Included)
Power Over Cable (PoC) Support
No
AC Adapter
Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 3A
PHYSICAL
Color
Black
3/5
Cleveland, OH 44122
United States
Included Mounting Accessories
Rackmount
Number of Displays
4
Form Factor/Mounting Options
Box; Rackmount
Shipping Dimensions (hwd / in.)
2.80 x 6.20 x 20.90
Shipping Dimensions (hwd / cm)
7.11 x 15.75 x 53.09
Shipping Weight (lbs.)
5.60
Shipping Weight (kg)
2.54
Transmitter Unit Dimensions (hwd /
in.)
1.7 x 17.3 x 4.7
Transmitter Unit Weight (lbs.)
3.5
Unit Dimensions (hwd / in.)
1.700 x 17.300 x 4.700
Unit Packaging Type
Box
Unit Weight (lbs.)
3.5
Unit Weight (kg)
1.59
Unit Weight Details
3.50
Housing
Metal
ENVIRONMENTAL
Operating Temperature Range
0 to 40 C (32 to 104 F)
Storage Temperature Range
-20 to 60 C (-4 to 140 F)
Relative Humidity
20 to 90%
Operating Humidity Range
20 to 90%
Storage Humidity Range
20 to 90%
COMMUNICATIONS
Max 1024 x 768 Range (ft)
500
Max 480P Range (ft)
500
Max 1440 x 900 Range (ft)
500
Max 1080i Range (ft)
500
Max 1920 x 1440 Range (ft)
328
Max 4K UHD Range (ft)
328
Max 480i Range (ft)
500
Max 640 x 480 Range (ft)
500
Max 800 x 600 Range (ft)
500
Max 1600 x 1200 Range (ft)
500
EDID Compatible
Yes
4/5
Cleveland, OH 44122
United States
IR Remote Extension Support
Yes
RS-232 Serial Extension Support
Yes
Consumer Electronics Control (CEC)
Supported
Yes
USB Extension Support
No
CONNECTIONS
Number of Ports
4
Side A - Connector 1
(4) HDMI (FEMALE)
Side A - Connector 2
DB9 (FEMALE)
Side B - Connector 1
(4) RJ45 (FEMALE)
FEATURES & SPECIFICATIONS
HDCP Specification
1.4
Driver Required
No
10/100 Ethernet Extension Support
No
Built-In Equalizer
No
STANDARDS & COMPLIANCE
External Power Supply Certifications
UL; cUL; PSE; FCC; CE; TUV; NOM; RoHS; WEEE
Product Compliance
RoHS; REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
1-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“BHDBT-T-SI-4X4”相匹配的价格&库存,您可以联系我们找货
