B078-001-PS2
B078-001-PS2
    TRIPPLITE
    MODULE INTERFACE PS2 CAT5E
B078-001-PS2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States KVM Switch Accessories - NetCommander PS2 Server Interface Module Highlights ● Needed to connect a PS/2 Server to a B072-Series NetCommander KVM switch via Cat5e cable ● Easy to install; no software needed ● No power supply needed ● Allows a recommended maximum distance of 35ft from KVM to Server via Cat5e cable ● Compact and lightweight design MODEL NUMBER: B078-001-PS2 System Requirements ● Server or CPU with a HD15 port and (2) PS/2 type connections ● A B072-Series NetCommander Cat5 KVM Switch ● Cat5e/6 cable; up to 35ft Package Includes ● Description Tripp Lite's NetCommander PS/2 Server Interface Module connects to the HD15 port and PS/2 ports on a computer/server, and converts them to a single RJ45 connector. Ordinary Cat5e patch cables can then be used to connect the computer/server to the switch ports on a Tripp Lite B072-Series NetCommander Cat5 KVM switch. Use of Cat5e cables frees up space in the installation that would be filled by traditional, thicker KVM cables. Features ● Eliminates the need for thicker, heavier KVM cables ● Compact, lightweight design ● Plug and Play; no software required ● No power supply required ● Allows a Server/CPU to be located up to 35ft away from the KVM switch Specifications OVERVIEW UPC Code 037332127501 PHYSICAL Shipping Dimensions (hwd / in.) 1.00 x 6.50 x 6.50 Shipping Dimensions (hwd / cm) 2.54 x 16.51 x 16.51 Shipping Weight (lbs.) 0.30 Shipping Weight (kg) 0.14 1/2 1 PS/2 Server Interface Module 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Side B - Connector 1 HD15 (MALE) Side B - Connector 2 (2) MINI DIN-6 (MALE) © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B078-001-PS2 价格&库存
很抱歉,暂时无法提供与“B078-001-PS2”相匹配的价格&库存,您可以联系我们找货
