0DT23008
0DT23008
    TRIPPLITE
    MINICOMKVMCONSOLESWITCHEXT
0DT23008 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Mini PS2 VGA over Cat5 UTP KVM Console Extender Kit - 230-ft. Highlights ● More security - Look after your investment by storing computers in locked, environmentally controlled room ● More flexibility - Place your KVM console where you want it and your computer where you need it ● More efficiency - Make your set up work for you instead of you working for your set up ● Plug and play solution ● Compatible with any KVM switch/computer - extends console 70m / 230ft from server room or rack ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: 0DT23008 System Requirements Description ● Compatible with all major operating systems ● Compatible with any KVM switch / computer ● PS/2 Keyboard and Mouse The Mini KVM Extender PS/2 is a high value, affordable solution for extending your KVM console from your computer or KVM switch to a distance of up to 70m / 230ft away over clutter free CAT5/6/7 cables. If you're working from a small, home office (SOHO), the Mini KVM Extender PS/2 is your preferred extended control solution - just place the KVM console where you want and the computer where you need and you're all set to go! Package Includes ● Local Transmitter Unit ● Remote Receiver Unit ● External Power Supply for Receiver Unit NEMA 1-15P Plug (Input: 100-240V, 50/60Hz Output: DC5V/1000mA) ● Owner's Manual For industrial applications such as manufacturing lines or clean rooms, the Mini KVM Extender PS/2 provides maximum safety and security, allowing you to place computers and servers in a single centralized location, far away from any production hazards. IT managers seeking extended access to server rooms in a tightly secured environment will find the Mini KVM Extender PS/2 particularly efficient and easy to use. Ideal also for presentation and training applications, the Mini KVM Extender PS/2 provides flexibility and security coupled with highly attractive pricing. The Mini KVM Extender PS/2 is made up of 2 micro sized, compact units on both ends: the Transmitter unit that connects to the computer and the Receiver unit that connects to the KVM hardware. The Mini KVM Extender PS/2 is a pure hardware solution, making it both software and network independent. Features ● More security - Look after your investment by storing computers in locked, environmentally controlled room ● More flexibility - Place your KVM console where you want it and your computer where you need it ● More efficiency - Make your set up work for you instead of you working for your set up ● Preserve your investment - Perfect add-on for existing installations - Extend a KVM console 70m / 230ft 1/3 1000 Eaton Boulevard Cleveland, OH 44122 United States from server room, rack or KVM switch ● Plug and play solution ● Micro sized - Smallest form factor for sleek Transmitter and Receiver units. Once installed you won't even know they exist! ● Compatible with any KVM switch/computer - extends console 70m / 230ft from server room or rack ● Simple to install and operate ● No external power needed at transmitter end ● Supports all major OS ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 654518301656 Accessory Type Extender Kit POWER AC Adapter (Input: 100-240V, 50/60Hz Output: DC5V/100mA) PHYSICAL Color Black Shipping Dimensions (hwd / in.) 4.00 x 6.50 x 6.00 Shipping Dimensions (hwd / cm) 10.16 x 16.51 x 15.24 Shipping Weight (lbs.) 1.20 Shipping Weight (kg) 0.54 ENVIRONMENTAL Storage Temperature Range -40 to 70 C / -40 to 158 F Operating Temperature 0 to 40 C / 32 to 104 F CONNECTIONS PC/Server Connections VGA; PS/2 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
0DT23008 价格&库存
很抱歉,暂时无法提供与“0DT23008”相匹配的价格&库存,您可以联系我们找货
