U357-025-R
U357-025-R
    TRIPPLITE
    2.5"SATAHARDDRIVEENCLOSURE
U357-025-R 数据手册
USB 3.0 SuperSpeed External 2.5" SatA III Hard Drive Enclosure with Built-in Cable MODEL NUMBER: U357-025-R Highlights ● Supports data transfer rates up to 5Gbps ● Lightweight, compact design, ideal for portable storage ● Windows, Mac, and Linux compatible, Plug and Play ● Accepts most Manufacturers 2.5" SATA Hard Drives ( see "Features" tab, "System Requirements" ) System Requirements ● Available USB 3.0 "A" ( or USB 2.0 / 1.1 ) Computer or Hub port ● Compatible with Windows, Mac, and Linux ● 2.5" SATA hard drive must be able to operate on the power provided by the USB port (USB 3.0 provides up to 900mA, USB 2.0 up to 500mA) ● 2.5" SATA hard drive with a maximum height of 9.5mm. Description Tripp Lite's U357-025-R is an inexpensive way to create an external USB storage drive for laptop / notebook / netbook users. Simply insert a SATA 2.5" hard drive ( not supplied ) into the enclosure and Package Includes ● U357-025-R External Enclosure ( no hard drive supplied ) software to load. At only 4.9"L x 3.5"W x 0.63"H, the U357-025-R travels easily and is great for storing ● USB 3.0 Cable large files like photos, music, movies, etc. Compatible with Windows, Mac, and Linux. Supports USB 3.0 ● User Manual plug the built-in USB 3.0 cable into a computer or hub's USB port. The unit is Plug-n-Play so there's no data transfer rates up to 5Gbps, provided the USB source is USB 3.0. Features ● USB 3.0 transfer rates up to 5Gbps, 10X faster than USB 2.0 ● Create a portable, high volume storage device for Laptop / Netbook ● Built-in USB cable for quick attachment to your computer ● SATA I, II, and III compliant ● Backwards compatible with USB 2.0 ● Plug-and-Play, no software required ● No power supply required ● Power / Activity LED Lights Specifications OVERVIEW UPC Code 037332161161 Drives Supported 2.5" SATA Technology SATA/eSATA 1/2 INPUT Input Plug Type USB A (Male) PHYSICAL Color Black Material of Construction ABS Housing Color Black Shipping Dimensions (hwd / in.) 6.30 x 4.80 x 1.20 Shipping Dimensions (hwd / cm) 16.00 x 12.19 x 3.05 Shipping Weight (lbs.) 0.33 Shipping Weight (kg) 0.15 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 1.6 x 8.8 x 12.4 Unit Weight (lbs.) 0.15 Unit Weight (kg) 0.07 CONNECTIONS Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 22 PIN SATA + POWER (FEMALE) WARRANTY Product Warranty Period (Worldwide) 1-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
U357-025-R 价格&库存
很抱歉,暂时无法提供与“U357-025-R”相匹配的价格&库存,您可以联系我们找货
