U223-010
U223-010
    TRIPPLITE
    10-PORT USB 2.0 HI-SPEED HUB
U223-010 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 10-Port USB 2.0 Hub, Black Highlights ● Connects up to 10 USB 2.0 devices ● Bus powered or optional AC adapter ● Compatible with all major operating systems MODEL NUMBER: U223-010 System Requirements ● USB 2.0 Computer Port ● USB Peripherals Package Includes Description Tripp Lite's U223-010, 10-port USB 2.0 hub is the most versatile and powerful hub on the market. It allows you to connect up to ten USB devices to a single USB port on your computer. This unit meets or exceeds USB 2.0 Specifications for Hi-Speed data transmission rates up to 480Mbps. Perfect for both the desktop user. While the hub will function perfectly in virtually all cases without needing external power, a compact, multi-voltage AC adapter (100-240V ) has been provided for the rare circumstance when connecting a power hungry device. This USB 2.0 device is backwards compatible so that it will function with both USB 2.0 and USB 1.1 devices. Over-current protection safeguards connected equipment from over voltages. Features ● USB 2.0 10-Port Hub ● Supports data transfer rates up to 480Mbps ● Connect up to 10 USB devices to a single USB port on your computer ● Compact design is ideal for use with a laptop/notebook computer ● Does not require external power, software, or complicated set-up procedures ● Plug-and-play/hot-swappable allows you to add or remove a device at any time ● Per-port overcurrent protection ● Bus-powered or self-powered ● Supports USB 2.0 spec up to 500mA per port ● On bus-power, 500mA from the USB 2.0 computer port is shared between the hub ports ● The included external power supply provides 4A of power, to be shared between the hub ports (up to 500mA per port) ● Compact, multi-voltage power supply (100-240V) provided ● Compatible with all major operating systems Specifications OVERVIEW 1/4 ● U223-010 USB 2.0 Hub ● User's Manual ● USB 2.0 Mini B male to USB 2.0 A male cable ● External Power Supply with NEMA 1-15P Plug (Input: AC100-240V, 50/60Hz, 1.5A; Output: 5V, 4A) 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332185396 Product Type Hub Technology USB 2.0 (High Speed) Host Connector USB A (MALE) VIDEO Number of Monitors Supported 0 Extended Mode No Mirror Mode No DATA Data Ports (10) USB A (FEMALE) Data Ports Details (10) USB-A - USB 2.0 INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 Bus Powered No Product Length (in.) 8.6 Product Length (cm.) 21.84 Product Length (ft.) 0.72 Product Length (m.) 0.22 POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.9A External Power Supply Output Specs (V / A) 5V / 4A External Power Supply Cord Length (ft.) 4 External Power Supply Cord Length (m.) 1.2 DC Barrel Plug OD: 3.5 x 1.35 x 8mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 0.55 USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Power) PHYSICAL 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Color Black Material of Construction ABS Shipping Dimensions (hwd / in.) 2.20 x 3.20 x 9.10 Shipping Weight (lbs.) 0.70 Unit Dimensions (hwd / in.) 0.600 x 8.600 x 1.300 Unit Dimensions (hwd / cm) 21.84 x 1.52 x 3.3 Unit Packaging Type Box Unit Weight (lbs.) 0.2 Unit Weight (kg) 0.09 ENVIRONMENTAL Operating Temperature Range 32 to 158 F (0 to 70 C) Storage Temperature Range 14 to 194 F (-10 to 90 C) Relative Humidity 10% to 90 % RH, Non-Condensing BTUs 1.9 BTU/Hr Power Provided to Connected Device(s) 5V 0.5A (2.5W) Output per USB port CONNECTIONS Number of Ports 10 Side A - Connector 1 USB A (FEMALE) Side B - Connector 1 (10) USB A (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 2.0 (up to 480 Mbps) Driver Required No STANDARDS & COMPLIANCE External Power Supply Certifications DOE; FCC; UL Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U223-010 价格&库存
很抱歉,暂时无法提供与“U223-010”相匹配的价格&库存,您可以联系我们找货
