U223-004-IND
U223-004-IND
    TRIPPLITE
    4-PORT IND USB 2.0 HUB
U223-004-IND 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port Industrial-Grade USB 2.0 Hub - 15 kV ESD Immunity, Metal Housing, Mountable MODEL NUMBER: U223-004-IND Highlights ● Adds barcode scanner, serial device, sensor—up to 4 devices—to your host computer ● Supports USB 2.0 speeds up to 480 Mbps to ensure reliable data transfers ● Rugged metal housing designed to withstand harsh warehouse and factory environments ● ESD protection to ±15 kV cuts potential static damage to your connected peripherals ● Plug-and-play operation with no software required for easy, immediate installation Applications ● Connect up to 4 USB devices and peripherals to your computer or laptop ● Add easy-to-access USB ports to computers stored in a cabinet, behind furniture or other hard-to-reach location ● Mount to a wall or DIN rail in a harsh environment, such as a factory, construction site, supply room or warehouse Rugged industrial-grade hub adds 4 USB 2.0 ports to your computer for connecting industrial printers, sensors and other USB devices. Features Industrial-Grade USB 2.0 Hub Adds up to 4 USB Devices to Your ComputerThis USB 2.0 hub with a heavy-duty all-metal housing connects as many as four USB devices, such as external hard drives, industrial printers, barcode scanners, serial devices and sensors, to your host PC, server or thin client. The durable metal housing withstands harsh physical conditions in industrial and commercial applications, such as factories, construction sites, supply rooms and warehouses. The hub supports USB 2.0 data transfer rates up to 480 Mbps and is backward compatible with USB 1.1 devices. Protects Your Devices against Electrostatic Discharge (ESD) and OvercurrentMachines on the shop floor can generate electrostatic discharges, wiping out data and damaging sensitive electronics. This fourport hub includes ESD protection to ±15 kV, reducing potential static damage to your connected peripherals. This feature works in tandem with overcurrent protection to safeguard your connected devices against damage and data loss from power surges. Plug-and-Play Hub Offers Flexible Power and Mounting OptionsThe U223-004-IND requires no software or drivers to download and install. It draws power from the connected computer through the included USB cable. You can also plug the included 3-wire terminal block into the hub to draw power from a power terminal, or connect a compatible 5V 2.5A DC power supply (not included) to a standard AC outlet. The hub mounts easily to a wall or DIN rail using the included hardware. Specifications OVERVIEW 1/3 System Requirements ● Compatible with all USBenabled operating systems ● If using an optional power supply, requires 5V 2.5A DC unit with 5.5 x 2.1 x 9.5 mm output plug with a positive pin and negative sleeve Package Includes ● U223-004-IND 4-Port IndustrialGrade USB 2.0 Hub ● USB 2.0 cable, 6 ft. ● 3-pin power terminal block ● DIN rail-mounting hardware ● Wall-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332174284 Product Type Hub Technology USB 2.0 (High Speed) Host Connector USB A (MALE) VIDEO Number of Monitors Supported 0 Extended Mode No Mirror Mode No DATA Data Ports (4) USB A (FEMALE) Data Ports Details (4) USB-A - USB 2.0 INPUT Voltage Compatibility (VAC) 100; 110; 120; 127; 200; 208; 220; 230; 240 Bus Powered Yes POWER DC Barrel Plug OD: 5.5 x 2.1 x 9.5mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 2.50 PHYSICAL Color Black Material of Construction Steel Included Mounting Accessories Yes Shipping Dimensions (hwd / in.) 3.00 x 6.30 x 9.10 Shipping Dimensions (hwd / cm) 7.62 x 16.00 x 23.11 Shipping Weight (lbs.) 1.40 Shipping Weight (kg) 0.64 Unit Dimensions (hwd / in.) 1.000 x 5.500 x 2.500 Unit Dimensions (hwd / cm) 14.2 x 6.36 x 2.46 Unit Packaging Type Box Unit Weight (lbs.) 1 Unit Weight (kg) 0.45 ENVIRONMENTAL 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range 32 to 140 F (0 to 60 C) Storage Temperature Range 14 to 176 F (-10 to 80 C) Relative Humidity 5% to 95% RH, Non-Condensing BTUs 8.5 BTU/Hr Power Provided to Connected Device(s) 5V 0.5A (2.5W) Output per USB Port CONNECTIONS Number of Ports 4 Side A - Connector 1 USB B (FEMALE) Side B - Connector 1 (4) USB A (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS Over Current Protection Yes USB Specification USB 2.0 (up to 480 Mbps) Driver Required No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U223-004-IND 价格&库存
很抱歉,暂时无法提供与“U223-004-IND”相匹配的价格&库存,您可以联系我们找货
U223-004-IND
  • 1+1214.884981+157.16392
  • 5+855.828805+110.71452
  • 10+765.8000010+99.06792
  • 15+751.3281915+97.19577
  • 25+718.4131325+92.93771
库存:14
