U360-004-R
U360-004-R
    TRIPPLITE
    4-PORT USB SUPERSPEED COMP HUB
U360-004-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port USB 3.0 SuperSpeed Hub Highlights ● USB 3.0 SuperSpeed Compatible ● 5Gbps Transfer Speed - 10X as fast as USB 2.0 ● All 4 ports are USB Battery Charging (BC) 1.2-compliant, providing up to 1.5A for charging mobile devices ● External power supply included for use with more power hungry devices MODEL NUMBER: U360-004-R ***NOTE***If your hub features white housing, see the FAQ tab on this page. System Requirements Windows, MAC, or Linux computer with an available USB 3.0 port Package Includes Description Tripp Lites U360-004-R USB 3.0 SuperSpeed 4-port hub carries your data from a USB3.0 enabled computer at a blazing 5Gbps transfer rate. Connect to a variety of USB enabled devices such as USB external hard drives, cameras, printers and more. Backward compatible to previous USB generations. Bus powered for use with devices that require minimal power. For more power hungry devices, an external power supply is included. Sleek, compact design is perfect for USB port expansion. Features ● USB 3.0 SuperSpeed compatible ● 5Gbps Transfer Speed - 10X as fast as USB 2.0 ● Supports USB Battery Charging (BC) specification v1.2 ● On bus-power, 900mA from the USB 3.0 computer port is shared between all four ports ● The included external power supply provides 2A of power, allowing each port to provide up to 1.5A of charging power to mobile devices. ● Plug-and-Play - No Drivers Required ● 1 Upstream and 4 Downstream USB ports Specifications OVERVIEW UPC Code 037332161154 Product Type Hub Technology USB Host Connector USB A (MALE) VIDEO Number of Monitors Supported 0 1/3 ● USB 3.0 SuperSpeed 4-Port Hub ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A) ● USB 3.0 Cable, 3-ft. ● User manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Extended Mode No Mirror Mode No DATA Data Ports (4) USB A (FEMALE) Data Ports Details (4) USB-A - USB 3.2 Gen 1 (5 Gbps) INPUT Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Bus Powered No POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.35A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 5 External Power Supply Cord Length (m.) 1.5 AC Adapter Input: 100-240V, 50/60Hz, 0.35A; Output: 5V, 2A DC Barrel Plug OD: 3.5 x 1.35 x 10mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 0.7 USER INTERFACE, ALERTS & CONTROLS LED Indicators Blue (Power) CHARGING Charging Ports Details Any of the 4 ports Charging Ports (4) USB-A: 5V 1.5A (7.5W) PHYSICAL Color Black Material of Construction ABS Shipping Dimensions (hwd / in.) 5.35 x 2.87 x 4.72 Shipping Dimensions (hwd / cm) 13.59 x 7.29 x 11.99 Shipping Weight (lbs.) 0.61 Shipping Weight (kg) 0.28 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Packaging Type Box Unit Weight (lbs.) 0.13 Unit Weight (kg) 0.06 ENVIRONMENTAL Operating Temperature Range -4 to 158 F (-20 to 70 C) Storage Temperature Range -4 to 185 F (-20 to 85 C) Relative Humidity 20% to 80% RH, Non-Condensing BTUs 2.4 BTU/Hr Power Provided to Connected Device(s) 5V 0.9A (4.5W) Output per USB Port CONNECTIONS Number of Ports 4 Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 (4) USB 3.0 A (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No STANDARDS & COMPLIANCE External Power Supply Certifications FCC; UL; cUL; RoHS Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U360-004-R 价格&库存
很抱歉,暂时无法提供与“U360-004-R”相匹配的价格&库存,您可以联系我们找货
