2909
2909
    ADAFRUIT
    USB 2.0 AND ETHERNET HUB - 3 USB
2909 数据手册
USB 2.0 and Ethernet Hub - 3 USB Ports and 1 Ethernet PRODUCT ID: 2909 DESCRIPTION - One can never have enough socks, or USB ports. Add some more USB and Ethernet capability to your Raspberry Pi or, really, any kind of computer with this USB 2.0 and Ethernet Hub! This handy combo-hub has 3 USB 2.0 ports, and a AX88772A Ethernet transceiver. This chipset is really common and can be used by any Linux, Mac or Windows computer. It's particularly handy for the  Raspberry Pi A+ or brand new Raspberry Pi Zero which is tight on USB ports and has no Ethernet out. We did some basic tests and got 11+ MB/s transfer speeds on our Pi Zero. Note that Ethernet draws a lot of power and you'll be looking at 280mA current draw when the hub is plugged in, even if the Ethernet itself isn't being used. https://www.adafruit.com/product/2909 1/27/2016 Technical Details 3x USB 2.0 ports 1x Ethernet port Supports 10Mbps and 100Mbps N-way auto-negotiation operation Integrated fast Ethernet MAC, physical clip and transceiver in one chip Powered by USB Supports suspend/resume detection logic Supports both full-duplex and half-duplex operations Compliant with IEEE 802.3 (10Based-T) and 802.3u (100Based-TX) standards. Compliant with USB interface versions 1.0/1.1/2.0 Linux, Windows and Mac compatible Hub Dimensions: 23.4mm x 85.1mm x 16.6mm / 0.92" x 3.35" x 0.65" USB cable length: ~110mm / ~4.3" Weight: 29.7g
很抱歉,暂时无法提供与“2909”相匹配的价格&库存,您可以联系我们找货
    库存:87
