U460-004-4A-C
U460-004-4A-C
    TRIPPLITE
    4-PORT USB 3.1 GEN 1 PORTABLE HU
U460-004-4A-C 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port USB-C Hub with Power Delivery, USB-C to 4x USB-A Ports, USB 3.0, White MODEL NUMBER: U460-004-4A-C Highlights ● Supports USB 3.1 Gen 1 data transfer rates up to 5 Gbps ● USB-C PD charging port supports power input up to 20V 3A (60W) ● USB-A fast-charging port provides up to 5V/1.5A (7.5W) for charging devices ● Reversible USB-C plug connects in either direction ● Plug-and-play operation with no software or drivers required System Requirements ● Source device with USB-C or Thunderbolt 3 port Package Includes Adds USB-A and USB-C PD charging ports to the USB-C or Thunderbolt 3 port on your tablet, laptop, notebook, MacBook, Chromebook, smartphone or PC. Description The U460-004-4A-C USB 3.1 Gen 1 USB-C Portable Hub expands the potential of your tablet, laptop, MacBook, Chromebook, smartphone or PC’s USB-C or Thunderbolt 3 port. It’s ideal for adding a thumb drive and other USB peripherals and powering and charging a PD Charging-compliant mobile device—all at the same time. The plug-and-play U460-004-4A-C requires no software, drivers or external power. Connect the reversible USB-C plug to your source device’s USB-C or Thunderbolt 3 port. The fumble-free USB-C plug connects in either direction to ensure fast, easy connection every time. Four USB-A ports accept USB peripherals, such as a flash drive, mouse, keyboard or printer, and the dedicated fast-charging port provides up to 5V/1.5A (7.5W) for charging smartphones and other mobile devices. All ports support fast USB 3.1 Gen 1 data transfer rates up to 5 Gbps and are backward compatible with previous USB generations, so you can continue using older peripherals while getting highspeed performance from new devices. The USB-C Power Delivery (PD) port provides power and charging to the PD Charging-compliant device (such as a MacBook or Chromebook) connected to the U460-004-4A-C. Connect the device’s AC wall charger to the USB-C PD port, which supports power input up to 20V 3A (60W). Features Turn Your Device’s USB-C Port into a Multiport Workstation ● Ideal for adding USB peripherals and powering and charging a PD Charging-compliant mobile device simultaneously ● Plug-and-play operation with no software, drivers or external power required ● About the size of a credit card for easy carrying in a pocket, purse or laptop bag Connect USB Peripherals ● 4 USB-A ports accept flash drives, mice, keyboards, printers and other USB peripherals ● USB-A fast-charging port provides up to 5V/1.5A (7.5W) for charging mobile devices ● Supports USB 3.1 Gen 1 data transfer rates up to 5 Gbps ● Backward compatible with USB 2.0 and USB 1.1 Note: Host must support USB OTG (On-the-Go) Charge a Connected Device 1/4 ● U460-004-4A-C USB 3.1 Gen 1 USB-C Portable Hub ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● USB-C PD port connects to wall charger to power and charge the connected PD Charging-compliant USB-C/Thunderbolt 3 device ● Supports power input up to 20V 3A (60W) Note: USB-C PD port does not support Quick Charge (QC). Built-In Cable with Reversible USB-C Connector ● Fumble-free reversible USB-C plug connects in either direction for quick connection every time Specifications OVERVIEW UPC Code 037332193773 Host Connector USB C (MALE) INPUT Bus Powered Yes Product Length (in.) 6 Product Length (cm.) 15.24 Product Length (ft.) 0.5 Product Length (m.) 0.15 BATTERY Battery Charging (5V/1.5A Port) Yes POWER Power Consumption (Watts) 2.2 USB Power Delivery (PD) Charging Support Yes CHARGING Total Charging Watts 60 Charging Ports / Amps 1.5A; 3A PHYSICAL Color White Material of Construction Plastic Cable Jacket Rating VW-1 Shipping Dimensions (hwd / in.) 1.00 x 3.90 x 5.60 Shipping Weight (lbs.) 0.15 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Packaging Type Box Unit Weight (lbs.) 0.1 Unit Weight (kg) 0.05 ENVIRONMENTAL Operating Temperature Range 32 to 113 °F (0 to 45 °C) Storage Temperature Range 14 to 158 °F (-10 to 70 °C) Relative Humidity 10% to 90% RH, Non-Condensing BTUs 7.5 BTU/Hr Power Provided to Connected Device(s) Up to 20V 3A (60W) Input (USB-C), 5V 1.5A (7.5W) Output USB port, 5V 0.9A (4.5W) Output per USB port CONNECTIONS Number of Ports 5 Side A - Connector 1 USB C (MALE) Side B - Connector 1 (4) USB 3.0 A (FEMALE) Side B - Connector 2 USB C (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No UASP Support No Auto MDIX Support No Full Duplex Support No Suspend Mode Support No Remote Wakeup Support No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U460-004-4A-C 价格&库存
很抱歉,暂时无法提供与“U460-004-4A-C”相匹配的价格&库存,您可以联系我们找货
