QSU2-100
QSU2-100
    B+BSMARTWORX
    USB 2.0 SERIAL ADAPTER 4 PORT
QSU2-100 数据手册
High Speed USB Serial Adapters Standard serial ports via USB 2.0 without replacing peripheral hardware or application software For over 20 years, Quatech has been known to help you Connect with Reliability. As we continue in the race to become the industry leader, our high performance device connectivity line expands with the new high speed USB 2.0 Serial Adapters. The next generation Quatech USB Serial Adapter hits speeds of up to 921.6 kbps, 1024-byte FIFO and hardware and software flow control. Connect serial peripherals with USB 2.0 Serial Adapters If speed, expansion and support are what you’re looking for in a USB Serial Adapter, think Quatech. You can now broaden the range of external peripherals used on your computer at higher speed rates than the USB 1.1 series, with the introduction of the High Speed USB 2.0 Serial Adapters. The USB 2.0 has more bandwidth that allows higher data rates on the serial ports for more efficiency. The new High Speed USB Serial Adapter line gives your laptop or workstation the ability to communicate between a USB port and up to eight RS232, RS-422, or RS-485 serial peripherals. It adds the COM port(s) via its USB connection and is compatible with new and legacy RS-232 or RS232/422/485 devices. The USB Serial Adapters are the ideal solution for a variety of industries and applications including banking, retail and industrial automation where PCs have a significantly shorter lifecycle than the peripherals that use them. Rev C 2/2008 Quatech USB Serial Adapters enumerate themselves as standard COM ports that are compatible with all standard RS-232 or RS-232/422/485 devices and software created for them. With the industrial surge suppression “IND” option, you can safeguard the USB Serial Adapter. The “IND” option is ideal for implementing USB-to-serial networks in factories, power plants and other potentially harsh industrial environments. USB 2.0 is fully compatible with USB 1.1 devices. The older devices work with the new bus, and vice versa. The 400 Series models introduce the software-selectable RS-232/422/485 (Multi-Electrical Interface or MEI). The MEI capability is available on all ports at the click of a mouse. LEDs visually tell you which ports are using which protocol, so go ahead, mix and match. KEY FEATURES 1, 2, 4 or 8 independent serial ports RS-232 or software-selectable RS-232/422/485 Compatible with USB 1.1 Plug-and-play capability Devices enumerate themselves as standard COM ports Speeds up to 921.6 kbps High speed UARTs with 1KB FIFOs to boost data rates Optional surge suppression package (standard on Embedded products) Full modem control and hardware and software flow control Bus powered: no external power required Embedded (board-only) units also available Windows 2000/XP/Vista and Linux Auto detect between RS-422 and RS485 with Quatech’s new USB Serial Converter. Embedded USB Serial Adapters for custom enclosures RoHS compliant NEW! USB to RS-422/485 Converter 5 year warranty If you’re looking to seamlessly connect multiple serial peripherals via a single USB port in a custom enclosure, try Quatech’s board-level solutions, Embedded USB Serial Adapters. 5675 Hudson Industrial Parkway * Hudson, OH 44236 1.800.553.1170 * +1 330.655.9000 * www.quatech.com HIGH SPEED USB 2.0 SERIAL ADAPTER SPECIFICATIONS USB Ports Required SSU: 1 DSU: 1 Ordering Information Model Ports Interface DSU2-100 2 RS-232 with cable DSU2-400 2 RS-232/422/485 with cable QSU2-100 4 RS-232 with cable QSU2-400 4 RS-232/422/485 with cable ESU2-100 8 RS-232 with cable ESU2-400 8 RS-232/422/485 with cable QSU: 1 IND Option: Surge suppression applied to each line that is capable of sustaining up to 40A peak, 8 x 20ìs transient surges, a clamping voltage of 30V and a peak energy dissipation of 0.1 Joules. ESU: 1 UARTS 1024-byte FIFOs for transmit and receive (NOTE: The “IND” option limits data rate to 115.2 kbps) Transceiver (RS-232/422/485) MAX491 or compatible Environment Operating: 0° to 70°C Storage: -50° to 80° C Humidity: 10% to 90% Differential Driver Output (50Ù Load): +2V (min), +3.3V (max) Differential Driver Output (27Ù Load): +1.5V (min), +3.3V (max) OS Support Windows 2000/XP/Vista and Linux support High Input: +2V (min) Low Input: +0.8V (max) Driver Rise/Fall Time: 5ns (min), 20ns (typ), 25ns (max) Driver Input to Output Delay: 20ns (min), 40ns (typ), 60ns (max) Receiver Input to Output Delay: 40ns (min), 70ns (typ), 100ns (max) Data Rate Up to 921.6 kbps (max) RS-232 Output Voltage Swing: ±5V (min), ±5.4V (typ) Serial Ports Provided SSU: 1 DSU: 2 QSU: 4 ESU: 8 (For 400 models, each configurable as RS-232, RS422 or RS-485 for full or half duplex communication) RS-232 Input Voltage Range: -15V (min), +15V (max) Input Threshold Low: 0.6V (min), 1.0 (typ) Input Threshold High: 2.4VV (max), 1.5 (typ) Bus Interface USB 2.0 High Speed Retail Application Power Requirements Bus-powered device, no external power supply required Suspend power: < 500 ì A Unconfigured power: < 100 mA Configured power: < 500 mA Size SSU: 3.6” L x 1.7” W x 1” H DSU/QSU: 9.18” L x 5.25” W x 1.675” H ESU: 9.18” L x 5.25” W x 2.363” H Connectors DB-9 male Certifications CE, FCC Class B, RoHS & WEEE Compliant Banking Application High Speed Modem Central Bank Server at Remote Location Multiport USB to RS-232 Serial Adapter Branch Host PC RS-232 RS-232 Teller Station 1 Teller Station 2 5675 Hudson Industrial Parkway * Hudson, OH 44236 Rev. C 2/2008 1.800.553.1170 * +1 330.655.9000 * www.quatech.com Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: B&B Electronics: QSU2-400-IND
QSU2-100 价格&库存
很抱歉,暂时无法提供与“QSU2-100”相匹配的价格&库存,您可以联系我们找货
