U360-007-IND
U360-007-IND
    TRIPPLITE
    USB3CHARGINGHUB7-PORTXUSB
U360-007-IND 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 7-Port Industrial-Grade USB 3.0 SuperSpeed Hub - 20 kV ESD Immunity, Metal Housing, Mountable MODEL NUMBER: U360-007-IND Highlights ● Adds barcode scanner, serial device, sensor—up to 7 devices—to your host computer ● Supports USB 3.0 SuperSpeed rates up to 5 Gbps to ensure fast data transfers ● Rugged metal housing designed to withstand harsh warehouse and factory environments ● ESD protection to ±20 kV cuts potential static damage to your connected peripherals ● Plug-and-play operation with no software required for easy, immediate installation Applications ● Connect up to 7 USB devices and peripherals to your computer or laptop ● Add easy-to-access USB ports to computers stored in a cabinet, behind furniture or other hard-to-reach location ● Mount to a wall or DIN rail in a harsh environment, such as a factory, construction site, supply room or warehouse Rugged industrial-grade hub adds 7 USB 3.0 ports to your computer for connecting industrial printers, sensors and other USB devices. Features Industrial-Grade USB 3.0 Hub Adds up to 7 USB Devices to Your ComputerThis USB 3.0 hub with a heavy-duty all-metal housing connects as many as seven USB devices, such as external hard drives, industrial printers, barcode scanners, serial devices and sensors, to your host PC, server or thin client. The durable metal housing withstands harsh physical conditions in industrial and commercial applications, such as factories, construction sites, supply rooms and warehouses. Supports SuperSpeed USB 3.0 to Ensure Fast Data TransfersThe hub supports USB 3.0 SuperSpeed data transfer rates up to 5 Gbps, which is 10 times faster than USB 2.0. It is especially recommended for high-bandwidth USB 3.0 devices, such as security cameras and high-resolution webcams. Each downstream port provides up to 900 mA for charging mobile devices. The hub is backward compatible with previous USB standards, so you can also continue using older peripherals while getting maximum performance from current devices. Protects Your Devices against Electrostatic Discharge (ESD) and OvercurrentMachines on the shop floor can generate electrostatic discharges, wiping out data and damaging sensitive electronics. This seven-port hub includes ESD protection to ±20 kV, reducing potential static damage to your connected peripherals. This feature works in tandem with ±2.5kV-per-port overcurrent protection to safeguard your connected devices against damage and data loss from power surges. Plug-and-Play Hub Offers Flexible Power and Mounting OptionsThe U360-007-IND requires no software or drivers to download and install. It draws power from the connected computer through the included USB cable. You can also plug the included 3-wire terminal block into the hub to draw power from a power terminal, or connect a compatible 9V–40V DC LPS power supply (not included) to a standard AC outlet. The hub mounts easily to a wall or DIN rail using the included hardware. Specifications 1/4 System Requirements ● Compatible with all USBenabled operating systems (USB 3.0 port needed to achieve USB 3.0 speeds) ● If using an optional LPS power supply, requires 9–40V DC unit with 5.5 x 2.1 x 9.5 mm output plug with either positive pin/negative sleeve or negative pin/positive sleeve Package Includes ● U360-007-IND 7-Port IndustrialGrade USB 3.0 SuperSpeed Hub ● USB 3.0 cable, 3 ft. ● 3-pin power terminal block ● DIN rail-mounting hardware ● Wall-mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332186300 Product Type Hub Technology USB 3.x Host Connector USB A (MALE) VIDEO Number of Monitors Supported 0 DATA Data Ports (7) USB A (FEMALE) Data Ports Details (7) USB-A - USB 3.2 Gen 1 (5 Gbps) INPUT Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Bus Powered Yes Product Length (in.) 6.22 Product Length (cm.) 15.8 Product Length (ft.) 0.518 Product Length (m.) 0.158 POWER Power Source Type USB External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.6A External Power Supply Output Specs (V / A) 9V - 40V / 3A AC Adapter Input: 100-240V, 50/60Hz, 0.6A; Output: 9-40V, 3A DC Barrel Plug OD: 5.5 x 2.1 x 9.5mm, Positive Pin, Negative Sleeve Power Consumption (Watts) 32.4 USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (Power, 1, 2, 3, 4, 5, 6, 7) PHYSICAL Color Black Material of Construction Steel (Galvanized Cold Rolled) Included Mounting Accessories Yes 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 2.60 x 4.50 x 7.40 Shipping Dimensions (hwd / cm) 6.60 x 11.43 x 18.80 Shipping Weight (lbs.) 1.20 Shipping Weight (kg) 0.54 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Packaging Type Box Unit Weight (lbs.) 0.75 Unit Weight (kg) 0.34 ENVIRONMENTAL Operating Temperature Range 32 to 140 °F (0 to 60 °C) Storage Temperature Range 14 to 176 °F (-10 to 80 °C) Relative Humidity 5% to 90% RH, Non-Condensing BTUs 110.6 BTU/Hr Power Provided to Connected Device(s) 5V 0.9A (4.5W) Output (USB-A 3.0) CONNECTIONS Number of Ports 7 Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 (7) USB 3.0 A (FEMALE) FEATURES & SPECIFICATIONS Over Current Protection Yes USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA); UKCA WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U360-007-IND 价格&库存
很抱歉,暂时无法提供与“U360-007-IND”相匹配的价格&库存,您可以联系我们找货
