U360-004-MINI
U360-004-MINI
    TRIPPLITE
    4-PORTUSBSUPERSPEEDCOMPHUB
U360-004-MINI 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port Portable USB 3.0 SuperSpeed Hub Highlights ● Portable design with built-in 1-ft. cable ● USB data transfer rates up to 5Gbps ● Plug and Play MODEL NUMBER: U360-004-MINI System Requirements ● Desktop, Laptop or Tablet with USB 3.0 USB port ● USB 3.0 ( or less ) Peripherals Package Includes ● Connect up to four USB devices via a single USB 3.0 port on your desktop, laptop, or tablet Description Tripp Lite U360-004-MINI is a compact, 4-Port USB 3.0 SuperSpeed hub, with built-in cable, that provides up to 5Gbps transfer rates in a compact, portable format ( Computer and devices must be both USB3.0 rated to achieve maximum 5Gbps speeds ). Hub is backward compatible to USB 2.0 and 1.1, so that older USB devices can be attached ( devices will run at their native speeds of 480Mbps and 12Mbps respectively ). Small, portable design allows the hub to travel easily, and built-in cable eliminates the need to carry a separate cable for attachment to laptops and tablets. Needed power comes from the attached computer... no need for external power adapter. Plug-n-Play...no drivers or software required. Works with all Windows and MAC operating systems. Features ● Add 4 additional USB 3.0 ports to your PC, Laptop, or Tablet ● Compact design...4in long by 1.25in wide by .75in high ● Built-in 1-ft. attachment cable ● USB 3.0 SuperSpeed 5gbps ● Plug-n-Play...no drivers or software to load ● Bus powered...separate power supplied not needed ● Compatible with all Windows and MAC OS ● Backward compatible with Hi-Speed ( 480Mbps ), Full Speed ( 12Mbps ), and Low Speed ( 1.5Mbps) USB versions Specifications OVERVIEW UPC Code 037332184726 Product Type Hub Host Connector USB A (MALE) 1/3 Portable USB 3.0 SuperSpeed Hub - 4-Port 1000 Eaton Boulevard Cleveland, OH 44122 United States VIDEO Number of Monitors Supported 0 Extended Mode No Mirror Mode No DATA Data Ports (4) USB A (FEMALE) Data Ports Details (4) USB-A - USB 3.2 Gen 1 (5 Gbps) INPUT Bus Powered Yes Product Length (in.) 16.8 Product Length (cm.) 42.67 Product Length (ft.) 1.4 Product Length (m.) 0.426 POWER Power Source Type USB Power Consumption (Watts) 0.77 PHYSICAL Color Black; Silver Material of Construction Plastic Cable Jacket Rating VW-1 Included Mounting Accessories No Shipping Dimensions (hwd / in.) 5.50 x 3.90 x 1.20 Shipping Dimensions (hwd / cm) 13.97 x 9.91 x 3.05 Shipping Weight (lbs.) 0.24 Shipping Weight (kg) 0.11 Unit Dimensions (hwd / in.) 0.750 x 3.500 x 2.250 Unit Packaging Type Box Unit Weight (lbs.) 0.13 Unit Weight (kg) 0.06 ENVIRONMENTAL Operating Temperature Range -4 to 158 F (-20 to 70 C) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Storage Temperature Range -4 to 185 F (-20 to 85 C) Relative Humidity 20% to 80% RH, Non-Condensing BTUs 2.6 BTU/Hr Power Provided to Connected Device(s) 5V 0.9A (4.5W) Output per USB port CONNECTIONS Number of Ports 4 Side A - Connector 1 USB 3.0 A (MALE) Side B - Connector 1 (4) USB 3.0 A (FEMALE) Connector Plating Nickel FEATURES & SPECIFICATIONS USB Specification USB 3.0 (up to 5 Gbps); USB 3.1 Gen 1 (up to 5 Gbps) Driver Required No STANDARDS & COMPLIANCE Product Compliance RoHS; CE (Europe); REACH; FCC (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U360-004-MINI 价格&库存
很抱歉,暂时无法提供与“U360-004-MINI”相匹配的价格&库存,您可以联系我们找货
