U224-4R4-R
U224-4R4-R
    TRIPPLITE
    HUB USB 4-PORT
U224-4R4-R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Port USB over Cat5 Hub with 4 Remote Ports, TAA MODEL NUMBER: U224-4R4-R Highlights ● Locate 4 USB 1.1 peripherals up to 150-ft. (45.72 m) from your computer ● Uses readily available Cat5e/Cat6 patch cable ● Plug-and-play; no software or drivers required ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Package Includes Description Tripp Lite's 4-Port USB 1.1 over Cat5 extender hub allows USB peripherals to be located up to 150-ft. (45.72 m) from your computer. Simply plug the transmitter into the USB port on your computer, connect your USB peripherals, and run Cat5e/Cat6 cable up to 150-ft. (45.72 m) to the remote receiver unit and connected devices. Plug-and-play; no software or drivers required. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Features ● Locate 4 USB 1.1 peripherals up to 150-ft. (45.72 m) from your computer ● Uses readily available Cat5e/Cat6 patch cable ● Plug-and-play; no software or drivers required ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332146687 Product Type Hub Technology USB 2.0 (High Speed) Host Connector USB A (MALE) VIDEO Number of Monitors Supported 0 Extended Mode No 1/3 ● Local transmitter unit ● 4-Port remote receiver unit ● External Power Supply with NEMA 1-15P Plug (Input: 100240V, 50/60Hz, 0.5A; Output: 5V, 2A, 4.5 ft.) ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Mirror Mode No DATA Data Ports (4) USB A (FEMALE) Data Ports Details (4) USB-A - USB 2.0 INPUT Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 POWER Power Source Type AC Adapter External Power Supply Plug(s) NEMA 1-15P North America External Power Supply Input Specs (V / Hz / A) 100-240V / 50/60Hz / 0.35A External Power Supply Output Specs (V / A) 5V / 2A External Power Supply Cord Length (ft.) 4.5 External Power Supply Cord Length (m.) 1.5 AC Adapter Input: 100-240V, 50/60Hz, 0.5A; Output: 5V, 2A, 4.5 ft. DC Barrel Plug OD: 3.5 x 1.35 x 8mm, Positive Pin, Negative Sleeve USER INTERFACE, ALERTS & CONTROLS LED Indicators Red - Connection; Green - Activity PHYSICAL Color Black Material of Construction Plastic Receiver Unit Height (in.) 0.9 Receiver Unit Width (in.) 2.4 Receiver Unit Depth (in.) 3.3 Shipping Dimensions (hwd / in.) 2.30 x 8.90 x 5.90 Shipping Dimensions (hwd / cm) 5.84 x 22.61 x 14.99 Shipping Weight (lbs.) 0.75 Shipping Weight (kg) 0.34 Transmitter Unit Depth (in.) 2.6 Transmitter Unit Height (in.) 0.9 Transmitter Unit Width (in.) 1.8 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States CONNECTIONS Number of Ports 4 Side A - Connector 1 USB A (MALE) Side A - Connector 2 RJ45 (FEMALE) Side B - Connector 1 (4) USB A (FEMALE) Side B - Connector 2 RJ45 (FEMALE) STANDARDS & COMPLIANCE External Power Supply Certifications CE; FCC; UL Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
U224-4R4-R 价格&库存
很抱歉,暂时无法提供与“U224-4R4-R”相匹配的价格&库存,您可以联系我们找货
