2991
2991
    ADAFRUIT
    BATTERY CONTACT NEGATIVE SMD
2991 数据手册
USB Mini Hub with Power Switch - OTG Micro-USB PRODUCT ID: 2991 DESCRIPTION - Do you ever find yourself saying, "Gee whiz I wish I could plug in 4 more USB devices to my tablet, or microcontroller with USB host, or a Pi Zero?" I did - literally every single day.  But then I found this Micro USB powered hub and stopped having to repeat myself! This mini USB hub has four USB 2.0 ports each with a max total transmission speed up to 480 MBps. All four ports are powered thru the USB micro-B cable. There's also a single on-off switch that controls the four USB ports. There is a port for an external power supply but its connected directly to the 5V line so if you need to externally power, we recommend prying open the case and cutting the red 5V line from the USB connection. This hub is great for expanding your Pi Zero's USB port, or connecting to a tablet or other device with OTG USB, no adapter required! https://www.adafruit.com/products/2991 2/24/2016 Technical Details FE1.1s Datasheet (the hub chip inside) Dimensions: 72mm x 25mm x 19mm / 2.8" x 1.0" x 0.7"  Cable: 130mm / 5.1"  Weight: 24g
很抱歉,暂时无法提供与“2991”相匹配的价格&库存,您可以联系我们找货
