1000 Eaton Boulevard
Cleveland, OH 44122
United States
Computer with DisplayPort 1.2-compatible graphics card (e.g. AMD Radeon with AMD Eyefinity) required
for video wall mode. Backward compatible with most DisplayPort 1.1a equipment running current graphics
Highlights
Supports UHD video resolutions
up to 4K @ 60Hz (3840 x 2160)
Built-in 6 in. cable connects
directly to Mini DisplayPort
source
Supports up to 48-bit Deep
Color (16 bits per channel)
Works with all operating
systems
Supports DTS-HD, Dolby
TrueHD and 7.1-channel
surround sound
drivers with feature set limited to that of your equipment. Compatibility with older graphics cards not
guaranteed. MST compliant DisplayPort 1.2 graphics cards are limited to a bandwidth of 21.6 Gbps
amongst all monitors, with higher resolution monitors using up more bandwidth. 1080p monitors will use
up approximately 22% of bandwidth, whereas 4K monitors will use 40% or more. As each monitor will be
different, it is necessary to verify the percentage of bandwidth being used by each monitor in the display
settings interface for your graphics card. If the total percentage of bandwidth taken up by all of the
connected monitors exceeds 100%, an image will not display on one or more of them.Maximum supported
video resolutions and number of monitors depend on your graphics card. Check graphics card
specifications to determine its capabilities.
2-Port Mini DisplayPort to HDMI Multi-Monitor
Splitter, MST Hub, 4K UHD, DP1.2, TAA
System Requirements
Computer with DisplayPort 1.2compatible graphics card (e.g.
AMD Radeon with AMD
Eyefinity) required for video wall
mode
running current graphics drivers
guaranteed.
Mac OS X does not support
MST for NVIDIA and Intel
Graphics Processor Units,
limiting video display on
connected monitors to mirror
mode.
Maximum supported video
card specifications to determine
its capabilities.
Monitor with HDMI input
MODEL NUMBER: B155-002-HD-V2
Displays the same image on 2 HDMI monitors, extends the desktop across both, or combines both into
one large monitor. Ideal for digital signage in schools, churches, conference rooms, trade shows and retail
outlets.
Package Includes
Description
The B155-002-HD-V2 2-Port Mini DisplayPort 1.2 to HDMI MST Hub connects two HDMI televisions,
projectors or monitors to the MDP output on your computer. Ideal for digital signage in schools, churches,
conference rooms, trade shows, hotels and retail outlets, this hub allows you to display the same image
on both monitors, extend the desktop across them, or combine both into one large monitor in video wall
mode.
The B155-002-HD-V2 is compliant with DisplayPort 1.2 and backward compatible with versions 1.1 and
1.1a with the feature set being limited to that of your equipment. It supports Ultra High Definition (UHD)
video resolutions up to 4K @ 60Hz (3840 x 2160). This MST hub also supports HDCP, EDID, DDC and
48-bit Deep Color (16 bits per channel), as well as DTS-HD, Dolby TrueHD and 7.1-channel surround
sound audio.
The B155-002-HD-V2 works with all operating systems. Plug-and-play convenience means no software,
drivers or external power supply is needed. The included three-foot USB Micro-B cable delivers necessary
power from the connected computer. A built-in six-inch cable connects directly to an MDP source. LEDs
indicate when the monitors are receiving a signal. The B155-002-HD-V2 complies with the Federal Trade
Agreements Act (TAA) for GSA Schedule purchases.
Features
1/4
Hub
USB Micro-B cable, 3 ft.
Owner’s manual
Cleveland, OH 44122
United States
Connects 2 HDMI Displays to Your Computer’s Mini DisplayPort OutputIdeal for digital signs in
schools, churches, conference rooms, trade shows and retail settingsDisplays same image on 2 monitors
simultaneously in mirror modeExtends desktop across 2 monitors in extended modeCombines 2 monitors
into one large monitor in video wall modeBuilt-in 6 in. cable connects directly to Mini DisplayPort
sourceLEDs indicate when monitors are receiving a signal
Meets the Latest Performance StandardsSupports UHD video resolutions up to 4K @ 60Hz (3840 x
2160)Supports HDCP, EDID and DDCSupports 48-bit Deep Color (16 bits per channel)Supports DTS-HD,
Dolby TrueHD and 7.1-channel surround sound audioBackward compatible with DisplayPort 1.1 and 1.1a
Easy to Use Almost AnywhereWorks with all operating systemsPlug and play—no software, drivers or
external power supply requiredBus-powered via included USB Micro-B cable
TAA CompliantComplies with Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332193445
Technology
DisplayPort; HDMI
Host Connector
MINI DISPLAYPORT (MALE)
VIDEO
Max Supported Video Resolution
Max Supported Color Depth
48-bit Deep Color
3D Video Supported
Yes
AUDIO
Audio Specification
DTS-HD, Dolby TrueHD and 7.1-channel surround sound audio
POWER
Power Consumption (Watts)
4.1
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
(x2) Orange (Monitor Signal)
PHYSICAL
Color
Black
Material of Construction
Plastic
Rackmountable
No
Shipping Dimensions (hwd / in.)
7.87 x 1.73 x 5.59
Shipping Dimensions (hwd / cm)
19.99 x 4.39 x 14.20
Shipping Weight (lbs.)
0.40
2/4
Cleveland, OH 44122
United States
Shipping Weight (kg)
0.18
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Dimensions (hwd / cm)
7.6 x 6.15 x 2.55
Unit Dimensions (hwd / mm)
61.5 x 76 x 25.5
Unit Packaging Type
Box
Unit Weight (lbs.)
0.154
Unit Weight (kg)
0.07
ENVIRONMENTAL
Operating Temperature Range
14 to 167 °F (-10 to 75 °C)
Storage Temperature Range
-4 to 176 °F (-20 to 80 °C)
Relative Humidity
0% to 85%, Non-Condensing
BTUs
14 BTU/Hr
COMMUNICATIONS
EDID Compatible
Yes
CONNECTIONS
Number of Ports
2
Side A - Connector 1
Side A - Connector 2
MICRO-USB B (FEMALE)
Side B - Connector 1
(2) HDMI (FEMALE)
Connector Plating
Nickel
Contact Plating
Gold
FEATURES & SPECIFICATIONS
Displayport Specification
1.2
HDCP Specification
1.3
Driver Required
No
MST Support
Yes
STANDARDS & COMPLIANCE
Product Compliance
RoHS; CE (Europe); REACH; FCC (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
3/4
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“B155-002-HD-V2”相匹配的价格&库存,您可以联系我们找货
